Echec de restauration
je souhaite remplacer mon PI3+ par un PI4.
J’ai réinstallé correctement jeedom sur mon nouveau RPI mais… quand je tente une restauration d’une sauvegarde ca bloque. Mes 2 RPI sont sur la même version de Jeedom (4.4.8.1)
Sous Putty, le blocage semble se faire lors de la restauration des plugin. Au premier plugin, ca s’arrête.
Et bien ensuite, j’ai un affichage des menus entre accolades, et plus rien ne fonctionne. Aucune page ne s’affiche…
root@raspberrypi:~# php /var/www/html/install/restore.php
[START RESTORE]
***************Begin Jeedom restore 2024-07-11 09:19:31***************
Send begin restore event...OK
Checking rights...OK
Restore from file : /var/www/html/install/../backup/backup-Maison-4.        4.8.1-2024-07-11-02h31.tar.gz
Backup database access configuration...OK
Disable all taskkill: (6213): No such process
. OK
Disable all scenario OK
Unpacking backup...OK
Update composer file...
OK
[PROGRESS][58]
Deleting database...Disabling constraints...OK
Deleting table : cmd ...OK
Deleting table : config ...OK
Deleting table : cron ...OK
Deleting table : dataStore ...OK
Deleting table : eqLogic ...OK
Deleting table : history ...OK
Deleting table : historyArch ...OK
Deleting table : interactDef ...OK
Deleting table : interactQuery ...OK
Deleting table : listener ...OK
Deleting table : message ...OK
Deleting table : note ...OK
Deleting table : object ...OK
Deleting table : plan ...OK
Deleting table : plan3d ...OK
Deleting table : plan3dHeader ...OK
Deleting table : planHeader ...OK
Deleting table : scenario ...OK
Deleting table : scenarioElement ...OK
Deleting table : scenarioExpression ...OK
Deleting table : scenarioSubElement ...OK
Deleting table : timeline ...OK
Deleting table : update ...OK
Deleting table : user ...OK
Deleting table : view ...OK
Deleting table : viewData ...OK
Deleting table : viewZone ...OK
Deleting table : widgets ...OK
Restoring database from backup...OK
Enable back constraints...OK
Restoring cache...OK
sudo: yarn: command not found
Restoring Plugin : sonos3...root@raspberrypi:~#
Est-ce que tu es passé sur une distribution basé sur Debian 12 au passage (sur ton nouveau PI4) ?
Voir ici : Compatibilité des plugins avec Debian 12 - Bookworm, php 8, python 3.11 - #71 par laurent.da-col
S’il s’agit du plugin-sonos3, visiblement ça se passe mal sur une Debian 12.
Bonjour Bison,
En effet, après avoir posté ma question (et alors que j’y suis depuis hier…), j’ai supprimé le plugin Sonos sur mon installation et refait une sauvegarde.
Celle ci a fonctionnée sur ma nouvelle config… !
Bon, j’ai aucun plugin qui fonctionne mais je suppose que c’est normal, je vais réinstaller les dépendances et autres…
Merci pour l’info.
Oui en effet, il faudra réinstaller les dépendances de la plupart des plugins pour que le demon de chacun puisse à nouveau tourner et faire le job.
Si c’est OK pour toi, pense à fermer ce post avec la solution
Bonne journée,
Bison
Du coup vous avez installé debian 12?
Attention que cette version n’est pas 100% compatible.
Sachez que vous êtes en mode « beta ».
En cas de soucis majeure il faudra réinstaller debian 11.
