Erreur suite au passage sur debian 13
Je viens de passer sur Debian 13 et j’ai cette erreur en stable:
File "/var/www/html/plugins/toshibaac/resources/toshibaacd/toshibaacd.py", line 207, in <module>
ToshibaApp.init_connection()
File "/var/www/html/plugins/toshibaac/resources/toshibaacd/toshibaconnect/toshibaac.py", line 42, in init_connection
return self.exec_async_fx(self.__async__init_connection)
File "/var/www/html/plugins/toshibaac/resources/toshibaacd/toshibaconnect/toshibaac.py", line 39, in exec_async_fx
return asyncio.run_coroutine_threadsafe(fonction(), self.loop).result()
File "/usr/lib/python3.13/concurrent/futures/_base.py", line 456, in result
return self.__get_result()
File "/usr/lib/python3.13/concurrent/futures/_base.py", line 401, in __get_result
raise self._exception
File "/var/www/html/plugins/toshibaac/resources/toshibaacd/toshibaconnect/toshibaac.py", line 51, in __async__init_connection
sas_token = await self.device_manager.connect()
File "/var/www/html/plugins/toshibaac/resources/venv/lib/python3.13/site-packages/toshiba_ac/device_manager.py", line 63, in connect
await self.http_api.connect()
File "/var/www/html/plugins/toshibaac/resources/venv/lib/python3.13/site-packages/toshiba_ac/utils/http_api.py", line 223, in connect
res = await self.request_api(self.LOGIN_PATH, post=post, headers=headers)
File "/var/www/html/plugins/toshibaac/resources/venv/lib/python3.13/site-packages/toshiba_ac/utils/__init__.py", line 131, in wrapper
return await func(*args, **kwargs)
File "/var/www/html/plugins/toshibaac/resources/venv/lib/python3.13/site-packages/toshiba_ac/utils/http_api.py", line 214, in request_api
raise ToshibaAcHttpApiError(f"HTTP {response.status} calling {path}")
toshiba_ac.utils.http_api.ToshibaAcHttpApiError: HTTP 429 calling /api/Consumer/Login
Je n’ai pas testé la béta, le changelog n’indiquant rien en rapport avec Debian 13.
Trop de connexion. OK le lendemain.
