Erreur Migration v3 to v4
BugReport
J’ai essayé de migrer sur ma dev en v4, mais j’ai des erreur de migrations.
  1. Installation debian vierge dans VM
  2. Installation Jeedom
  3. Restauration prod dans dev
  4. Passage en v4
Page concernée : (Dashboard,scénario etc…)
Version Core :
Etape pour reproduire le Bug :
[START UPDATE]
****Update from 3.3.19 (2019-05-19 17:21:38)****
Parameters : {"preUpdate":"0","backup::before":"0","plugins":"0","core":"1","force":"0","update::reapply":""}
Send begin of update event...OK
Check rights...
OK
Disable all task.
kill: (2307): No such process
.. OK
Disable all scenario.............................
............................ OK
Téléchargement de https://api.github.com/repos/jeedom/core/zipball/beta...
OK
Cleaning folders...OK
Create temporary folder...OK
Unzip in progress...
OK
Clean temporary files (tmp)...OK
Moving files...
OK
Remove temporary files...OK
Update system into : 3.4.0...Suppression theme /var/www/html/install/update/../../core/themes/amber/Suppression theme /var/www/html/install/update/../../core/themes/blue/Suppression theme /var/www/html/install/update/../../core/themes/blue_grey/Suppression theme /var/www/html/install/update/../../core/themes/bootable/Suppression theme /var/www/html/install/update/../../core/themes/brown/Suppression theme /var/www/html/install/update/../../core/themes/cerulean/Suppression theme /var/www/html/install/update/../../core/themes/cosmo/Suppression theme /var/www/html/install/update/../../core/themes/cyan/Suppression theme /var/www/html/install/update/../../core/themes/cyborg/Suppression theme /var/www/html/install/update/../../core/themes/darkly/Suppression theme /var/www/html/install/update/../../core/themes/darksobre/Suppression theme /var/www/html/install/update/../../core/themes/deep_orange/Suppression theme /var/www/html/install/update/../../core/themes/deep_purple/Suppression theme /var/www/html/install/update/../../core/themes/flatly/Suppression theme /var/www/html/install/update/../../core/themes/green/Suppression theme /var/www/html/install/update/../../core/themes/grey/Suppression theme /var/www/html/install/update/../../core/themes/indigo/Suppression theme /var/www/html/install/update/../../core/themes/jeedom/Suppression theme /var/www/html/install/update/../../core/themes/journal/Suppression theme /var/www/html/install/update/../../core/themes/light_blue/Suppression theme /var/www/html/install/update/../../core/themes/light_green/Suppression theme /var/www/html/install/update/../../core/themes/lime/Suppression theme /var/www/html/install/update/../../core/themes/lumen/Suppression theme /var/www/html/install/update/../../core/themes/orange/Suppression theme /var/www/html/install/update/../../core/themes/paper/Suppression theme /var/www/html/install/update/../../core/themes/pink/Suppression theme /var/www/html/install/update/../../core/themes/purple/Suppression theme /var/www/html/install/update/../../core/themes/readable/Suppression theme /var/www/html/install/update/../../core/themes/red/Suppression theme /var/www/html/install/update/../../core/themes/sandstorn/Suppression theme /var/www/html/install/update/../../core/themes/simplex/Suppression theme /var/www/html/install/update/../../core/themes/slate/Suppression theme /var/www/html/install/update/../../core/themes/spacelab/Suppression theme /var/www/html/install/update/../../core/themes/superhero/Suppression theme /var/www/html/install/update/../../core/themes/teal/Suppression theme /var/www/html/install/update/../../core/themes/united/Suppression theme /var/www/html/install/update/../../core/themes/yellow/Suppression theme /var/www/html/install/update/../../core/themes/yeti/OK
Update system into : 4.0.1...
OK
Update system into : 4.0.2...
PHP Notice:  Accessing static property ttsWebServer::$_whatLog as non static in /var/www/html/plugins/ttsWebServer/core/class/ttsWebServer.class.php on line 246
PHP Fatal error:  Uncaught Error: Call to a member function add() on null in /var/www/html/plugins/ttsWebServer/core/class/ttsWebServer.class.php:247
Stack trace:
#0 /var/www/html/core/class/DB.class.php(140): ttsWebServer->preSave()
#1 /var/www/html/core/class/eqLogic.class.php(921): DB::save(Object(ttsWebServer), false)
#2 /var/www/html/install/update/4.0.2.php(19): eqLogic->save()
#3 /var/www/html/install/update/4.0.2.php(27): replaceAndSaveFA5(Array)
#4 {main}
thrown in /var/www/html/plugins/ttsWebServer/core/class/ttsWebServer.class.php on line 247
OK
Update system into : 4.0.3...
Copy widget of plugin widget to jeedom custom widget dir...OK
Check jeedom consistency...[START CONSISTENCY]
[START CHECK AND FIX DB]
Fix : ALTER TABLE `cmd` DROP INDEX `unique`;
Fix : ALTER TABLE `cmd` DROP INDEX `isHistorized`;
Fix : ALTER TABLE `cmd` DROP INDEX `type`;
Fix : ALTER TABLE `cmd` DROP INDEX `name`;
Fix : ALTER TABLE `cmd` DROP INDEX `subtype`;
Fix : ALTER TABLE `cmd` DROP INDEX `eqLogic_id`;
Fix : ALTER TABLE `cmd` DROP INDEX `value`;
Fix : ALTER TABLE `cmd` DROP INDEX `order`;
Fix : ALTER TABLE `cmd` DROP INDEX `logicalID`;
Fix : ALTER TABLE `cmd` DROP INDEX `logicalId_eqLogicID`;
Fix : ALTER TABLE `cmd` MODIFY COLUMN `logicalId`  varchar(255) NULL
Fix : ALTER TABLE `cmd` DROP `html`
Fix :
CREATE UNIQUE INDEX `unique` ON `cmd` (`eqLogic_id` ASC,`name` ASC)
Fix :
CREATE INDEX `isHistorized` ON `cmd` (`isHistorized` ASC)
Fix :
CREATE INDEX `type` ON `cmd` (`type` ASC)
Fix :
CREATE INDEX `name` ON `cmd` (`name` ASC)
Fix :
CREATE INDEX `subtype` ON `cmd` (`subType` ASC)
Fix :
CREATE INDEX `eqLogic_id` ON `cmd` (`eqLogic_id` ASC)
Fix :
CREATE INDEX `value` ON `cmd` (`value` ASC)
Fix :
CREATE INDEX `order` ON `cmd` (`order` ASC)
Fix :
CREATE INDEX `logicalID` ON `cmd` (`logicalId` ASC)
Fix :
CREATE INDEX `logicalId_eqLogicID` ON `cmd` (`eqLogic_id` ASC,`logicalId` ASC)
Fix : ALTER TABLE `interactDef` ADD `display` text NULL
Fix : ALTER TABLE `plan3dHeader` ADD `order` int(11) NULL
Fix : CREATE INDEX `order` ON `plan3dHeader` (`order` ASC)
Fix : ALTER TABLE `planHeader` ADD `order` int(11) NULL
Fix : CREATE INDEX `order` ON `planHeader` (`order` ASC)
Fix : ALTER TABLE `scenario` DROP `type`
Fix : CREATE TABLE IF NOT EXISTS `widgets` (
`id` int(11) NOT NULL AUTO_INCREMENT,
`name` varchar(255) NOT NULL,
`type` varchar(27) NULL,
`subtype` varchar(27) NULL,
`template` varchar(255) NULL,
`display` text NULL,
`replace` text NULL,
`test` text NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE UNIQUE INDEX `unique` ON `widgets` (`type` ASC,`subtype` ASC,`name` ASC)[END CHECK AND FIX DB]
Check jeedom database...OK
Create plugin::cron10
Check filesystem right...
OK
PHP Fatal error:  Uncaught Error: Call to undefined function cleanComponanteName() in /var/www/html/core/class/cmd.class.php:2054
Stack trace:
#0 /var/www/html/plugins/virtual/core/class/virtual.class.php(238): cmd->setName('Sc\xC3\xA9nario Chauf...')
#1 /var/www/html/core/class/DB.class.php(144): virtualCmd->preSave()
#2 /var/www/html/core/class/cmd.class.php(939): DB::save(Object(virtualCmd))
#3 /var/www/html/install/consistency.php(401): cmd->save()
#4 /var/www/html/install/update.php(348): require_once('/var/www/html/i...')
#5 {main}
thrown in /var/www/html/core/class/cmd.class.php on line 2054
Relance juste la mise a jour en forcé et ça sera bon.
