impossible de synchroniser
l’accès au pilotage a distance est effectif (application ima protect utilisée)
ci-dessous les logs en mode débug
bonne soirée
[2025-06-02 18:38:01] DEBUG : Exécution du cron Ima Protect
[2025-06-02 18:38:01] DEBUG : GetAlarmState Start
[2025-06-02 18:38:01] DEBUG : * instanciation api ima protect
[2025-06-02 18:38:01] DEBUG : ==> constructor of class imaProtectNewAPI - Start
[2025-06-02 18:38:01] DEBUG : ==> getDatasSession
[2025-06-02 18:38:01] DEBUG : ==> No plugin config ... init to call
[2025-06-02 18:38:01] DEBUG : * Validation couple user / mdp
[2025-06-02 18:38:01] DEBUG : * login
[2025-06-02 18:38:01] DEBUG : ==> doRequest
[2025-06-02 18:38:01] DEBUG : ==> Params : https://www.imaprotect.com/fr/client/login | | GET | null
[2025-06-02 18:38:01] DEBUG : ==> Params json input : null
[2025-06-02 18:38:01] DEBUG : ==> Response
[2025-06-02 18:38:01] DEBUG : # Code Http : 200
[2025-06-02 18:38:01] DEBUG : # Header : HTTP/2 200 date: Mon, 02 Jun 2025 16:38:01 GMT cache-control: max-age=0, must-revalidate, private expires: Mon, 02 Jun 2025 16:38:01 GMT vary: Accept-Encoding content-type: text/html; charset=UTF-8 strict-transport-security: max-age=31536000; includeSubDomains set-cookie: imainternational=e36663dc87a80201dee5c342b4661d53; expires=Mon, 02 Jun 2025 16:58:01 GMT; Max-Age=1200; path=/; domain=www.imaprotect.com; secure; HttpOnly; SameSite=lax set-cookie: TS013a2ec2=01277f05fcb1f71ff7d445a4a89b09a99d1e0b95009fb158e6e6cbb94d0ee9df1baa6ecda6497805280c4ffd1c03f0bdeaa58c69c29a57f6dd647465e4e7e991aaa2ce7ae0; Path=/; Domain=.www.imaprotect.com; Secure; HttpOnly;
[2025-06-02 18:38:01] DEBUG : ==> Recover cookies get : e36663dc87a80201dee5c342b4661d53|01277f05fcb1f71ff7d445a4a89b09a99d1e0b95009fb158e6e6cbb94d0ee9df1baa6ecda6497805280c4ffd1c03f0bdeaa58c69c29a57f6dd647465e4e7e991aaa2ce7ae0|Mon, 02 Jun 2025 16:58:01 GMT|9.4F-VodkjHZ4bt35MfL_6JeVydfGXT57s3RSkkRrBXO4.rxTs4-5ke9hehhcCKvXMRqs6Fqi6fsuppEb04VGDJoeqLsXE7xdN-n3jCQ
[2025-06-02 18:38:01] DEBUG : * loginCheck
[2025-06-02 18:38:01] DEBUG : ==> Params : https://www.imaprotect.com/fr/client/login_check | _username=myemailadr%40gmail.com&_password=xxxxxxxxxxx%40xxxxxxxxxxxxxx&_csrf_token=9.4F-VodkjHZ4bt35MfL_6JeVydfGXT57s3RSkkRrBXO4.rxTs4-5ke9hehhcCKvXMRqs6Fqi6fsuppEb04VGDJoeqLsXE7xdN-n3jCQ | POST | ["Host: www.imaprotect.com","Referer: https:\/\/www.imaprotect.com\/fr\/client\/login","Accept: application\/json, text\/plain, *\/*","Accept-Encoding: gzip, deflate, br","Cookie: TS013a2ec2=01277f05fcb1f71ff7d445a4a89b09a99d1e0b95009fb158e6e6cbb94d0ee9df1baa6ecda6497805280c4ffd1c03f0bdeaa58c69c29a57f6dd647465e4e7e991aaa2ce7ae0;imainternational=e36663dc87a80201dee5c342b4661d53","Origin: https:\/\/www.imaprotect.com","Content-Type: application\/x-www-form-urlencoded"]
[2025-06-02 18:38:01] DEBUG : ==> Params json input : "_username=myemailadr%40gmail.com&_password=xxxxxxxx%40xxxxxxxxxxxxxxxxx&_csrf_token=9.4F-VodkjHZ4bt35MfL_6JeVydfGXT57s3RSkkRrBXO4.rxTs4-5ke9hehhcCKvXMRqs6Fqi6fsuppEb04VGDJoeqLsXE7xdN-n3jCQ"
[2025-06-02 18:38:01] DEBUG : # Header : HTTP/1.1 302 Found Date: Mon, 02 Jun 2025 16:38:01 GMT Cache-Control: max-age=0, must-revalidate, private Expires: Mon, 02 Jun 2025 16:38:01 GMT Upgrade: h2,h2c Connection: Upgrade Location: https://www.imaprotect.com/fr/client/login Content-Type: text/html; charset=utf-8 Strict-Transport-Security: max-age=31536000; includeSubDomains Set-Cookie: front=deleted; expires=Sun, 02 Jun 2024 16:38:00 GMT; Max-Age=0; path=/client; secure; httponly; samesite=lax Set-Cookie: TS013a2ec2=01277f05fcb1f71ff7d445a4a89b09a99d1e0b95009fb158e6e6cbb94d0ee9df1baa6ecda6497805280c4ffd1c03f0bdeaa58c69c29a57f6dd647465e4e7e991aaa2ce7ae0; Path=/; Domain=.www.imaprotect.com; Secure; HttpOnly; Set-Cookie: TS0192ac0d=01277f05fc5e3c53d21b3db9c13949627957c5725b9fb158e6e6cbb94d0ee9df1baa6ecda6497805280c4ffd1c03f0bdeaa58c69c2cf7c252ea08fef61f5fca71ac88951cb7d782a860a8c69566d363927ec45dbab; path=/client; HttpOnly; Secure Transfer-Encoding: chunked HTTP/1.1 200OKDate: Mon, 02 Jun 2025 16:38:01 GMT Cache-Control: max-age=0, must-revalidate, private Expires: Mon, 02 Jun 2025 16:38:01 GMT Vary: Accept-Encoding Content-Encoding: gzip Content-Length: 6293 Content-Type: text/html; charset=UTF-8 Strict-Transport-Security: max-age=31536000; includeSubDomains
[2025-06-02 18:38:01] DEBUG : manageErrorMessage : login_check function - Erreur récuperation cookie (expireImaCookie)|500
[2025-06-02 18:38:01] DEBUG : ==> errorMessage : login_check function - Erreur récuperation cookie (expireImaCookie) (500)
**[2025-06-02 18:38:01] ERROR : Erreur lors de l'exécution du cron GetAlarmState => getInstanceIMAApi => login_check function - Erreur récuperation cookie (expireImaCookie) (500)**
Informations Jeedom Delta
Core : 4.4.19 (master)
DNS Jeedom Delta : non
Plugin : Alarme IMA
Version : 2024-04-03 01:21:27 (stable)
