Erreur resto sur Debian 12
Je n’arrive pas à faire une resto de mon jeedom 4.5 sur Debian 11 sur un 4.5 sur Debian 12 tout frais…
J’ai bien sur fait le tour des plugins, avant de faire la sauvegarde, mais çà coince …Log restore obtenue avec rescue=1
[START RESTORE]
***************Begin Jeedom restore 2025-03-26 12:26:23***************
Send begin restore event...OK
Checking rights...OK
Restore from file : /var/www/html/core/class/../../backup/backup-Jeedom_4.5-4.5-2025-03-26-12h22.tar.gz
Backup database access configuration...OK
Disable all task OK
Disable all scenario OK
Unpacking backup...
OK
Update composer file...
OK
[PROGRESS][58]
Deleting database...Disabling constraints...OK
Deleting table : cache ...OK
Deleting table : cmd ...OK
Deleting table : config ...OK
Deleting table : cron ...OK
Deleting table : dataStore ...OK
Deleting table : eqLogic ...OK
Deleting table : event ...OK
Deleting table : history ...OK
Deleting table : historyArch ...OK
Deleting table : interactDef ...OK
Deleting table : interactQuery ...OK
Deleting table : listener ...OK
Deleting table : message ...OK
Deleting table : note ...OK
Deleting table : object ...OK
Deleting table : plan ...OK
Deleting table : plan3d ...OK
Deleting table : plan3dHeader ...OK
Deleting table : planHeader ...OK
Deleting table : queue ...OK
Deleting table : scenario ...OK
Deleting table : scenarioElement ...OK
Deleting table : scenarioExpression ...OK
Deleting table : scenarioSubElement ...OK
Deleting table : timeline ...OK
Deleting table : update ...OK
Deleting table : user ...OK
Deleting table : view ...OK
Deleting table : viewData ...OK
Deleting table : viewZone ...OK
Deleting table : widgets ...OK
Restoring database from backup...OK
Enable back constraints...OK
Restoring cache...OK
     Restoring Plugin: calendar...OK
sudo: yarn: command not found
PHP Warning:  Trying to access array offset on value of type null in /var/www/html/core/class/system.class.php on line 423
Check jeedom consistency...[START CONSISTENCY]
[START CHECK AND FIX DB]
[END CHECK AND FIX DB]
Check jeedom package...OK
Check jeedom database...OK
Check crons...
Check filesystem right...OK
Check jeedom object...PHP Fatal error:  Uncaught TypeError: Unsupported operand types: string * int in /var/www/html/core/class/jeeObject.class.php:1101
Stack trace:
#0 /var/www/html/core/class/jeeObject.class.php(386): jeeObject->getSummary()
#1 /var/www/html/core/class/jeeObject.class.php(843): jeeObject::getGlobalSummary()
#2 /var/www/html/install/consistency.php(429): jeeObject->save()
#3 /var/www/html/install/restore.php(221): require_once('...')
#4 {main}
  thrown in /var/www/html/core/class/jeeObject.class.php on line 1101
Le fichier (+.txt)
jeeObject.class.php.txt (43,9 Ko)
J’ai toujours le même soucis de désactiver les plugins dans ce mode, c’est inopérant et j’ai toujours les doubles accolades cf ici : Migration jeedom sur VM debian 12.7 &rescue=1 - #4 par thienell
Thierry
Tu as bien installé un jeedom 4.5 vierge et pas un jeedom 4.4 (avant la resto) ?
sudo ./install.sh -v beta
Norbert
Je viens de pousser la correction en alpha. Merci pour le retour.
Yes, install neuve
Bonsoir Loic,
Je n’ai pas pu restaurer depuis la 4.5 en béta, j’ai donc passé ma VM Debian11 en Alpha > sauvegarde et injection dans la VM Debian 12 en Alpha (fraiche install).
Impec :slight_smile:
Pour info, le log :
restore.log.txt (3,0 Ko)
Thierry
