Dongle usb non détecté
Bonsoir, j’ai acquis un dongle usb conseillé par le grand docteur Sarakah ( http://sarakha63-domotique.fr/blea-plugin-bluetooth-jeedom/
le second modele , mais il n’est pas détécté par jeedom lorsque je le branche. Dois je faire autre chose ?
Voici le bout de log d installation dont je dispose . L installation cale a 50%
  •   	 Installation des dépendances			 *
Hit:1 http://www.deb-multimedia.org stretch InRelease
Hit:2 http://security.debian.org stretch/updates InRelease
Hit:3 Index of /odroid stable InRelease
Ign:4 Index of /debian stretch InRelease
Hit:5 Index of /debian stretch-updates InRelease
Hit:6 Index of /debian stretch-backports InRelease
Hit:7 Index of /debian stretch-proposed-updates InRelease
Hit:8 Index of /debian stretch Release
Hit:9 https://oph.mdrjr.net/meveric all InRelease
Hit:10 https://oph.mdrjr.net/meveric stretch InRelease
Reading package lists…
Building dependency tree…
Reading state information…
libatlas-base-dev is already the newest version (3.10.3-1+b1).
bluetooth is already the newest version (5.43-2+deb9u1).
libbluetooth-dev is already the newest version (5.43-2+deb9u1).
build-essential is already the newest version (12.3).
libffi-dev is already the newest version (3.2.1-6).
python3-serial is already the newest version (3.2.1-1).
python3-setuptools is already the newest version (33.1.1-1).
python3-dev is already the newest version (3.5.3-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.12.4-1).
rfkill is already the newest version (0.5-1+b1).
libtiff5 is already the newest version (4.0.8-2+deb9u4).
libssl-dev is already the newest version (1.1.0l-1~deb9u1).
libopenjp2-7 is already the newest version (2.1.2-1.1+deb9u4).
0 upgraded, 0 newly installed, 0 to remove and 175 not upgraded.
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 175 not upgraded.
Need to get 0 B/142 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database …
(Reading database … 5%
(Reading database … 10%
(Reading database … 15%
(Reading database … 20%
(Reading database … 25%
(Reading database … 30%
(Reading database … 35%
(Reading database … 40%
(Reading database … 45%
(Reading database … 50%
(Reading database … 55%
(Reading database … 60%
(Reading database … 65%
(Reading database … 70%
(Reading database … 75%
(Reading database … 80%
(Reading database … 85%
(Reading database … 90%
(Reading database … 95%
(Reading database … 100%
(Reading database … 53093 files and directories currently installed.)
Preparing to unpack …/python3-pip_9.0.1-2+deb9u1_all.deb …
Unpacking python3-pip (9.0.1-2+deb9u1) over (9.0.1-2+deb9u1) …
Setting up python3-pip (9.0.1-2+deb9u1) …
Processing triggers for man-db (2.7.6.1-2) …
Requirement already up-to-date: setuptools in /usr/local/lib/python3.5/dist-packages
git is already the newest version (1:2.11.0-3+deb9u4).
libglib2.0-dev is already the newest version (2.50.3-2+deb9u1).
Requirement already satisfied: pyudev in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: six in /usr/local/lib/python3.5/dist-packages (from pyudev)
Requirement already satisfied: pyserial in /usr/lib/python3/dist-packages
Requirement already satisfied: requests in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.5/dist-packages (from requests)
Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/local/lib/python3.5/dist-packages (from requests)
Requirement already satisfied: idna<2.9,>=2.5 in /usr/local/lib/python3.5/dist-packages (from requests)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.5/dist-packages (from requests)
Requirement already satisfied: pybluez in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: pillow in /usr/local/lib/python3.5/dist-packages
Collecting numpy
Using cached https://files.pythonhosted.org/packages/ff/59/d3f6d46aa1fd220d020bdd61e76ca51f6548c6ad6d24ddb614f4037cf49d/numpy-1.17.4.zip
Building wheels for collected packages: numpy
Running setup.py bdist_wheel for numpy: started
Running setup.py bdist_wheel for numpy: still running…
Running setup.py bdist_wheel for numpy: still running…`
Tu évoques un problème de détection de ton dongle alors que tu as déjà un problème de dépendance. La détection cela sera après.
Là les dépendance bloque, après une recherche sur l’ancien forum, il y a quelques remonté similaire qui semble être lié à un conflit avec un autre plugin.
As tu intallé Zigate par exemple ?
J ai réussi en entrant la commande Isusb. Le dongle est apparu et j ai pu détecter mes nut
Tu as réglé le problème d’installation des dépendances ?
Effectivement, ca a fini par s’installer mais ca a pris pres de 20 minutes.
