Erreur à l’installation des dépendances d’une antenne
Je viens d’installer une antenne blea sur un buster tout neuf et l’installation des dépendances me fait une erreur à l’installation de pillow:
  Running setup.py bdist_wheel for pillow: finished with status 'error'
  Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-kuti0lp3/pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-towileot --python-tag cp37:
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-armv7l-3.7
  creating build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageQt.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageSequence.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageStat.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/FpxImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/FtexImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/FontFile.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/McIdasImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/_tkinter_finder.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/WalImageFile.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/FliImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/GbrImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/GdImageFile.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/MpegImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PcxImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/GimpPaletteFile.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageMath.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/JpegImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageFilter.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PaletteFile.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/FitsStubImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/_binary.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/SgiImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/IcoImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/__main__.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/XVThumbImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageDraw.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageOps.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/WmfImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageColor.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PSDraw.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/MpoImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/IptcImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageShow.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PdfImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageWin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/DcxImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/XpmImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageTk.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageMorph.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PngImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/TiffImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/BmpImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImtImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/Jpeg2KImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PpmImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/_util.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/BdfFontFile.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/WebPImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageMode.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageFont.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageFile.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ContainerIO.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/Image.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PsdImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/BufrStubImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImagePalette.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/__init__.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PixarImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/DdsImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/BlpImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PcfFontFile.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageCms.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/CurImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImagePath.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PalmImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/TgaImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/EpsImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageGrab.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/SunImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageChops.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/XbmImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PyAccess.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageDraw2.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageTransform.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/TarIO.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ImageEnhance.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PcdImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/PdfParser.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/features.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/IcnsImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/GimpGradientFile.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/MspImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/SpiderImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/_version.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/TiffTags.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/Hdf5StubImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/MicImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/GribStubImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/GifImagePlugin.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/JpegPresets.py -> build/lib.linux-armv7l-3.7/PIL
  copying src/PIL/ExifTags.py -> build/lib.linux-armv7l-3.7/PIL
  running egg_info
  writing src/Pillow.egg-info/PKG-INFO
  writing dependency_links to src/Pillow.egg-info/dependency_links.txt
  writing top-level names to src/Pillow.egg-info/top_level.txt
  reading manifest file 'src/Pillow.egg-info/SOURCES.txt'
  reading manifest template 'MANIFEST.in'
  warning: no files found matching '*.c'
  warning: no files found matching '*.h'
  warning: no files found matching '*.sh'
  warning: no previously-included files found matching '.appveyor.yml'
  warning: no previously-included files found matching '.coveragerc'
  warning: no previously-included files found matching '.codecov.yml'
  warning: no previously-included files found matching '.editorconfig'
  warning: no previously-included files found matching '.readthedocs.yml'
  warning: no previously-included files found matching 'azure-pipelines.yml'
  warning: no previously-included files matching '.git*' found anywhere in distribution
  warning: no previously-included files matching '*.pyc' found anywhere in distribution
  warning: no previously-included files matching '*.so' found anywhere in distribution
  no previously-included directories found matching '.azure-pipelines'
  no previously-included directories found matching '.travis'
  writing manifest file 'src/Pillow.egg-info/SOURCES.txt'
  running build_ext
  The headers or library files could not be found for jpeg,
  a required dependency when compiling Pillow from source.
  Please see the install instructions at:
     https://pillow.readthedocs.io/en/latest/installation.html
    File "/tmp/pip-install-kuti0lp3/pillow/setup.py", line 888, in <module>
      zip_safe=not (debug_build() or PLATFORM_MINGW),
    File "/usr/local/lib/python3.7/dist-packages/setuptools/__init__.py", line 145, in setup
      return distutils.core.setup(**attrs)
    File "/usr/lib/python3.7/distutils/core.py", line 148, in setup
      dist.run_commands()
    File "/usr/lib/python3.7/distutils/dist.py", line 966, in run_commands
      self.run_command(cmd)
    File "/usr/lib/python3.7/distutils/dist.py", line 985, in run_command
      cmd_obj.run()
    File "/usr/lib/python3/dist-packages/wheel/bdist_wheel.py", line 188, in run
      self.run_command('build')
    File "/usr/lib/python3.7/distutils/cmd.py", line 313, in run_command
      self.distribution.run_command(command)
      cmd_obj.run()
    File "/usr/lib/python3.7/distutils/command/build.py", line 135, in run
      self.run_command(cmd_name)
      cmd_obj.run()
    File "/usr/lib/python3.7/distutils/command/build_ext.py", line 340, in run
      self.build_extensions()
    File "/tmp/pip-install-kuti0lp3/pillow/setup.py", line 687, in build_extensions
      raise RequiredDependencyException(f)
  __main__.RequiredDependencyException: jpeg
  During handling of the above exception, another exception occurred:
    File "<string>", line 1, in <module>
    File "/tmp/pip-install-kuti0lp3/pillow/setup.py", line 903, in <module>
      raise RequiredDependencyException(msg)
  Failed building wheel for pillow
  Running setup.py clean for pillow
Failed to build pillow
Installing collected packages: pillow
  Running setup.py install for pillow: started
    Running setup.py install for pillow: finished with status 'error'
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-gvetm07m/install-record.txt --single-version-externally-managed --compile:
    running install
    running build
    running build_py
    creating build
    running egg_info
    running build_ext
        dist.run_commands()
        cmd_obj.run()
      File "/usr/local/lib/python3.7/dist-packages/setuptools/command/install.py", line 61, in run
        return orig.install.run(self)
      File "/usr/lib/python3.7/distutils/command/install.py", line 589, in run
        cmd_obj.run()
        cmd_obj.run()
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-kuti0lp3/pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-gvetm07m/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-kuti0lp3/pillow/
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.17.3)
Cloning into 'bluepy'...
Quelqu’un sait d’ou ça vient?
Édit: dans la page indiquée dans les logs, je vois ça:
You do not need to install all supported external libraries to use Pillow’s basic features. Zlib and libjpeg are required by default.
Je dois installer libjpeg manuellement?
Edit2: d’apres le graph de réseau, l’antenne a l’air de fonctionner quand même…(pas vérifié si elle reçoit des données, mais elle voit mes capteurs)
Plutôt que d’essayer de me dépatouiller à la main, je laisse comme ça pour l’instant, comme ça si @Ludovic a besoin d’infos je peux regarder.
