Une question pour @domoggvad:
Dans ton test sur la Beelink GT1, tu indiques avoir ajouté le swap.
- J’ai vérifié dans « santé » de mon Jeedom et il est indiqué Swapiness 100 %.
- Et dans les infos de mon système Armbian, j’ai:
jeedom@arm-64:~$ more /proc/swaps
Filename Type Size Used Priority
/dev/zram1 partition 1842120 0 5
jeedom@arm-64:~$ more /proc/meminfo
MemTotal: 3684248 kB
MemFree: 2865600 kB
MemAvailable: 3171652 kB
Buffers: 76180 kB
Cached: 358036 kB
SwapCached: 0 kB
Active: 404124 kB
Inactive: 194224 kB
Active(anon): 176104 kB
Inactive(anon): 33196 kB
Active(file): 228020 kB
Inactive(file): 161028 kB
Unevictable: 16 kB
Mlocked: 16 kB
SwapTotal: 1842120 kB
SwapFree: 1842120 kB
Dirty: 68 kB
jeedom@arm-64:~$ df -ah
Filesystem Size Used Avail Use% Mounted on
sysfs 0 0 0 - /sys
proc 0 0 0 - /proc
udev 1.4G 0 1.4G 0% /dev
devpts 0 0 0 - /dev/pts
tmpfs 360M 37M 324M 11% /run
/dev/mmcblk2p2 28G 2.5G 25G 9% /
securityfs 0 0 0 - /sys/kernel/security
selinuxfs 0 0 0 - /sys/fs/selinux
tmpfs 1.8G 0 1.8G 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 1.8G 0 1.8G 0% /sys/fs/cgroup
cgroup2 0 0 0 - /sys/fs/cgroup/unified
cgroup 0 0 0 - /sys/fs/cgroup/systemd
pstore 0 0 0 - /sys/fs/pstore
none 0 0 0 - /sys/fs/bpf
cgroup 0 0 0 - /sys/fs/cgroup/net_cls,net_prio
cgroup 0 0 0 - /sys/fs/cgroup/cpu,cpuacct
cgroup 0 0 0 - /sys/fs/cgroup/perf_event
cgroup 0 0 0 - /sys/fs/cgroup/hugetlb
cgroup 0 0 0 - /sys/fs/cgroup/blkio
cgroup 0 0 0 - /sys/fs/cgroup/freezer
cgroup 0 0 0 - /sys/fs/cgroup/pids
cgroup 0 0 0 - /sys/fs/cgroup/rdma
cgroup 0 0 0 - /sys/fs/cgroup/cpuset
cgroup 0 0 0 - /sys/fs/cgroup/devices
cgroup 0 0 0 - /sys/fs/cgroup/memory
mqueue 0 0 0 - /dev/mqueue
debugfs 0 0 0 - /sys/kernel/debug
hugetlbfs 0 0 0 - /dev/hugepages
configfs 0 0 0 - /sys/kernel/config
tmpfs 1.8G 268K 1.8G 1% /tmp
tmpfs 256M 192K 256M 1% /tmp/jeedom
/dev/mmcblk2p1 488M 59M 429M 13% /boot
/dev/mmcblk2p2 28G 2.5G 25G 9% /var/log.hdd
/dev/zram0 49M 6.0M 39M 14% /var/log
tmpfs 360M 0 360M 0% /run/user/1000
Dois je faire la manip ou le swap est OK ?
