e[0;37m[5/5/2022, 7:43:25 PM] e[0me[0;36m[Homebridge UI]e[0m e[0;33mHomebridge Config UI X v4.43.2 is listening on :: port 33221e[0m
e[0;37m[5/6/2022, 1:10:51 AM] e[0me[0;36m[Homebridge UI]e[0m Running job to cleanup config.json backup files older than 60 days...
[5/6/2022, 8:53:36 PM] Got SIGTERM, shutting down Homebridge...
2022-05-06T20:53:53.478Z ciao:init Loading ciao v1.1.4...
2022-05-06T20:53:55.536Z HAP-NodeJS:Advertiser Initializing HAP-NodeJS v0.10.0 ...
[5/6/2022, 8:53:56 PM] Loaded config.json with 0 accessories and 2 platforms.
[5/6/2022, 8:53:57 PM] Loaded 6 cached accessories from cachedAccessories.
[5/6/2022, 8:53:57 PM] ---
[5/6/2022, 8:53:59 PM] Loaded plugin: @nebz/homebridge-jeedom@v1.6.0
[5/6/2022, 8:54:03 PM] Plugin '@nebz/homebridge-jeedom' tried to register with an incorrect plugin identifier: 'homebridge-jeedom'. Please report this to the developer!
[5/6/2022, 8:54:03 PM] Registering platform '@nebz/homebridge-jeedom.Jeedom'
[5/6/2022, 8:54:03 PM] ---
[5/6/2022, 8:54:08 PM] Loaded plugin: homebridge-alexa@0.5.63
[5/6/2022, 8:54:08 PM] Registering platform 'homebridge-alexa.Alexa'
[5/6/2022, 8:54:08 PM] ---
[5/6/2022, 8:54:08 PM] Loaded plugin: homebridge-camera-ffmpeg@3.1.4
[5/6/2022, 8:54:08 PM] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[5/6/2022, 8:54:09 PM] Loaded plugin: homebridge-config-ui-x@4.43.2
[5/6/2022, 8:54:09 PM] Registering platform 'homebridge-config-ui-x.config'
[5/6/2022, 8:54:09 PM] ---
[5/6/2022, 8:54:09 PM] Loaded plugin: homebridge-gsh@2.2.0
[5/6/2022, 8:54:09 PM] Registering platform 'homebridge-gsh.google-smarthome'
[5/6/2022, 8:54:09 PM] Loading 2 platforms...
[5/6/2022, 8:54:09 PM] [Jeedom Delta] Initializing Jeedom platform...
[5/6/2022, 8:54:09 PM] [Jeedom Delta] debugLevel:100
[5/6/2022, 8:54:09 PM] [Jeedom Delta] [INFO] Adresse Jeedom bien configurée :http://192.168.0.40
[5/6/2022, 8:54:11 PM] [Config] Initializing config platform...
[5/6/2022, 8:54:11 PM] [Config] Spawning homebridge-config-ui-x with PID 6433
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] Accessoire en cache: Volet de la chambre du haut
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] Accessoire en cache: Volet de la chambre du bas
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] Accessoire en cache: Volet de la chambre de AAA
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] Accessoire en cache: Détecteur de fermeture
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] Accessoire en cache: Garage
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] Accessoire en cache: Système d'alarme
[5/6/2022, 8:54:11 PM] [Jeedom Delta] Synchronisation Jeedom <> Homebridge...
[5/6/2022, 8:54:11 PM] Publishing bridge accessory (name: Jeedom Delta, publishInfo: {
username: 'DB:3D:46:FE:A1:B3',
port: 51826,
pincode: '***-**-***',
category: 2,
bind: undefined,
mdns: undefined,
addIdentifyingMaterial: true,
advertiser: 'bonjour-hap',
setupID: 'A1B3'
2022-05-06T20:54:11.207Z HAP-NodeJS:Advertiser Preparing Advertiser for 'Jeedom Delta 2623' using bonjour-hap backend!
Setup Payload:
X-HM://0023ISYWYA1B3
Enter this code with your HomeKit app on your iOS device to pair with Homebridge:
│ 031-45-154 │
2022-05-06T20:54:11.220Z HAP-NodeJS:EventedHTTPServer Server listening on [::]:51826
2022-05-06T20:54:11.221Z HAP-NodeJS:Advertiser Starting to advertise 'Jeedom Delta 2623' using bonjour-hap backend!
[5/6/2022, 8:54:11 PM] Homebridge v1.4.0 (HAP v0.10.0) (Jeedom Delta) is running on port 51826.
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] Enumération des objets Jeedom (Pièces)...
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] Pièce > Maison
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] Pièce > Chambre 1
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] Pièce > Chambre 2
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] Pièce > Chambre 3
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] Pièce > Salon
[5/6/2022, 8:54:11 PM] [Jeedom Delta] Enumération des scénarios Jeedom...
[5/6/2022, 8:54:11 PM] [Jeedom Delta] Enumération des périphériques Jeedom...
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [DEBUG] eqLogic > {"id":"31","name":"Volet de la chambre","logicalId":"44","generic_type":null,"object_id":"2","eqType_name":"Freebox_OS","isVisible":0,"isEnable":1,"order":"1","comment":null,"tags":null,"status":{"lastCommunication":"2022-05-06 22:50:02","timeout":0,"warning":0,"danger":0},"sendToHomebridge":1,"services":{"flap":[{"state":{"id":"317","logicalId":"3","generic_type":"FLAP_STATE","eqType":"Freebox_OS","name":"Etat","order":"0","type":"info","subType":"binary","eqLogic_id":"31","isVisible":1,"currentValue":0,"configuration":{"phpType":"integer"}}},null,{"up":{"id":"318","logicalId":"0","generic_type":"FLAP_UP","eqType":"Freebox_OS","name":"Haut","order":"2","type":"action","subType":"other","eqLogic_id":"31","value":null,"isVisible":1}},{"stop":{"id":"319","logicalId":"1","generic_type":"FLAP_STOP","eqType":"Freebox_OS","name":"Stop","order":"3","type":"action","subType":"other","eqLogic_id":"31","value":null,"isVisible":1}},{"down":{"id":"320","logicalId":"2","generic_type":"FLAP_DOWN","eqType":"Freebox_OS","name":"Bas","order":"4","type":"action","subType":"other","eqLogic_id":"31","value":null,"isVisible":1}}]},"numSwitches":0}
[5/6/2022, 8:54:11 PM] [Jeedom Delta] ┌──── Chambre 1 > Volet de la chambre (31)
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [ERROR] Erreur de la fonction AccessoireCreateHomebridge : TypeError: Cannot read property 'invertBinary' of undefined
at /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js:521:36
at Array.forEach (<anonymous>)
at JeedomPlatform.AccessoireCreateHomebridge (/var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js:497:26)
at /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js:281:11
at Array.map (<anonymous>)
at JeedomPlatform.JeedomDevices2HomeKitAccessories (/var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js:275:12)
at /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js:144:12
at processTicksAndRejections (internal/process/task_queues.js:95:5)
[5/6/2022, 8:54:11 PM] [Jeedom Delta] [ERROR] Erreur de la fonction JeedomDevices2HomeKitAccessories : TypeError: Cannot read property 'UUID' of undefined
at JeedomPlatform.AccessoireCreateHomebridge (/var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js:2709:114)
