J’ai une box atlas et jeedom V4.4.5 et je suis en version 10.10 debian
Mon installation fonctionne très bien mais je me suis aperçus en faisant une vérification générale que j’avais des erreurs dans le log
Check composer...OK
Check nodejs...E: The repository 'http://deb.debian.org/debian buster-backports Release' no longer has a Release file.
Get:1 http://security.debian.org buster/updates InRelease [34.8 kB]
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Ign:4 http://deb.debian.org/debian buster-backports InRelease
Err:5 http://deb.debian.org/debian buster-backports Release
404 Not Found [IP: 2a04:4e42:6a::644 80]
Get:6 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
Get:7 http://security.debian.org buster/updates/main arm64 Packages [767 kB]
Get:8 http://security.debian.org buster/updates/main armhf Packages [769 kB]
Get:9 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [8564 B]
Get:10 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [8589 B]
Get:11 https://deb.nodesource.com/node_18.x nodistro/main arm64 Contents (deb) [38.6 kB]
Get:12 https://deb.nodesource.com/node_18.x nodistro/main armhf Contents (deb) [38.6 kB]
Reading package lists...
Building dependency tree...
Reading state information...
apt-utils is already the newest version (1.8.2.3).
build-essential is already the newest version (12.6).
lsb-release is already the newest version (10.2019051400).
git is already the newest version (1:2.20.1-2+deb10u8).
The following packages were automatically installed and are no longer required:
gcc-8-base:armhf libc6:armhf libgcc1:armhf libpopt0:armhf libttspico0:armhf
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 216 not upgraded.
[Check Version NodeJS actuelle : v18.19.1 : [ OK ]
[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
OK
[END CONSISTENCY]
Au niveau de la page santé tous et ok
Je pense c’est parce-que debian 10.10 n’est plus supporté
Ma deuxième question :
Et on obligé de migré en debian 11 ?
Merci pour vos retour
