Erreur Plugin Deconz
Depuis la dernière mise à jour Jeedom mon plugin Deconz ne fonctionne plus :
Le démon ne démarre plus et la clé conbe 2 n’est pas retrouvé.
  • La connexion à MONIPJEEDOM:8484 me dit que safari n’arrive pas à se connecter au serveur (chrome pareil)
  • J’ai réinstallé le plugin, les dépendance, puis installation local, ensuite découverte:
    ID et nom : undefined
    IP : 127.0.0.1
    Port : 8484
    Port Socket : 20877
    clé api : undefined
le log deconz instal indique :
             Installation deconz
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:3 http://www.deb-multimedia.org buster InRelease
Hit:4 http://ftp.uk.debian.org/debian buster InRelease
Hit:5 http://ftp.uk.debian.org/debian buster-updates InRelease
Hit:6 https://deb.nodesource.com/node_12.x buster InRelease
Hit:7 https://oph.mdrjr.net/meveric all InRelease
Hit:8 https://oph.mdrjr.net/meveric buster InRelease
Err:1 https://repo.jeedom.com/odroid stable InRelease
504  Gateway Time-out [IP: 51.178.69.128 443]
Reading package lists...
W: Failed to fetch http://repo.jeedom.com/odroid/dists/stable/InRelease  504  Gateway Time-out [IP: 51.178.69.128 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree...
Reading state information...
libqt5serialport5 is already the newest version (5.11.3-2).
libqt5websockets5 is already the newest version (5.11.3-5).
0 upgraded, 0 newly installed, 0 to remove and 83 not upgraded.
sqlite3 is already the newest version (3.27.2-3+deb10u1).
It's arm64, RPI
--2021-02-05 23:33:18--  https://images.jeedom.com/resources/deconz/arm64/deconz_beta.deb
Resolving images.jeedom.com (images.jeedom.com)... 51.178.69.128, 51.210.253.116
Connecting to images.jeedom.com (images.jeedom.com)|51.178.69.128|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 6135068 (5.9M) [application/x-debian-package]
Saving to: '/tmp/deconz.deb'
0K .......... .......... .......... .......... ..........  0% 1.89M 3s
50K .......... .......... .......... .......... ..........  1% 3.69M 2s
100K .......... .......... .......... .......... ..........  2% 14.3M 2s
150K .......... .......... .......... .......... ..........  3% 5.42M 1s
200K .......... .......... .......... .......... ..........  4% 14.0M 1s
250K .......... .......... .......... .......... ..........  5% 13.1M 1s
300K .......... .......... .......... .......... ..........  5% 2.37M 1s
350K .......... .......... .......... .......... ..........  6% 13.6M 1s
400K .......... .......... .......... .......... ..........  7% 14.1M 1s
450K .......... .......... .......... .......... ..........  8% 11.8M 1s
500K .......... .......... .......... .......... ..........  9% 12.7M 1s
550K .......... .......... .......... .......... .......... 10% 13.8M 1s
600K .......... .......... .......... .......... .......... 10% 13.5M 1s
650K .......... .......... .......... .......... .......... 11% 12.8M 1s
700K .......... .......... .......... .......... .......... 12% 14.0M 1s
750K .......... .......... .......... .......... .......... 13% 14.6M 1s
800K .......... .......... .......... .......... .......... 14% 13.8M 1s
850K .......... .......... .......... .......... .......... 15% 13.0M 1s
900K .......... .......... .......... .......... .......... 15% 13.9M 1s
950K .......... .......... .......... .......... .......... 16%  553K 1s
1000K .......... .......... .......... .......... .......... 17% 9.20M 1s
1050K .......... .......... .......... .......... .......... 18% 13.6M 1s
1100K .......... .......... .......... .......... .......... 19% 11.6M 1s
1150K .......... .......... .......... .......... .......... 20% 12.6M 1s
1200K .......... .......... .......... .......... .......... 20% 14.3M 1s
1250K .......... .......... .......... .......... .......... 21% 13.3M 1s
1300K .......... .......... .......... .......... .......... 22% 11.5M 1s
1350K .......... .......... .......... .......... .......... 23% 13.5M 1s
1400K .......... .......... .......... .......... .......... 24% 14.1M 1s
1450K .......... .......... .......... .......... .......... 25% 11.7M 1s
1500K .......... .......... .......... .......... .......... 25% 12.7M 1s
1550K .......... .......... .......... .......... .......... 26% 13.7M 1s
1600K .......... .......... .......... .......... .......... 27% 13.0M 1s
1650K .......... .......... .......... .......... .......... 28% 15.1M 1s
1700K .......... .......... .......... .......... .......... 29% 13.6M 1s
1750K .......... .......... .......... .......... .......... 30% 15.6M 1s
1800K .......... .......... .......... .......... .......... 30% 14.6M 1s
1850K .......... .......... .......... .......... .......... 31% 14.7M 1s
1900K .......... .......... .......... .......... .......... 32% 14.5M 1s
1950K .......... .......... .......... .......... .......... 33%  336K 1s
2000K .......... .......... .......... .......... .......... 34% 12.2M 1s
2050K .......... .......... .......... .......... .......... 35% 11.3M 1s
2100K .......... .......... .......... .......... .......... 35% 9.52M 1s
2150K .......... .......... .......... .......... .......... 36% 11.0M 1s
2200K .......... .......... .......... .......... .......... 37% 14.2M 1s
2250K .......... .......... .......... .......... .......... 38% 11.7M 1s
2300K .......... .......... .......... .......... .......... 39% 10.7M 1s
2350K .......... .......... .......... .......... .......... 40% 12.6M 1s
2400K .......... .......... .......... .......... .......... 40% 11.9M 1s
2450K .......... .......... .......... .......... .......... 41% 12.1M 1s
2500K .......... .......... .......... .......... .......... 42% 13.9M 1s
2550K .......... .......... .......... .......... .......... 43% 13.5M 1s
2600K .......... .......... .......... .......... .......... 44% 12.5M 1s
2650K .......... .......... .......... .......... .......... 45% 13.1M 1s
2700K .......... .......... .......... .......... .......... 45% 15.1M 1s
2750K .......... .......... .......... .......... .......... 46% 13.7M 1s
2800K .......... .......... .......... .......... .......... 47% 14.6M 1s
2850K .......... .......... .......... .......... .......... 48% 14.4M 1s
2900K .......... .......... .......... .......... .......... 49% 15.3M 1s
2950K .......... .......... .......... .......... .......... 50%  364K 1s
3000K .......... .......... .......... .......... .......... 50% 11.8M 1s
3050K .......... .......... .......... .......... .......... 51% 14.9M 1s
3100K .......... .......... .......... .......... .......... 52% 15.1M 1s
3150K .......... .......... .......... .......... .......... 53% 11.7M 1s
3200K .......... .......... .......... .......... .......... 54% 13.4M 1s
3250K .......... .......... .......... .......... .......... 55% 13.8M 1s
3300K .......... .......... .......... .......... .......... 55% 10.9M 1s
3350K .......... .......... .......... .......... .......... 56% 11.4M 1s
3400K .......... .......... .......... .......... .......... 57% 14.1M 0s
3450K .......... .......... .......... .......... .......... 58% 12.2M 0s
3500K .......... .......... .......... .......... .......... 59% 12.9M 0s
3550K .......... .......... .......... .......... .......... 60% 11.5M 0s
3600K .......... .......... .......... .......... .......... 60% 12.8M 0s
3650K .......... .......... .......... .......... .......... 61% 12.0M 0s
3700K .......... .......... .......... .......... .......... 62% 13.6M 0s
3750K .......... ..........
........ .......... 63% 13.0M 0s
3800K .......... .......... .......... .......... .......... 64% 14.0M 0s
3850K .......... .......... .......... .......... .......... 65% 13.6M 0s
3900K .......... .......... .......... .......... .......... 65% 7.57M 0s
3950K .......... .......... .......... .......... .......... 66%  358K 0s
4000K .......... .......... .......... .......... .......... 67% 11.0M 0s
4050K .......... .......... .......... .......... .......... 68% 14.1M 0s
4100K .......... .......... .......... .......... .......... 69% 13.8M 0s
4150K .......... .......... .......... .......... .......... 70% 10.8M 0s
4200K .......... .......... .......... .......... .......... 70% 14.0M 0s
4250K .......... .......... .......... .......... .......... 71% 14.2M 0s
4300K .......... .......... .......... .......... .......... 72% 12.1M 0s
4350K .......... .......... .......... .......... .......... 73% 13.3M 0s
4400K .......... .......... .......... .......... .......... 74% 15.1M 0s
4450K .......... .......... .......... .......... .......... 75% 13.8M 0s
4500K .......... .......... .......... .......... .......... 75% 11.0M 0s
4550K .......... .......... .......... .......... .......... 76% 13.8M 0s
4600K .......... .......... .......... .......... .......... 77% 14.4M 0s
4650K .......... .......... .......... .......... .......... 78% 13.2M 0s
4700K .......... .......... .......... .......... .......... 79% 14.4M 0s
4750K .......... .......... .......... .......... .......... 80% 14.4M 0s
4800K .......... .......... .......... .......... .......... 80% 14.4M 0s
4850K .......... .......... .......... .......... .......... 81% 15.6M 0s
4900K .......... .......... .......... .......... .......... 82% 14.7M 0s
4950K .......... .......... .......... .......... .......... 83%  340K 0s
5000K .......... .......... .......... .......... .......... 84% 14.4M 0s
5050K .......... .......... .......... .......... .......... 85% 11.8M 0s
5100K .......... .......... .......... .......... .......... 85% 15.6M 0s
5150K .......... .......... .......... .......... .......... 86% 12.5M 0s
5200K .......... .......... .......... .......... .......... 87% 12.8M 0s
5250K .......... .......... .......... .......... .......... 88% 14.4M 0s
5300K .......... .......... .......... .......... .......... 89% 13.1M 0s
5350K .......... .......... .......... .......... .......... 90% 15.5M 0s
5400K .......... .......... .......... .......... .......... 90% 11.4M 0s
5450K .......... .......... .......... .......... .......... 91% 15.6M 0s
5500K .......... .......... .......... .......... .......... 92% 13.3M 0s
5550K .......... .......... .......... .......... .......... 93% 11.1M 0s
5600K .......... .......... .......... .......... .......... 94% 15.0M 0s
5650K .......... .......... .......... .......... .......... 95% 13.7M 0s
5700K .......... .......... .......... .......... .......... 95% 14.5M 0s
5750K .......... .......... .......... .......... .......... 96% 15.6M 0s
5800K .......... .......... .......... .......... .......... 97% 14.1M 0s
5850K .......... .......... .......... .......... .......... 98% 15.1M 0s
5900K .......... .......... .......... .......... .......... 99% 14.5M 0s
5950K .......... .......... .......... .......... .         100% 15.9M=1.1s
2021-02-05 23:33:19 (5.11 MB/s) - '/tmp/deconz.deb' saved [6135068/6135068]
dpkg: warning: downgrading deconz from 2.07.01-debian-stretch-stable to 2.05.86-debian-stretch-beta
(Reading database ... 84453 files and directories currently installed.)
Preparing to unpack /tmp/deconz.deb ...
tput: unknown terminal "unknown"
Unpacking deconz (2.05.86-debian-stretch-beta) over (2.07.01-debian-stretch-stable) ...
Setting up deconz (2.05.86-debian-stretch-beta) ...
Processing triggers for mime-support (3.62) ...
Hit:2 http://www.deb-multimedia.org buster InRelease
Hit:3 http://ftp.uk.debian.org/debian buster InRelease
Hit:4 http://ftp.uk.debian.org/debian buster-updates InRelease
Hit:5 http://security.debian.org/debian-security buster/updates InRelease
             Installation terminée
J’imagine que le problème peut venir d’ici:
Err:1 Index of /odroid stable InRelease
Jeedom est en 4.1.19
Deconz avec la version de 2020-10-28 18:46:23
lsusb me donne :
Bus 001 Device 065: ID 1cf1:0030 Dresden Elektronik
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
La clé conbe fonctionne sur PC (j’ai accès à phoscon et la clé est à jour).
J’espère avoir mis assez d’information.
Merci pour votre support.
Tu l’a dit et c’est dans le log …
Juste une mise à jour de jeedom ?
Alors réinstaller les dépendances n’étaient pas nécessaires et si le démon tournait avant c’est que cette erreur n’est pas un soucis.
Mise à jour depuis quelle version ?
Une mise à jour du core ne va pas casser un plug-in.
Qu’elle autres actions ont été faites ?
J’ai mis à jour en passant par une clé USB comme demandé.
Je ne sais plus dire dans quelle « état » était le plugin mais le démon n’était plus démarré et impossible de le redémarrer.
J’ai donc fait toute les manip comme dans mon premier post.
J’ai un backup que je peux remettre mais je ne sais pas si cela va aider ?
Je ne sais pas à quoi correspond :
OK alors c’était une mise à jour de Linux surtout en plus de jeedom.
Donc oui il fallait bien relancer le dépendances.
Dans ce cas je ne sais pas dire ce qu’il manque.
P-e quelq’un ayant le plug-in pourra aider.
Ok merci quand même :+1:
Le log m’indique qu’il n’arrive pas à joindre l’adresse mais en en la tapant dans la barre de recherche je trouve bien le fichier.
Je peux télécharger le « InRelease » mais je ne sais pas où le stocker ensuite…
Une idée ?
