Est-ce que quelqu’un a remarqué des soucis vers les serveurs Somfy les temps-ci ?
Parfois lors de commandes j’ai :
[2021-11-03 08:00:18][DEBUG] : send command up to io://1237-7252-1660/5254378
[2021-11-03 08:00:18][DEBUG] : {"label":"up","actions":[{"deviceURL":"io:\/\/1237-7252-1660\/5254378","commands":[{"name":"up"}]}]}
[2021-11-03 08:00:18][DEBUG] : send command: ko: 401. Will retry
[2021-11-03 08:00:18][DEBUG] : logon with xxx and cookie /tmp/tahomacurlcookie
[2021-11-03 08:00:28][DEBUG] : new cookie - logon: ko: 401()
[2021-11-03 08:00:28][DEBUG] : return: HTTP/1.1 401 Date: Wed, 03 Nov 2021 07:00:27 GMT Server: overkiz Strict-Transport-Security: max-age=31536000; includeSubDomains Content-Type: application/json;charset=UTF-8 Transfer-Encoding: chunked {"errorCode":"AUTHENTICATION_ERROR","error":"Bad credentials"}
[2021-11-03 08:00:28][DEBUG] : return cancelExecutions: ()
[2021-11-03 08:00:28][DEBUG] : set cancelExecutions: ()
[2021-11-03 08:00:28][DEBUG] : send command up to io://1237-7252-1660/1863134
[2021-11-03 08:00:28][DEBUG] : {"label":"up","actions":[{"deviceURL":"io:\/\/1237-7252-1660\/1863134","commands":[{"name":"up"}]}]}
[2021-11-03 08:00:28][DEBUG] : send command: ko: 401. Will retry
[2021-11-03 08:00:28][DEBUG] : logon with xxx and cookie /tmp/tahomacurlcookie
[2021-11-03 08:00:38][DEBUG] : new cookie - logon: ko: 401()
[2021-11-03 08:00:38][DEBUG] : return: HTTP/1.1 401 Date: Wed, 03 Nov 2021 07:00:37 GMT Server: overkiz Strict-Transport-Security: max-age=31536000; includeSubDomains Content-Type: application/json;charset=UTF-8 Transfer-Encoding: chunked {"errorCode":"AUTHENTICATION_ERROR","error":"Bad credentials"}
[2021-11-03 08:00:38][DEBUG] : return cancelExecutions: ()
[2021-11-03 08:00:38][DEBUG] : set cancelExecutions: ()
[2021-11-03 08:00:38][DEBUG] : send command up to io://1237-7252-1660/9572117
[2021-11-03 08:00:38][DEBUG] : {"label":"up","actions":[{"deviceURL":"io:\/\/1237-7252-1660\/9572117","commands":[{"name":"up"}]}]}
[2021-11-03 08:00:38][DEBUG] : send command: ko: 401. Will retry
[2021-11-03 08:00:38][DEBUG] : logon with xxx and cookie /tmp/tahomacurlcookie
[2021-11-03 08:00:48][DEBUG] : new cookie - logon: ko: 401()
[2021-11-03 08:00:48][DEBUG] : return: HTTP/1.1 401 Date: Wed, 03 Nov 2021 07:00:48 GMT Server: overkiz Strict-Transport-Security: max-age=31536000; includeSubDomains Content-Type: application/json;charset=UTF-8 Transfer-Encoding: chunked {"errorCode":"AUTHENTICATION_ERROR","error":"Bad credentials"}
[2021-11-03 08:00:48][DEBUG] : return cancelExecutions: ()
[2021-11-03 08:00:48][DEBUG] : set cancelExecutions: ()
[2021-11-03 08:00:48][DEBUG] : send command up to io://1237-7252-1660/11045014
[2021-11-03 08:00:48][DEBUG] : {"label":"up","actions":[{"deviceURL":"io:\/\/1237-7252-1660\/11045014","commands":[{"name":"up"}]}]}
[2021-11-03 08:00:48][DEBUG] : send command: ko: 401. Will retry
[2021-11-03 08:00:48][DEBUG] : logon with xxx and cookie /tmp/tahomacurlcookie
[2021-11-03 08:00:49][DEBUG] : new cookie - logon: ko: 401()
[2021-11-03 08:00:49][DEBUG] : return: HTTP/1.1 401 Date: Wed, 03 Nov 2021 07:00:48 GMT Server: overkiz Strict-Transport-Security: max-age=31536000; includeSubDomains Content-Type: application/json;charset=UTF-8 Transfer-Encoding: chunked {"errorCode":"AUTHENTICATION_ERROR","error":"Bad credentials"}
[2021-11-03 08:00:49][DEBUG] : return cancelExecutions: ()
[2021-11-03 08:00:49][DEBUG] : set cancelExecutions: ()
[2021-11-03 08:00:49][DEBUG] : send command up to io://1237-7252-1660/13841355
[2021-11-03 08:00:49][DEBUG] : {"label":"up","actions":[{"deviceURL":"io:\/\/1237-7252-1660\/13841355","commands":[{"name":"up"}]}]}
[2021-11-03 08:00:49][DEBUG] : send command: ko: 401. Will retry
[2021-11-03 08:00:49][DEBUG] : logon with xxx and cookie /tmp/tahomacurlcookie
[2021-11-03 08:00:49][DEBUG] : send command up to io://1237-7252-1660/5913809
[2021-11-03 08:00:49][DEBUG] : {"label":"up","actions":[{"deviceURL":"io:\/\/1237-7252-1660\/5913809","commands":[{"name":"up"}]}]}
[2021-11-03 08:00:49][DEBUG] : send command up to io://1237-7252-1660/11133158
[2021-11-03 08:00:49][DEBUG] : {"label":"up","actions":[{"deviceURL":"io:\/\/1237-7252-1660\/11133158","commands":[{"name":"up"}]}]}
Genre 1 fois par semaine à 8h.
