A priori des problèmes de droit. Ton utilisateur « jeedom » a t il les droits d’écritures?
sinon il faut faire exactement ce qui est indiqué, à savoir:
passer en root: sudo su
et écrire dans le crontab la commande indiquée
ensuite les trois autres lignes c’est des paramètres à modifier dans php (/etc/php/7.3/apache2/php.ini)
max_execution_time
upload_max_filesize
post_max_size
Concrètement ça en passe par quelles commandes ? j’avais éteins la machine et du coup aujourd’hui je n’ai plus d’accès en passant par un navigateur > la connexion a échoué.
Du coup en cherchant un peu et en saisisssant `sudo docker logs jeedom-server
je tombe sur ça
étape 6 téléchargement de jeedom réussie
All init complete
Start apache2
System has not been booted with systemd as init system (PID 1). Can't operate.
Failed to connect to bus: Host is down
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 172.17.0.3. Set the 'ServerName' directive globally to suppress this message
Restarting Apache httpd web server: apache2.
Start sshd
Restarting OpenBSD Secure Shell server: sshd.
Start atd
Stopping deferred execution scheduler: atd.
Starting deferred execution scheduler: atd.
/usr/lib/python2.7/dist-packages/supervisor/options.py:461: UserWarning: Supervisord is running as root and it is searching for its configuration file in default locations (including its current working directory); you probably want to specify a "-c" argument specifying an absolute path to a configuration file for improved security.
'Supervisord is running as root and it is searching '
2020-01-28 11:42:53,197 CRIT Supervisor is running as root. Privileges were not dropped because no user is specified in the config file. If you intend to run as root, you can set user=root in the config file to avoid this message.
2020-01-28 11:42:53,197 INFO Included extra file "/etc/supervisor/conf.d/supervisord.conf" during parsing
2020-01-28 11:42:53,203 INFO RPC interface 'supervisor' initialized
2020-01-28 11:42:53,203 CRIT Server 'unix_http_server' running without any HTTP authentication checking
2020-01-28 11:42:53,204 INFO supervisord started with pid 99
2020-01-28 11:42:54,207 INFO spawned: 'cron' with pid 102
2020-01-28 11:42:55,209 INFO success: cron entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
Je ne vois pas non plus de rep php dans etc… bref je nage
Il faut avouer que ce n’est pas limpide comme install… merci
avant de lancer l’installation tu dois faire une ligne de commande
sudo su
sans quoi la fin de ton installation sera un echec
j’ai eu le même soucis lors de mon installation
Tu installe jeedom via ton syno ?
Je dois t’avouer que je n’avais pas fait attention que c’était sous Docker, j’avais a l’époque essayé via Docker et j’avais eu le même soucis que toi et je suis passé par virtual machine et la plus de soucis
Oui ça c’est testé et fonctionnel, mais je teste diverses solutions pour voir ce qui me convient le mieux, car la machine ne sera pas dédiée qu’à jeedom.
Proxmox + docker
Openmediavault + docker
Debian + docker
