je suis sur RPI 2B avec LINUX Jessie et en controlant le log du plugin mqtt_dep j’ai des erreurs, il cherche entre autres php5.6-dev
A priori il fonctionne correctement mais je ne voudrais pas etre planté lors d’un prochaine mise à jour.
Que faudrait il faire pour corriger ca ?
Merci de votre aide
Voila le log :
Début d'installation des dépendances
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version.
php-pear is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 217 not upgraded.
Err http://repo.mosquitto.org wheezy/main armhf Packages
404 Not Found [IP: 2001:ba8:1f1:f271::2 80]
Fetched 9894 kB in 32s (308 kB/s)
W: Failed to fetch http://repo.mosquitto.org/debian/dists/wheezy/main/binary-armhf/Packages 404 Not Found [IP: 2001:ba8:1f1:f271::2 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
libmosquitto-dev is already the newest version.
mosquitto is already the newest version.
mosquitto-clients is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 230 not upgraded.
E: Unable to locate package php5.6-dev
E: Couldn't find any package by regex 'php5.6-dev'
Fin installation des dépendances
