Je viens de passer le core de la version 3.1.7 en 3.3.45
Au redémarrage, plus de com des sensors, les dependances mysensors ne s’installent pas:
Début de l'installation
converted 'https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh' (ANSI_X3.4-1968) -> 'https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh' (UTF-8)
--2020-04-11 15:29:03-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.120.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.120.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1491 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 1.13M=0.001s
2020-04-11 15:29:03 (1.13 MB/s) - 'dependencies.sh' saved [1491/1491]
dependencies.sh: 3: [: mySensors: unexpected operator
Nodejs non installé
Ign http://ftp.debian.org jessie InRelease
Hit http://ftp.debian.org jessie-updates InRelease
Hit http://security.debian.org jessie/updates InRelease
Hit http://apt.osmc.tv jessie InRelease
Hit https://deb.nodesource.com jessie InRelease
Hit http://ftp.debian.org jessie Release.gpg
Hit http://ftp.debian.org jessie-updates/main armhf Packages
Hit http://security.debian.org jessie/updates/main armhf Packages
Hit http://ftp.debian.org jessie-updates/contrib armhf Packages
Hit http://security.debian.org jessie/updates/contrib armhf Packages
Hit http://security.debian.org jessie/updates/non-free armhf Packages
Hit http://security.debian.org jessie/updates/contrib Translation-en
Hit http://ftp.debian.org jessie-updates/non-free armhf Packages
Hit http://security.debian.org jessie/updates/main Translation-en
Hit http://ftp.debian.org jessie-updates/contrib Translation-en
Hit http://security.debian.org jessie/updates/non-free Translation-en
Hit http://ftp.debian.org jessie-updates/main Translation-en
Hit http://ftp.debian.org jessie-updates/non-free Translation-en
Get:1 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
Hit https://deb.nodesource.com jessie/main Sources
Hit https://deb.nodesource.com jessie/main armhf Packages
Get:2 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:3 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:4 https://deb.nodesource.com jessie/main Translation-en [162 B]
Hit http://ftp.debian.org jessie/main armhf Packages
Get:5 https://deb.nodesource.com jessie/main Translation-en [162 B]
Hit http://ftp.debian.org jessie/contrib armhf Packages
Get:6 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en
Hit http://ftp.debian.org jessie/non-free armhf Packages
Hit http://ftp.debian.org jessie/contrib Translation-en
Ign http://apt.osmc.tv jessie/main Translation-en
Hit http://ftp.debian.org jessie/main Translation-en
Hit http://ftp.debian.org jessie/non-free Translation-en
Fetched 2023 B in 10s (200 B/s)
Reading package lists...
W: There is no public key available for the following key IDs:
AA8E81B4331F7F50
Building dependency tree...
Reading state information...
lsb-release is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 329 not upgraded.
KO, version obsolète à upgrader
Suppression du Nodejs existant et installation du paquet recommandé
Package 'npm' is not installed, so not removed
Package 'nodejs' is not installed, so not removed
dependencies.sh: 37: [: armv7l: unexpected operator
Utilisation du dépot officiel
## Installing the NodeSource Node.js 12.x repo...
## Populating apt-get cache...
+ apt-get update
Get:1 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:6 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
Fetched 2023 B in 8s (226 B/s)
AA8E81B4331F7F50
## You seem to be using Devuan version jessie.
## This maps to Debian "jessie"... Adjusting for you...
## Confirming "jessie" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/jessie/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
OK
## Creating apt sources list file for the NodeSource Node.js 12.x repo...
+ echo 'deb https://deb.nodesource.com/node_12.x jessie main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src https://deb.nodesource.com/node_12.x jessie main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
Get:5 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
Fetched 2023 B in 9s (224 B/s)
AA8E81B4331F7F50
## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nodejs : Depends: libstdc++6 (>= 5.2) but 4.9.2-10 is to be installed
E: Unable to correct problems, you have held broken packages.
dependencies.sh: 1: dependencies.sh: nodejs: not found
Version actuelle :
dependencies.sh: 59: dependencies.sh: npm: not found
chown: cannot access 'node_modules': No such file or directory
rm: cannot remove '/tmp/mySensors_dep': No such file or directory
Fin de l'installation
Merci pour votre aide
