Je me permet de rebondir sur ce fil de discussion, j’ai le même soucis. Malgrè plusieur tentative, les dépendances ne s’installe pas. Du coup pour un plugin que je viens d’acheter je ne peut rien en faire. Pas glop.
Je suis sous freebox Delta en machine virtuelle. Voici le log pour une tentative d’install. Il semble manquer pas mal de chose…
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/math/fround/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/math/hypot/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/math/imul/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/math/log10/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/math/log1p/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/math/log2/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/math/sign/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/math/sinh/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/math/tanh/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/math/trunc/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/number/is-finite/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/number/is-integer/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/number/is-nan/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/number/is-safe-integer/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/assign/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/entries/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/keys/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/set-prototype-of/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/promise/#/finally/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/reg-exp/#/match/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/reg-exp/#/replace/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/reg-exp/#/search/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/reg-exp/#/split/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/string/#/@@iterator/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/string/#/code-point-at/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/string/#/contains/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/string/#/ends-with/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/string/#/normalize/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/string/#/repeat/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/string/#/starts-with/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/string/from-code-point/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/string/raw/shim.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/array/#/some-right.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/array/#/some-right.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/object/some.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/some.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/function/#/spread.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/function/#/spread.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/error/#/throw.js'
npm WARN tar ENOENT: no such file or directory, lstat '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/error/#'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/array/to-array.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/object/to-array.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/array/to-array.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/to-array.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/number/to-integer.js'
npm WARN tar ENOENT: no such file or directory, lstat '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/number'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/number/to-pos-integer.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/to-short-string-representation.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/to-short-string-representation.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/function/#/to-string-tokens.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/function/#/to-string-tokens.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/number/to-uint32.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/string/#/uncapitalize.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/string/#/uncapitalize.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/array/#/uniq.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/array/#/uniq.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/object/unserialize.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/unserialize.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/array/valid-array.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/array/valid-array.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/object/valid-callable.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/valid-callable.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/date/valid-date.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/date/valid-date.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/error/valid-error.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/error/valid-error.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/function/valid-function.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/function/valid-function.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/object/valid-object.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/valid-object.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/reg-exp/valid-reg-exp.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/reg-exp/valid-reg-exp.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/object/valid-value.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/valid-value.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/object/validate-array-like-object.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/validate-array-like-object.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/object/validate-array-like.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/validate-array-like.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/iterable/validate-object.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/iterable/validate-object.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/object/validate-stringifiable-value.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/validate-stringifiable-value.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/object/validate-stringifiable.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/object/validate-stringifiable.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/iterable/validate.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/iterable/validate.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/promise/.eslintrc.json'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/.eslintrc.json'
npm WARN tar ENOENT: no such file or directory, lstat '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/test/promise'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/package.json'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/CHANGELOG.md'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/node_modules/.staging/es5-ext-1b8ab9cd/README.md'
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2020-11-05T20_09_30_752Z-debug.log
--70%
npm WARN saveError ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/package.json'
npm WARN enoent ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/resources/package.json'
npm WARN resources No description
npm WARN resources No repository field.
npm WARN resources No README data
npm WARN resources No license field.
+ express@4.17.1
added 50 packages from 37 contributors in 3.634s
--80%
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
+ request@2.88.2
added 43 packages from 52 contributors in 3.912s
--90%
--95%
--100%
Installation des dépendances eWeJee terminée, vérifiez qu'il n'y a pas d'erreur
mv: inter-device move failed: '/tmp/jeedom/ewejee' to '/var/www/html/plugins/ewejee/log/ewejee'; unable to remove target: Directory not empty
