Erreur depuis mise à jour UniFi OS 5.1.15
J’ai fait la mise à jour UniFi OS 5.1.12 –> 5.1.15 hier sur un UDR7 et un UDR5GMax. Depuis, j’ai certaines fonctions du plugin unifi qui fonctionnent toujours, et d’autres qui ne fonctionnent plus. En particulier, j’utilise le plugin pour mettre en pause mon wifi la nuit. Ca ne fonctionne plus.
Voilà l’erreur dans la log unifi en mode debug :
[2026-06-05 08:28:52] DEBUG  syncUniFi manuelle :all
[2026-06-05 08:28:52] INFO  syncUniFi
[2026-06-05 08:28:52] DEBUG  avec params : all
[2026-06-05 08:28:52] DEBUG  CustomApiRequest...
[2026-06-05 08:28:52] DEBUG  CustomApiRequest brut : {"result":"ko","msg":{"message":"Request failed with status code 401","name":"AxiosError","stack":"AxiosError: Request failed with status code 401\n    at settle (/var/www/html/plugins/unifi/resources/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:1967:12)\n    at IncomingMessage.handleStreamEnd (/var/www/html/plugins/unifi/resources/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:3062:11)\n    at IncomingMessage.emit (node:events:531:35)\n    at endReadableNT (node:internal/streams/readable:1698:12)\n    at process.processTicksAndRejections (node:internal/process/task_queues:89:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":5000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","x-csrf-token":"71cc6a14-088d-4d10-ab3a-20a34547ab88","User-Agent":"axios/1.6.2","Accept-Encoding":"gzip, compress, deflate, br"},"httpAgent":{"_events":{},"_eventsCount":2,"options":{"cookies":{"jar":{"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"TOKEN","expires":"1970-01-01T00:00:00.000Z","domain":"192.168.1.1","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2026-06-05T06:28:52.738Z","lastAccessed":"2026-06-05T06:28:52.738Z","sameSite":"none"}]}},"noDelay":true,"path":null},"defaultPort":80,"protocol":"http:","requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"agentKeepAliveTimeoutBuffer":1000},"httpsAgent":{"_events":{},"_eventsCount":2,"options":{"cookies":{"jar":{"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"TOKEN","expires":"1970-01-01T00:00:00.000Z","domain":"192.168.1.1","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2026-06-05T06:28:52.738Z","lastAccessed":"2026-06-05T06:28:52.738Z","sameSite":"none"}]}},"rejectUnauthorized":false,"requestCert":true,"defaultPort":443,"protocol":"https:","noDelay":true,"path":null},"defaultPort":443,"protocol":"https:","requests":{},"sockets":{"192.168.1.1:443::::::::false:::::::::::::":[{"_tlsOptions":{"pipe":false,"secureContext":{"context":{}},"isServer":false,"requestCert":true,"rejectUnauthorized":false,"session":{"type":"Buffer","data":[48,130,3,235,2,1,1,2,2,3,4,4,2,19,2,4,32,47,184,150,127,219,27,216,57,95,156,24,152,0,89,196,184,49,74,84,92,107,0,65,40,196,149,43,177,150,38,41,234,4,48,193,230,206,76,217,85,17,18,4,106,147,138,39,235,250,114,145,113,233,70,29,3,190,238,14,137,207,80,197,137,189,106,50,232,56,11,215,38,177,95,61,58,164,200,31,108,105,210,161,6,2,4,106,34,108,164,162,4,2,2,28,32,163,130,3,57,48,130,3,53,48,130,2,29,160,3,2,1,2,2,9,117,0,129,113,161,190,76,110,45,48,13,6,9,42,134,72,134,247,13,1,1,11,5,0,48,22,49,20,48,18,6,3,85,4,3,19,11,117,110,105,102,105,46,108,111,99,97,108,48,30,23,13,50,54,48,52,49,49,49,52,48,54,49,53,90,23,13,50,56,48,55,49,52,49,52,48,54,49,53,90,48,22,49,20,48,18,6,3,85,4,3,19,11,117,110,105,102,105,46,108,111,99,97,108,48,130,1,34,48,13,6,9,42,134,72,134,247,13,1,1,1,5,0,3,130,1,15,0,48,130,1,10,2,130,1,1,0,188,207,146,2,122,79,74,221,135,228,107,215,204,52,135,208,51,4,128,164,45,132,124,206,193,122,30,130,73,225,156,218,247,201,138,167,3,144,67,61,232,247,144,230,44,30,21,119,96,15,44,85,153,237,109,94,116,19,20,102,79,55,90,68,54,12,237,84,102,80,159,218,230,230,104,238,40,119,243,176,203,165,64,67,139,246,244,187,53,59,96,86,150,22,158,193,247,82,102,36,112,133,166,26,23,32,4,186,241,177,194,153,2,47,25,51,63,121,174,109,46,254,182,196,218,35,120,54,90,95,25,25,218,203,225,53,230,183,65,219,88,83,54,98,172,97,3,28,104,246,209,121,201,109,243,86,58,86,168,192,95,103,237,27,148,188,171,247,193,165,171,97,227,126,35,204,125,92,99,61,38,11,98,19,60,133,108,119,219,24,226,177,121,71,85,59,141,57,148,24,253,19,7,224,5,167,16,4,91,120,221,38,114,66,69,43,16,151,210,53,143,188,179,235,245,152,26,107,150,163,148,156,109,138,62,166,100,94,97,94,218,167,156,111,31,105,88,67,102,41,117,202,217,102,130,165,2,3,1,0,1,163,129,133,48,129,130,48,11,6,3,85,29,15,4,4,3,2,2,244,48,49,6,3,85,29,37,4,42,48,40,6,8,43,6,1,5,5,7,3,1,6,8,43,6,1,5,5,7,3,2,6,8,43,6,1,5,5,7,3,3,6,8,43,6,1,5,5,7,3,8,48,64,6,3,85,29,17,4,57,48,55,130,11,117,110,105,102,105,46,108,111,99,97,108,130,9,108,111,99,97,108,104,111,115,116,130,5,91,58,58,49,93,135,4,127,0,0,1,135,16,254,128,0,0,0,0,0,0,0,0,0,0,0,0,0,1,48,13,6,9,42,134,72,134,247,13,1,1,11,5,0,3,130,1,1,0,159,20,254,98,21,1,165,225,169,91,129,60,80,108,246,63,123,2,101,29,97,11,32,3,114,229,48,43,186,32,236,8,26,87,205,110,97,247,250,32,54,151,238,210,19,139,59,44,58,129,228,193,36,234,161,172,103,232,253,32,187,68,113,219,127,195,252,134,37,22,94,76,53,36,177,43,171,239,149,100,37,204,99,203,141,85,126,151,58,180,157,133,58,137,96,101,38,250,156,157,84,69,89,143,154,174,80,116,224,205,59,110,203,151,170,223,149,173,223,193,25,103,22,78,6,73,83,255,106,117,152,104,40,10,4,222,113,75,188,64,210,103,231,238,250,71,127,200,168,38,195,0,78,160,47,215,179,213,67,128,148,76,205,47,84,75,90,100,104,13,246,87,171,32,149,235,181,234,150,183,73,12,133,167,127,32,17,57,14,15,6,143,25,137,34,210,249,108,17,158,70,161,222,112,215,123,19,21,141,161,63,48,20,66,244,21,140,168,80,110,148,71,146,241,125,245,144,245,139,78,72,231,183,96,162,112,235,88,88,96,74,231,50,114,191,14,165,29,87,180,188,218,61,46,78,235,164,2,4,0,165,3,2,1,18,169,4,2,2,36,45,170,34,4,32,126,47,26,69,182,140,118,31,78,154,153,46,22,155,172,124,3,79,184,237,52,75,240,120,191,142,147,254,225,124,216,192,174,7,2,5,0,192,102,133,193,179,3,2,1,29]}},"_secureEstablished":true,"_securePending":false,"_newSessionPending":false,"_controlReleased":true,"secureConnecting":false,"_SNICallback":null,"servername":false,"alpnProtocol":false,"authorized":false,"authorizationError":"DEPTH_ZERO_SELF_SIGNED_CERT","encrypted":true,"_events":{"close":[null,null,null,null],"timeout":[null,null]},"_eventsCount":10,"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_closeAfterHandlingError":false,"_readableState":{"highWaterMark":65536,"buffer":[],"bufferIndex":0,"length":0,"pipes":[],"awaitDrainWriters":null},"_writableState":{"highWaterMark":65536,"length":0,"corked":0,"writelen":0,"bufferedIndex":0,"pendingcb":1},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","_server":null,"ssl":{"_parent":{"reading":true,"onconnection":null},"_parentWrap":null,"_secureContext":{"context":{}},"reading":true},"_requestCert":true,"_rejectUnauthorized":false,"parser":null,"_httpMessage":{"_events":{},"_eventsCount":7,"outputData":[],"outputSize":0,"writable":true,"destroyed":false,"_last":true,"chunkedEncoding":false,"shouldKeepAlive":false,"maxRequestsOnConnectionReached":false,"_defaultKeepAlive":true,"useChunkedEncodingByDefault":false,"sendDate":false,"_removedConnection":false,"_removedContLen":false,"_removedTE":false,"strictContentLength":false,"_contentLength":0,"_hasBody":true,"_trailer":"","finished":true,"_headerSent":true,"_closed":false,"_header":"GET /proxy/network/v2/api/site/default/models HTTP/1.1\r\nAccept: application/json, text/plain, */*\r\nx-csrf-token: 71cc6a14-088d-4d10-ab3a-20a34547ab88\r\nUser-Agent: axios/1.6.2\r\nAccept-Encoding: gzip, compress, deflate, br\r\nHost: 192.168.1.1\r\nConnection: close\r\n\r\n","_keepAliveTimeout":0,"method":"GET","path":"/proxy/network/v2/api/site/default/models","_ended":true,"res":{"_events":{"end":[null,null]},"_readableState":{"highWaterMark":65536,"buffer":[],"bufferIndex":0,"length":0,"pipes":[],"awaitDrainWriters":null},"httpVersionMajor":1,"httpVersionMinor":1,"httpVersion":"1.1","complete":true,"rawHeaders":["Server","nginx","Date","Fri, 05 Jun 2026 06:28:52 GMT","Content-Type","application/json","Content-Length","47","Connection","close","Referrer-Policy","no-referrer","Strict-Transport-Security","max-age=15552000; includeSubDomains","X-Content-Type-Options","nosniff","X-DNS-Prefetch-Control","off","X-Frame-Options","SAMEORIGIN","X-XSS-Protection","1; mode=block","X-Robots-Tag","noindex","Set-Cookie","TOKEN=; path=/; expires=Thu, 01 Jan 1970 00:00:00 GMT; samesite=none; secure; httponly; partitioned","Set-Cookie","TOKEN=; path=/; expires=Thu, 01 Jan 1970 00:00:00 GMT; samesite=none; secure; httponly"],"rawTrailers":[],"aborted":false,"upgrade":false,"url":"","method":null,"statusCode":401,"statusMessage":"Unauthorized","_consuming":false,"_dumped":false,"_eventsCount":4,"responseUrl":"https://192.168.1.1/proxy/network/v2/api/site/default/models","redirects":[]},"aborted":false,"timeoutCb":null,"upgradeOrConnect":false,"parser":null,"maxHeadersCount":null,"reusedSocket":false,"host":"192.168.1.1","protocol":"https:","_redirectable":{"_events":{"socket":[null,null]},"_writableState":{"highWaterMark":65536,"length":0,"corked":0,"writelen":0,"bufferedIndex":0,"pendingcb":0},"_options":{"maxRedirects":21,"maxBodyLength":null,"protocol":"https:","path":"/proxy/network/v2/api/site/default/models","method":"GET","headers":{"Accept":"application/json, text/plain, */*","x-csrf-token":"71cc6a14-088d-4d10-ab3a-20a34547ab88","User-Agent":"axios/1.6.2","Accept-Encoding":"gzip, compress, deflate, br"},"agents":{"http":{"_events":{},"_eventsCount":2,"options":{"cookies":{"jar":{"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"TOKEN","expires":"1970-01-01T00:00:00.000Z","domain":"192.168.1.1","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2026-06-05T06:28:52.738Z","lastAccessed":"2026-06-05T06:28:52.738Z","sameSite":"none"}]}},"noDelay":true,"path":null},"defaultPort":80,"protocol":"http:","requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"agentKeepAliveTimeoutBuffer":1000}},"beforeRedirects":{},"hostname":"192.168.1.1","port":"","nativeProtocols":{"http:":{"METHODS":["ACL","BIND","CHECKOUT","CONNECT","COPY","DELETE","GET","HEAD","LINK","LOCK","M-SEARCH","MERGE","MKACTIVITY","MKCALENDAR","MKCOL","MOVE","NOTIFY","OPTIONS","PATCH","POST","PROPFIND","PROPPATCH","PURGE","PUT","QUERY","REBIND","REPORT","SEARCH","SOURCE","SUBSCRIBE","TRACE","UNBIND","UNLINK","UNLOCK","UNSUBSCRIBE"],"STATUS_CODES":{"100":"Continue","101":"Switching Protocols","102":"Processing","103":"Early Hints","200":"OK","201":"Created","202":"Accepted","203":"Non-Authoritative Information","204":"No Content","205":"Reset Content","206":"Partial Content","207":"Multi-Status","208":"Already Reported","226":"IM Used","300":"Multiple Choices","301":"Moved Permanently","302":"Found","303":"See Other","304":"Not Modified","305":"Use Proxy","307":"Temporary Redirect","308":"Permanent Redirect","400":"Bad Request","401":"Unauthorized","402":"Payment Required","403":"Forbidden","404":"Not Found","405":"Method Not Allowed","406":"Not Acceptable","407":"Proxy Authentication Required","408":"Request Timeout","409":"Conflict","410":"Gone","411":"Length Required","412":"Precondition Failed","413":"Payload Too Large","414":"URI Too Long","415":"Unsupported Media Type","416":"Range Not Satisfiable","417":"Expectation Failed","418":"I'm a Teapot","421":"Misdirected Request","422":"Unprocessable Entity","423":"Locked","424":"Failed Dependency","425":"Too Early","426":"Upgrade Required","428":"Precondition Required","429":"Too Many Requests","431":"Request Header Fields Too Large","451":"Unavailable For Legal Reasons","500":"Internal Server Error","501":"Not Implemented","502":"Bad Gateway","503":"Service Unavailable","504":"Gateway Timeout","505":"HTTP Version Not Supported","506":"Variant Also Negotiates","507":"Insufficient Storage","508":"Loop Detected","509":"Bandwidth Limit Exceeded","510":"Not Extended","511":"Network Authentication Required"},"maxHeaderSize":16384,"globalAgent":{"_events":{},"_eventsCount":2,"options":{"keepAlive":true,"scheduling":"lifo","timeout":5000,"noDelay":true,"path":null},"defaultPort":80,"protocol":"http:","requests":{},"sockets":{},"freeSockets":{"192.168.1.30:80:":[{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_closeAfterHandlingError":false,"_events":{"timeout":[null,null]},"_readableState":{"highWaterMark":65536,"buffer":[],"bufferIndex":0,"length":0,"pipes":[],"awaitDrainWriters":null},"_writableState":{"highWaterMark":65536,"length":0,"corked":0,"writelen":0,"bufferedIndex":0,"pendingcb":0},"allowHalfOpen":false,"_eventsCount":6,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null,"timeout":4000,"parser":null,"_httpMessage":null}]},"keepAliveMsecs":1000,"keepAlive":true,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":1,"agentKeepAliveTimeoutBuffer":1000}},"https:":{"globalAgent":{"_events":{},"_eventsCount":2,"options":{"keepAlive":true,"scheduling":"lifo","timeout":5000,"defaultPort":443,"protocol":"https:","noDelay":true,"path":null},"defaultPort":443,"protocol":"https:","requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":true,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"agentKeepAliveTimeoutBuffer":1000,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}}},"pathname":"/proxy/network/v2/api/site/default/models"},"_ended":true,"_ending":true,"_redirectCount":0,"_redirects":[],"_requestBodyLength":0,"_requestBodyBuffers":[],"_eventsCount":3,"_currentUrl":"https://192.168.1.1/proxy/network/v2/api/site/default/models","_timeout":null}},"timeout":5000}]},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":1,"agentKeepAliveTimeoutBuffer":1000,"maxCachedSessions":100,"_sessionCache":{"map":{"192.168.1.1:443::::::::false:::::::::::::":{"type":"Buffer","data":[48,130,3,235,2,1,1,2,2,3,4,4,2,19,2,4,32,183,150,99,126,185,76,223,63,229,175,52,17,193,197,90,35,28,125,94,16,84,99,25,33,253,92,253,68,25,83,128,236,4,48,12,150,154,143,110,133,239,149,59,214,145,61,103,167,84,241,52,20,33,219,128,146,193,175,19,176,54,67,137,197,103,164,163,5,222,169,195,88,102,169,162,204,12,168,149,214,215,192,161,6,2,4,106,34,108,164,162,4,2,2,28,32,163,130,3,57,48,130,3,53,48,130,2,29,160,3,2,1,2,2,9,117,0,129,113,161,190,76,110,45,48,13,6,9,42,134,72,134,247,13,1,1,11,5,0,48,22,49,20,48,18,6,3,85,4,3,19,11,117,110,105,102,105,46,108,111,99,97,108,48,30,23,13,50,54,48,52,49,49,49,52,48,54,49,53,90,23,13,50,56,48,55,49,52,49,52,48,54,49,53,90,48,22,49,20,48,18,6,3,85,4,3,19,11,117,110,105,102,105,46,108,111,99,97,108,48,130,1,34,48,13,6,9,42,134,72,134,247,13,1,1,1,5,0,3,130,1,15,0,48,130,1,10,2,130,1,1,0,188,207,146,2,122,79,74,221,135,228,107,215,204,52,135,208,51,4,128,164,45,132,124,206,193,122,30,130,73,225,156,218,247,201,138,167,3,144,67,61,232,247,144,230,44,30,21,119,96,15,44,85,153,237,109,94,116,19,20,102,79,55,90,68,54,12,237,84,102,80,159,218,230,230,104,238,40,119,243,176,203,165,64,67,139,246,244,187,53,59,96,86,150,22,158,193,247,82,102,36,112,133,166,26,23,32,4,186,241,177,194,153,2,47,25,51,63,121,174,109,46,254,182,196,218,35,120,54,90,95,25,25,218,203,225,53,230,183,65,219,88,83,54,98,172,97,3,28,104,246,209,121,201,109,243,86,58,86,168,192,95,103,237,27,148,188,171,247,193,165,171,97,227,126,35,204,125,92,99,61,38,11,98,19,60,133,108,119,219,24,226,177,121,71,85,59,141,57,148,24,253,19,7,224,5,167,16,4,91,120,221,38,114,66,69,43,16,151,210,53,143,188,179,235,245,152,26,107,150,163,148,156,109,138,62,166,100,94,97,94,218,167,156,111,31,105,88,67,102,41,117,202,217,102,130,165,2,3,1,0,1,163,129,133,48,129,130,48,11,6,3,85,29,15,4,4,3,2,2,244,48,49,6,3,85,29,37,4,42,48,40,6,8,43,6,1,5,5,7,3,1,6,8,43,6,1,5,5,7,3,2,6,8,43,6,1,5,5,7,3,3,6,8,43,6,1,5,5,7,3,8,48,64,6,3,85,29,17,4,57,48,55,130,11,117,110,105,102,105,46,108,111,99,97,108,130,9,108,111,99,97,108,104,111,115,116,130,5,91,58,58,49,93,135,4,127,0,0,1,135,16,254,128,0,0,0,0,0,0,0,0,0,0,0,0,0,1,48,13,6,9,42,134,72,134,247,13,1,1,11,5,0,3,130,1,1,0,159,20,254,98,21,1,165,225,169,91,129,60,80,108,246,63,123,2,101,29,97,11,32,3,114,229,48,43,186,32,236,8,26,87,205,110,97,247,250,32,54,151,238,210,19,139,59,44,58,129,228,193,36,234,161,172,103,232,253,32,187,68,113,219,127,195,252,134,37,22,94,76,53,36,177,43,171,239,149,100,37,204,99,203,141,85,126,151,58,180,157,133,58,137,96,101,38,250,156,157,84,69,89,143,154,174,80,116,224,205,59,110,203,151,170,223,149,173,223,193,25,103,22,78,6,73,83,255,106,117,152,104,40,10,4,222,113,75,188,64,210,103,231,238,250,71,127,200,168,38,195,0,78,160,47,215,179,213,67,128,148,76,205,47,84,75,90,100,104,13,246,87,171,32,149,235,181,234,150,183,73,12,133,167,127,32,17,57,14,15,6,143,25,137,34,210,249,108,17,158,70,161,222,112,215,123,19,21,141,161,63,48,20,66,244,21,140,168,80,110,148,71,146,241,125,245,144,245,139,78,72,231,183,96,162,112,235,88,88,96,74,231,50,114,191,14,165,29,87,180,188,218,61,46,78,235,164,2,4,0,165,3,2,1,18,169,4,2,2,36,45,170,34,4,32,59,61,244,198,190,228,152,149,22,119,99,117,255,33,99,210,202,197,199,71,81,31,70,43,171,34,110,196,101,104,167,66,174,7,2,5,0,240,192,149,142,179,3,2,1,29]}},"list":["192.168.1.1:443::::::::false:::::::::::::"]}},"url":"https://192.168.1.1/proxy/network/v2/api/site/default/models","method":"get","data":null},"code":"ERR_BAD_REQUEST","status":401}}
Est-ce qu’il suffit de faire une réparation de NodeJS ? Au faut-il attendre une mise à jour du plugin ?
Merci, cordialement,
M9
bonjour,
il me propose pas encore la 5.1.15, je suis en 5.1.12 donc il faudra attendre, sinon repassez en 5.1.12
la procédure pour revenir en arrière est chez eux, certains dans les commentaires disent qu’il est pas stable
https://community.ui.com/releases/UniFi-OS-Cloud-Gateways-5-1-15/37aeb9f3-c3a2-474d-ac9a-aa2ec7ecf417?reply=1
je viens de retirer l’auto-update chez moi du coup… on verra avec les autres retours dans les jours à venir…
sinon pour votre fonction particulière qui ne fonctionne plus, vous utilisez quelle commande exactement ? vous pourriez donner le log unif_daemon plutot ?
Désolé, mais je ne trouve pas de log correspondant au démon unifi. Dans la liste des logs accessibles (Analyse-Logs) il y a unifi ou unifi_dep seulement.
Concernant la commande que j’utilise, il s’agit des commandes « activer » et « désactiver » d’un objet de la partie « Mes Wifis » dans le plugin UniFi.
Cordialement,
M9
Alors une autre information intéressante. Depuis la mise à jour d’UniFi OS, je n’avais pas redémarré le démon unifi de Jeedom. Je viens de le faire et tout semble finalement revenu dans l’ordre. Je parviens à nouveau à éteindre et allumer mon réseau wifi avec une télécommande en RFXCom.
