je suis en Jeedom 4.1.25
Depuis la version Beta du 2021-09-10 01:03:24, j’ai toujours le même message d’erreur :
No module named 'zhaquirks.tuya.air’
J’ai la même erreur sur les versions suivantes du plugin.
Je suis donc revenu a la version juste avant celle du 10/09 et c’est OK
[2021-09-15 09:17:05][DEBUG] : Loading custom quirks from /var/www/html/plugins/zigbee/resources/zigbeed/quirks
[2021-09-15 09:17:05][DEBUG] : Loading custom quirks module schneider
[2021-09-15 09:17:05][DEBUG] : Loading custom quirks module ts130f-curtain
[2021-09-15 09:17:05][DEBUG] : Loading custom quirks module tuya-CO
[2021-09-15 09:17:05][ERROR] : [start_zigbee] Fatal error : No module named 'zhaquirks.tuya.air'
[2021-09-15 09:17:05][DEBUG] : Traceback (most recent call last):
File "/var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py", line 68, in start_zigbee
zhaquirks.const.CUSTOM_QUIRKS_PATH : os.path.dirname(os.path.realpath(__file__))+'/quirks'
File "/usr/local/lib/python3.7/dist-packages/zhaquirks/__init__.py", line 403, in setup
importer.find_module(modname).load_module(modname)
File "<frozen importlib._bootstrap_external>", line 407, in _check_name_wrapper
File "<frozen importlib._bootstrap_external>", line 907, in load_module
File "<frozen importlib._bootstrap_external>", line 732, in load_module
File "<frozen importlib._bootstrap>", line 265, in _load_module_shim
File "<frozen importlib._bootstrap>", line 696, in _load
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/var/www/html/plugins/zigbee/resources/zigbeed/quirks/tuya-CO.py", line 15, in <module>
from zhaquirks.tuya.air import (
ModuleNotFoundError: No module named 'zhaquirks.tuya.air'
[2021-09-15 09:17:05][DEBUG] : Shutdown
[2021-09-15 09:17:05][DEBUG] : Removing PID file /tmp/jeedom/zigbee/deamon_1.pid
[2021-09-15 09:17:05][DEBUG] : Exit 0
