Il semble que j’ai un soucis similaire dans donnée brutes :
vehicle State :
"exveErrorId": "CU-400",
"exveErrorMsg": "Bad request",
"exveErrorRef": "ygC#%2dRZp8BeEeOvnqG",
"exveNote": "This error is raised when the request is wrong."
Dans les log :
2026-07-14 18:05:03] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
[2026-07-14 20:05:03] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
[2026-07-14 22:05:04] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
[2026-07-15 00:05:04] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
[2026-07-15 02:05:04] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
[2026-07-15 04:05:04] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
[2026-07-15 06:05:03] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
[2026-07-15 08:05:04] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
[2026-07-15 10:05:04] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
[2026-07-15 12:05:04] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
[2026-07-15 14:05:04] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
[2026-07-15 16:05:04] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
dans les logs du daemon :
[2026-07-15 15:05:17]WARNING : Authentication failed — Refresh token required
[2026-07-15 15:05:17]WARNING : Disconnected from MQTT broker (code DisconnectFlags(is_disconnect_packet_from_server=False))
[2026-07-15 16:05:17]WARNING : Disconnected from MQTT broker (code DisconnectFlags(is_disconnect_packet_from_server=False))
[2026-07-15 16:05:30]WARNING : MQTT connection failed with code Bad user name or password
[2026-07-15 16:05:30]WARNING : Authentication failed — Refresh token required
[2026-07-15 16:05:30]WARNING : Disconnected from MQTT broker (code DisconnectFlags(is_disconnect_packet_from_server=False))
[2026-07-15 17:05:03]WARNING : Disconnected from MQTT broker (code DisconnectFlags(is_disconnect_packet_from_server=False))
[2026-07-15 17:05:17]WARNING : MQTT connection failed with code Bad user name or password
[2026-07-15 17:05:17]WARNING : Authentication failed — Refresh token required
[2026-07-15 17:05:17]WARNING : Disconnected from MQTT broker (code DisconnectFlags(is_disconnect_packet_from_server=False))
J’ai deja essayé de supprimer le token et de refaire mais rien ne change
[2026-07-15 17:10:34] ERROR | Result Authentication : you must (re)authenticate
[2026-07-15 17:11:07] ERROR | Result getContainer() : [403 - FORBIDDEN] {"exveErrorId": "CU-403","exveErrorMsg": "Bad Request. Forbidden","exveErrorRef": "","exveNote": "This application error is raised when an invalid resource is invoked, or a valid resource is invoked incorrectly."}
[2026-07-15 17:11:08] ERROR └─End of vehicle infos refresh : [400 - BAD_REQUEST]
Merci ![]()
