Equipement non visible dans l'interface Zigbee2MQTT
Suite à des problèmes d’équipement qui ne communiquait plus avec Jeedom, j’ai du désappairer un module de Jeedom pour le réappairer à nouveau.
Dans Jeedom, il apparait bien dans le plugin jeezigbee mais je ne sais pas pourquoi il n’apparait plus dans l’interface Zigbee2MQTT. J’en ai besoin pour configurer pour Zlinky_TIC :confused:
> zigbee2mqtt@1.33.2 start
> node index.js
Zigbee2MQTT:debug 2023-11-19 18:19:30: Loaded state from file /var/www/html/plugins/z2m/data/state.json
Zigbee2MQTT:info  2023-11-19 18:19:30: Logging to console and directory: '/var/www/html/plugins/z2m/data/log/2023-11-19.18-19-30' filename: log.txt
Zigbee2MQTT:info  2023-11-19 18:19:30: Starting Zigbee2MQTT version 1.33.2 (commit #311ea07)
Zigbee2MQTT:info  2023-11-19 18:19:30: Starting zigbee-herdsman (0.21.0)
Zigbee2MQTT:debug 2023-11-19 18:19:30: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/var/www/html/plugins/z2m/data/coordinator_backup.json","databaseBackupPath":"/var/www/html/plugins/z2m/data/database.db.backup","databasePath":"/var/www/html/plugins/z2m/data/database.db","network":{"channelList":[11],"extendedPanID":[45,210,183,205,195,242,138,10],"networkKey":"HIDDEN","panID":64797},"serialPort":{"adapter":"deconz","path":"/dev/ttyACM0"}}'
Zigbee2MQTT:info  2023-11-19 18:19:31: zigbee-herdsman started (resumed)
Zigbee2MQTT:info  2023-11-19 18:19:31: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"}'
Zigbee2MQTT:debug 2023-11-19 18:19:31: Zigbee network parameters: {"channel":11,"extendedPanID":"0x2dd2b7cdc3f28a0a","panID":64797}
Zigbee2MQTT:info  2023-11-19 18:19:31: Currently 1 devices are joined:
Zigbee2MQTT:info  2023-11-19 18:19:31: 0x00158d000966cc38 (0x00158d000966cc38): ZLinky_TIC - LiXee Lixee ZLinky (Router)
Zigbee2MQTT:info  2023-11-19 18:19:31: Zigbee: disabling joining new devices.
Zigbee2MQTT:info  2023-11-19 18:19:31: Connecting to MQTT server at mqtt://127.0.0.1:1883
Zigbee2MQTT:debug 2023-11-19 18:19:31: Using MQTT login with username: jeedom
Zigbee2MQTT:info  2023-11-19 18:19:32: Connected to MQTT server
Zigbee2MQTT:info  2023-11-19 18:19:32: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:debug 2023-11-19 18:19:32: Received MQTT message on 'zigbee2mqtt/bridge/config' with data '{"commit":"311ea07","coordinator":{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"},"log_level":"debug","network":{"channel":11,"extendedPanID":"0x2dd2b7cdc3f28a0a","panID":64797},"permit_join":false,"version":"1.33.2"}'
zlinky config: standard, single_phase, false, H PLEINE/CREUSE
Zigbee2MQTT:info  2023-11-19 18:19:32: Started frontend on port 0.0.0.0:8080
L’équipement communique bien avec Jeedom et se mets à jour.
Problème trouvé, l’interface me demandait le token de connexion via une pop up. Sauf que mon navigateur bloquait les pops up.
Après autorisation de cette pop up, j’ai pu voir mon équipement
