0689|[2025-07-26 22:20:09] DEBUG : Shutdown
0690|[2025-07-26 22:20:09] DEBUG : Removing PID file /tmp/jeedom/tahomalocalapi/tahomalocalapid.pid
0691|[2025-07-26 22:20:10] INFO : LoopNetServer Thread stopped
0692|[2025-07-26 22:20:10] DEBUG : Exit 0
0693|[2025-07-26 22:25:08] INFO : *-------------------------------------------------------------------------*
0694|[2025-07-26 22:25:08] INFO : Start demond
0695|[2025-07-26 22:25:08] INFO : Log level: debug
0696|[2025-07-26 22:25:08] INFO : Socket port: 56789
0697|[2025-07-26 22:25:08] INFO : Socket host: localhost
0698|[2025-07-26 22:25:08] INFO : PID file: /tmp/jeedom/tahomalocalapi/tahomalocalapid.pid
0699|[2025-07-26 22:25:08] INFO : Device: auto
0700|[2025-07-26 22:25:08] INFO : User: ********@gmail.com
0701|[2025-07-26 22:25:08] INFO : Pin ocde: ***********
0702|[2025-07-26 22:25:08] INFO : Box IP: https://192.168.1.41:8443
0703|[2025-07-26 22:25:08] INFO : Tahoma token: ***********
0704|[2025-07-26 22:25:08] INFO : Plugin uuid: 77635489-c55e-4030-8bf0-7f657e5529ea
0705|[2025-07-26 22:25:08] INFO : *-------------------------------------------------------------------------*
0706|[2025-07-26 22:25:08] INFO : Writing PID 20055 to /tmp/jeedom/tahomalocalapi/tahomalocalapid.pid
0707|[2025-07-26 22:25:08] INFO : Start changes async thread
0708|[2025-07-26 22:25:08] INFO : Init request module v2.32.4
0709|[2025-07-26 22:25:08] DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
0710|[2025-07-26 22:25:08] DEBUG : http://127.0.0.1:80 "GET /plugins/tahomalocalapi/core/php/jeeTahomalocalapi.php?apikey=lEksJM89gNtg9C8II8b8sHrQgN5R6GW5ErL4lPZ7xYG1AY19TOLlchx813hHfdpM HTTP/1.1" 200 0
0711|[2025-07-26 22:25:08] DEBUG : Listen socket jeedom
0712|[2025-07-26 22:25:08] INFO : Socket interface started
0713|[2025-07-26 22:25:08] INFO : LoopNetServer Thread started
0714|[2025-07-26 22:25:08] INFO : Listening on: [localhost:56789]
0715|[2025-07-26 22:25:08] DEBUG : * Retrieve gateways list
0716|[2025-07-26 22:25:08] ERROR : Fatal error: HTTPSConnectionPool(host='192.168.1.41', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/setup/gateways (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fadec4a60>: Failed to establish a new connection: [Errno 111] Connection refused'))
0717|[2025-07-26 22:25:08] INFO : Traceback (most recent call last):
0718|File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 198, in _new_conn
0719|sock = connection.create_connection(
0720|File "/usr/local/lib/python3.9/dist-packages/urllib3/util/connection.py", line 85, in create_connection
0721|raise err
0722|File "/usr/local/lib/python3.9/dist-packages/urllib3/util/connection.py", line 73, in create_connection
0723|sock.connect(sa)
0724|ConnectionRefusedError: [Errno 111] Connection refused
0725|The above exception was the direct cause of the following exception:
0726|Traceback (most recent call last):
0727|File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 787, in urlopen
0728|response = self._make_request(
0729|File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 488, in _make_request
0730|raise new_e
0731|File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 464, in _make_request
0732|self._validate_conn(conn)
0733|File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 1093, in _validate_conn
0734|conn.connect()
0735|File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 753, in connect
0736|self.sock = sock = self._new_conn()
0737|File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 213, in _new_conn
0738|raise NewConnectionError(
0739|urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7fadec4a60>: Failed to establish a new connection: [Errno 111] Connection refused
0740|The above exception was the direct cause of the following exception:
0741|Traceback (most recent call last):
0742|File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 667, in send
0743|resp = conn.urlopen(
0744|File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 841, in urlopen
0745|retries = retries.increment(
0746|File "/usr/local/lib/python3.9/dist-packages/urllib3/util/retry.py", line 519, in increment
0747|raise MaxRetryError(_pool, url, reason) from reason # type: ignore[arg-type]
0748|urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='192.168.1.41', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/setup/gateways (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fadec4a60>: Failed to establish a new connection: [Errno 111] Connection refused'))
0749|During handling of the above exception, another exception occurred:
0750|Traceback (most recent call last):
0751|File "/var/www/html/plugins/tahomalocalapi/resources/tahomalocalapid/tahomalocalapid.py", line 690, in <module>
0752|listen()
0753|File "/var/www/html/plugins/tahomalocalapi/resources/tahomalocalapid/tahomalocalapid.py", line 83, in listen
0754|getGateways()
0755|File "/var/www/html/plugins/tahomalocalapi/resources/tahomalocalapid/tahomalocalapid.py", line 289, in getGateways
0756|response = requests.request("GET", url, verify=False, headers=headers)
0757|File "/usr/local/lib/python3.9/dist-packages/requests/api.py", line 59, in request
0758|return session.request(method=method, url=url, **kwargs)
0759|File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 589, in request
0760|resp = self.send(prep, **send_kwargs)
0761|File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 703, in send
0762|r = adapter.send(request, **kwargs)
0763|File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 700, in send
0764|raise ConnectionError(e, request=request)
0765|requests.exceptions.ConnectionError: HTTPSConnectionPool(host='192.168.1.41', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/setup/gateways (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fadec4a60>: Failed to establish a new connection: [Errno 111] Connection refused'))
0766|[2025-07-26 22:25:08] DEBUG : Shutdown
0767|[2025-07-26 22:25:08] DEBUG : Removing PID file /tmp/jeedom/tahomalocalapi/tahomalocalapid.pid
0768|[2025-07-26 22:25:09] INFO : LoopNetServer Thread stopped
0769|[2025-07-26 22:25:09] DEBUG : Exit 0
