node -v
v16.20.2 ca c’est bon maintenant
0000|+ echo '*******************Begin of package installation******************'
0002|+ touch /tmp/jeedom_install_in_progress_z2m
0003|+ echo 1
0004|+ echo 2
0005|+ sudo chmod +x /var/www/html/core/class/../../plugins/z2m/resources/pre-install.sh
0006|+ sudo /var/www/html/core/class/../../plugins/z2m/resources/pre-install.sh
0007|Launch pre-install of z2m dependancy
0008|+ echo 3
0009|+ sudo chmod +x /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
0010|+ sudo /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
0011|+ echo Launch post-install of z2m dependancy
0012|Launch post-install of z2m dependancy
0013|+ realpath /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
0014|+ dirname /var/www/html/plugins/z2m/resources/post-install.sh
0015|+ BASEDIR=/var/www/html/plugins/z2m/resources
0016|+ [ -d /var/www/html/plugins/z2m/resources/zigbee2mqtt ]
0017|+ mkdir /var/www/html/plugins/z2m/resources/zigbee2mqtt
0018|+ git clone --depth 1 https://github.com/Koenkk/zigbee2mqtt.git /var/www/html/plugins/z2m/resources/zigbee2mqtt
0019|Cloning into '/var/www/html/plugins/z2m/resources/zigbee2mqtt'...
0020|+ cd /var/www/html/plugins/z2m/resources/zigbee2mqtt
0021|+ [ -f /var/www/html/plugins/z2m/resources/../data/wanted_z2m_version ]
0022|+ npm ci
0023|added 803 packages, and audited 804 packages in 29s
0024|89 packages are looking for funding
0025|run `npm fund` for details
0026|1 moderate severity vulnerability
0027|To address all issues, run:
0028|npm audit fix
0029|Run `npm audit` for details.
0030|+ npm run build
0031|> zigbee2mqtt@1.33.0 build
0032|> tsc && node index.js writehash
0033|+ chown www-data:www-data -R /var/www/html/plugins/z2m/resources/zigbee2mqtt
0034|+ echo 4
0035|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end z2m
0036|+ rm /tmp/jeedom_install_in_progress_z2m
0037|+ echo '*******************End of package installation******************'
0038|*******************End of package installation******************
Ca aussi je pense ?
Mais le demon ne veut pas demarrer et je ne sais pas ou se trouve la clé Conbee2 dans la liste…
j’ai un bandeau rouge des que je sauvegarde un port de controleur different avec indiqué :
500;internal server error
et puis quand je clique sur Interface z2m
[Ici] ca ne fonctionne pas non plus
Citation
