Dans les logs (http.error) j’ai beaucoup d’erreur avec Undefined index: HTTP_X_FORWARDED_PROTO.
Exemple :
[Fri May 15 07:02:38.373624 2020] [php7:notice] [pid 32026] [client XXXX:61700] PHP Notice: Undefined index: HTTP_X_FORWARDED_PROTO in /var/www/html/core/php/authentification.php on line 30, referer: http://XXXX/index.php?v=d&p=log
→ si je suis sur la page Log
[Fri May 15 07:06:12.295507 2020] [php7:notice] [pid 18687] [client XXX:61731] PHP Notice: Undefined index: HTTP_X_FORWARDED_PROTO in /var/www/html/core/php/authentification.php on line 30, referer: http://XXX/index.php?v=d&m=consoWidget&p=widget&id=507&widget=1
[Fri May 15 07:06:12.304853 2020] [php7:notice] [pid 18687] [client XXX:61731] PHP Notice: Undefined index: HTTP_X_FORWARDED_PROTO in /var/www/html/core/php/authentification.php on line 30, referer: http://XXX/index.php?v=d&m=consoWidget&p=widget&id=507&widget=1
[Fri May 15 07:06:12.350172 2020] [php7:notice] [pid 18687] [client :61731] PHP Notice: Undefined index: HTTP_X_FORWARDED_PROTO in /var/www/html/core/php/authentification.php on line 30, referer: http://XXX/index.php?v=d&m=consoWidget&p=widget&id=507&widget=1
[Fri May 15 07:06:12.360608 2020] [php7:notice] [pid 18687] [client XXX:61731] PHP Notice: Undefined index: HTTP_X_FORWARDED_PROTO in /var/www/html/core/php/authentification.php on line 30, referer: http://XXX/index.php?v=d&m=consoWidget&p=widget&id=507&widget=1
[Fri May 15 07:06:12.383907 2020] [php7:notice] [pid 18687] [client XXX:61731] PHP Notice: Undefined index: HTTP_X_FORWARDED_PROTO in /var/www/html/core/php/authentification.php on line 30, referer: http://XXX/index.php?v=d&m=consoWidget&p=widget&id=507&widget=1
[Fri May 15 07:06:12.393082 2020] [php7:notice] [pid 18687] [client XXX:61731] PHP Notice: Undefined index: HTTP_X_FORWARDED_PROTO in /var/www/html/core/php/authentification.php on line 30, referer: http://XXX/index.php?v=d&m=consoWidget&p=widget&id=507&widget=9
[Fri May 15 07:06:12.405981 2020] [php7:notice] [pid 18687] [client XXX:61731] PHP Notice: Undefined index: HTTP_X_FORWARDED_PROTO in /var/www/html/core/php/authentification.php on line 30, referer: http://XXX/index.php?v=d&m=consoWidget&p=widget&id=507&widget=5
[Fri May 15 07:06:12.418785 2020] [php7:notice] [pid 18687] [client XXX:61731] PHP Notice: Undefined index: HTTP_X_FORWARDED_PROTO in /var/www/html/core/php/authentification.php on line 30, referer: http://XXX/index.php?v=d&m=consoWidget&p=widget&id=507&widget=1
→ si je suis sur le dashboard
Je suis en version 4.1.9 sur une VM freebox Delta
