J’ai ajouté une rallonge usb entre le hub et le controller zwave, toujours sans optimisation…
J’ai remarqué que le problème ne surviens pas si j’effectue des actions plus ou moins toutes les heures. Aujourd’hui j’ai effectué qu’une action vers 15h et attendu la soirée pour tester. Et le bug est bien présent
Les log ci dessous :
2020-08-04 14:55:25.857 Detail, Node017, Notification: ValueChanged
2020-08-04 21:21:56.431 Info, Node019, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
2020-08-04 21:21:56.431 Info, Node019, SwitchMultilevel::Set - Setting to level 0
2020-08-04 21:21:56.431 Detail, Node019, Queuing (Send) SwitchMultilevelCmd_Set (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x26, 0x01, 0x00, 0x25, 0xef, 0x1b
2020-08-04 21:21:56.431 Detail, Node019, Queuing (Refresh) SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf0, 0x05
2020-08-04 21:21:56.432 Detail,
2020-08-04 21:21:56.432 Info, Node019, Sending (Send) message (Callback ID=0xef, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x26, 0x01, 0x00, 0x25, 0xef, 0x1b
2020-08-04 21:21:57.432 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-08-04 21:21:57.432 Detail, Node019, Removing current message
2020-08-04 21:21:57.432 Detail, Node019, Notification: Notification - TimeOut
2020-08-04 21:21:57.436 Detail,
2020-08-04 21:21:57.436 Info, Node019, Sending (Refresh) message (Callback ID=0xf0, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf0, 0x05
2020-08-04 21:21:58.436 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-08-04 21:21:58.436 Detail, Node019, Removing current message
2020-08-04 21:21:58.436 Detail, Node019, Notification: Notification - TimeOut
2020-08-04 21:22:05.444 Info, mgr, Refreshing node 19: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-08-04 21:22:05.444 Detail, Node019, Queuing (Refresh) SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf1, 0x04
2020-08-04 21:22:05.444 Info, Node019, Sending (Refresh) message (Callback ID=0xf1, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf1, 0x04
2020-08-04 21:22:06.444 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-08-04 21:22:06.444 Detail, Node019, Removing current message
2020-08-04 21:22:06.445 Detail, Node019, Notification: Notification - TimeOut
2020-08-04 21:22:14.448 Info, mgr, Refreshing node 19: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-08-04 21:22:14.448 Detail, Node019, Queuing (Refresh) SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf2, 0x07
2020-08-04 21:22:14.448 Info, Node019, Sending (Refresh) message (Callback ID=0xf2, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf2, 0x07
2020-08-04 21:22:15.448 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-08-04 21:22:15.449 Detail, Node019, Removing current message
2020-08-04 21:22:15.449 Detail, Node019, Notification: Notification - TimeOut
2020-08-04 21:22:23.449 Info, mgr, Refreshing node 19: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-08-04 21:22:23.449 Detail, Node019, Queuing (Refresh) SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf3, 0x06
2020-08-04 21:22:23.450 Detail,
2020-08-04 21:22:23.450 Info, Node019, Sending (Refresh) message (Callback ID=0xf3, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf3, 0x06
2020-08-04 21:22:24.450 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-08-04 21:22:24.450 Detail, Node019, Removing current message
2020-08-04 21:22:24.450 Detail, Node019, Notification: Notification - TimeOut
2020-08-04 21:22:32.455 Info, mgr, Refreshing node 19: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-08-04 21:22:32.569 Detail, Node019, Queuing (Refresh) SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf4, 0x01
2020-08-04 21:22:32.569 Info, Node019, Sending (Refresh) message (Callback ID=0xf4, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf4, 0x01
2020-08-04 21:22:33.569 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-08-04 21:22:33.569 Detail, Node019, Removing current message
2020-08-04 21:22:33.569 Detail, Node019, Notification: Notification - TimeOut
2020-08-04 21:22:41.578 Info, mgr, Refreshing node 19: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-08-04 21:22:41.578 Detail, Node019, Queuing (Refresh) SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf5, 0x00
2020-08-04 21:22:41.578 Info, Node019, Sending (Refresh) message (Callback ID=0xf5, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf5, 0x00
2020-08-04 21:22:42.578 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-08-04 21:22:42.578 Detail, Node019, Removing current message
2020-08-04 21:22:42.579 Detail, Node019, Notification: Notification - TimeOut
2020-08-04 21:22:50.587 Info, mgr, Refreshing node 19: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-08-04 21:22:50.587 Detail, Node019, Queuing (Refresh) SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf6, 0x03
2020-08-04 21:22:50.587 Info, Node019, Sending (Refresh) message (Callback ID=0xf6, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0xf6, 0x03
2020-08-04 21:22:51.587 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-08-04 21:22:51.587 Detail, Node019, Removing current message
2020-08-04 21:22:51.587 Detail, Node019, Notification: Notification - TimeOut
