Depuis quelques temps j’ai ces messages toutes les minutes dans le log http.error. Si quelqu’un pouvait me dire comme le solutionner, ça serait sympa !
Merci d’avance
0493|[Tue Feb 07 22:51:08.956417 2023] [php7:error] [pid 15922] [client 127.0.0.1:54374] PHP Fatal error: Uncaught Exception: [MySQL] Error code : 22007 (1366). Incorrect string value: '\xE9' for column `jeedom`.`cmd`.`logicalId` at row 1 : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert in /var/www/html/core/class/DB.class.php:102
0494|Stack trace:
0495|#0 /var/www/html/core/class/DB.class.php(181): DB::Prepare('INSERT INTO `cm...', Array, 0)
0496|#1 /var/www/html/core/class/cmd.class.php(1014): DB::save(Object(espeasyCmd), false)
0497|#2 /var/www/html/plugins/espeasy/core/api/jeeEspeasy.php(69): cmd->save()
0498|#3 {main}
0499|thrown in /var/www/html/core/class/DB.class.php on line 102```
