Salut !
En cours d’installation du plugin je n’arrive pas à démarrer mosquitto (broker local) dans le plugin mqtt2 :
found 0 vulnerabilities
+ sudo chown -R www-data:www-data jeedom mqtt2d.js node_modules package-lock.json package.json
+ echo 8
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end mqtt2
Signature ok
subject=C = FR, ST = Paris, L = Paris, O = jeedom, CN = jeedom-mosquitto
Getting CA Private Key
CA certificate and CA private key do not match
1995649088:error:06067099:digital envelope routines:EVP_PKEY_copy_parameters:different parameters:../crypto/evp/p_lib.c:93:
1995649088:error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch:../crypto/x509/x509_cmp.c:296:
Synchronizing state of mosquitto.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable mosquitto
+ echo 9
+ rm /tmp/jeedom_install_in_progress_mqtt2
per_listener_settings true
listener 1883
persistence false
allow_anonymous false
password_file /var/www/html/plugins/mqtt2/core/class/../../data/passwords
listener 8883
persistence false
cafile /var/www/html/plugins/mqtt2/core/class/../../data/ssl/ca.crt
certfile /var/www/html/plugins/mqtt2/core/class/../../data/ssl/mosquitto.crt
keyfile /var/www/html/plugins/mqtt2/core/class/../../data/ssl/mosquitto.key
require_certificate true
Une idée du problème ? ![]()
(j’ai tenté réinstallation des dépendances et réinstallation de mosquitto)
Merciiiiiii ![]()
j’ai vraiment hâte de pouvoir utiliser ce plugin Daikin ![]()
