ERROR: Cannot uninstall idna 3.3, RECORD file not found - doublon
Tout fonctionnais bien depuis plus d’un an.
Je n’avais plus de remonter de mes périphérique Zigbbee, j’ai relancé une install des dépendance et tjs echec.
Version zigbee : 2023-05-26 01:03:31
J’ai éssayé de desinstallé réinstallé tjs ko, j’ai fait :
sudo apt update
sudo apt-get update
Mise à jour de tous jeedom depuis le centre de mise à jour.
C’est tjs KO. :
zigbee_packages : J’ai laissé se qu’il me semble le plus utile …
Reading package lists...
Building dependency tree...
Reading state information...
Package 'rustc' is not installed, so not removed
The following package was automatically installed and is no longer required:
  rpi-eeprom-images
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (23.2.1)
WARNING: Error parsing requirements for idna: [Errno 2] No such file or directory: '/usr/local/lib/python3.7/dist-packages/idna-3.3.dist-info/METADATA'
WARNING: Error parsing requirements for pyudev: [Errno 2] No such file or directory: '/usr/local/lib/python3.7/dist-packages/pyudev-0.23.2.dist-info/METADATA'
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Installing collected packages: setuptools
  Attempting uninstall: setuptools
    Found existing installation: setuptools 68.0.0
    Uninstalling setuptools-68.0.0:
      Successfully uninstalled setuptools-68.0.0
Successfully installed setuptools-68.0.0
Installing collected packages: wheel
  Attempting uninstall: wheel
    Found existing installation: wheel 0.41.2
    Uninstalling wheel-0.41.2:
      Successfully uninstalled wheel-0.41.2
Successfully installed wheel-0.41.2
Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests
  Attempting uninstall: urllib3
    Found existing installation: urllib3 2.0.4
    Uninstalling urllib3-2.0.4:
      Successfully uninstalled urllib3-2.0.4
  Attempting uninstall: idna
    WARNING: No metadata found in /usr/local/lib/python3.7/dist-packages
    Found existing installation: idna 3.3
ERROR: Cannot uninstall idna 3.3, RECORD file not found. You might be able to recover from this via: 'pip install --force-reinstall --no-deps idna==3.3'.
→ j’ai fait ça pip install --force-reinstall --no-deps idna==3.3 mais tjs KO
Quelqu’un à une idée ?
Merci pour vos lumières
Aucune idée si cela va résoudre le cas mais il faudrait plutot faire ceci
sinon ce n’est probablement pas la bonne version de pip qui a été utilisée
une petite recherche sur les erreurs similaires: Résultats de recherche pour « ERROR: Cannot uninstall idna 3.3, RECORD file not found » - Communauté Jeedom
C’est un soucis connu et ceux pourquoi ce plugin n’est plus activement maintenu (entre autre). Le mieux est de passer sur jeezigbee.
Bonjour j’ai éssayé ça
sudo python3 -m pip install --force-reinstall --no-deps idna==3.3
mais pas mieux, j’ai donc suivi le conseil de Loic et en effet tout fonctionne correctement avec jeezigbee.
Merci à vous !
