Hello a tous
Jeedom m’a proposé la maj 1.8.3 et j’ai beau la faire je reste en 1.8.2
j’ai ce code d’update
[2025-01-03 11:03:21] ****************************
[2025-01-03 11:03:21] * Upgrade TheengsGateway *
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 2 100 2 0 0 68 0 --:--:-- --:--:-- --:--:-- 71
[2025-01-03 11:03:22] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
[2025-01-03 11:03:22] Requirement already satisfied: TheengsGateway in /opt/TheengsGateway/lib/python3.9/site-packages (1.5.0)
[2025-01-03 11:03:22] Requirement already satisfied: bleak>=0.19.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (0.22.2)
[2025-01-03 11:03:22] Requirement already satisfied: bluetooth-clocks<1.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (0.2.0)
[2025-01-03 11:03:22] Requirement already satisfied: bluetooth-numbers<2.0,>=1.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (1.1.1)
[2025-01-03 11:03:22] Requirement already satisfied: importlib-metadata in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (8.0.0)
[2025-01-03 11:03:22] Requirement already satisfied: paho-mqtt<3.0.0,>=2.0.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (2.1.0)
[2025-01-03 11:03:22] Requirement already satisfied: pycryptodomex>=3.18.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (3.20.0)
[2025-01-03 11:03:22] Requirement already satisfied: TheengsDecoder>=1.7.8 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (1.8.3)
[2025-01-03 11:03:22] Requirement already satisfied: bluetooth-adapters>=0.15.3 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (0.19.3)
[2025-01-03 11:03:22] Requirement already satisfied: async-timeout<5,>=3.0.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from bleak>=0.19.0->TheengsGateway) (4.0.3)
[2025-01-03 11:03:22] Requirement already satisfied: dbus-fast<3,>=1.83.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from bleak>=0.19.0->TheengsGateway) (2.22.1)
[2025-01-03 11:03:22] Requirement already satisfied: typing-extensions>=4.7.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from bleak>=0.19.0->TheengsGateway) (4.12.2)
[2025-01-03 11:03:22] Requirement already satisfied: aiooui>=0.1.1 in /opt/TheengsGateway/lib/python3.9/site-packages (from bluetooth-adapters>=0.15.3->TheengsGateway) (0.1.6)
[2025-01-03 11:03:22] Requirement already satisfied: uart-devices>=0.1.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from bluetooth-adapters>=0.15.3->TheengsGateway) (0.1.0)
[2025-01-03 11:03:22] Requirement already satisfied: usb-devices>=0.4.5 in /opt/TheengsGateway/lib/python3.9/site-packages (from bluetooth-adapters>=0.15.3->TheengsGateway) (0.4.5)
[2025-01-03 11:03:22] Requirement already satisfied: zipp>=0.5 in /opt/TheengsGateway/lib/python3.9/site-packages (from importlib-metadata->TheengsGateway) (3.19.2)
[notice] A new release of pip is available: 24.1.1 -> 24.3.1
[notice] To update, run: python3 -m pip install --upgrade pip
[2025-01-03 11:03:23] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
[2025-01-03 11:03:23] Requirement already satisfied: TheengsDecoder in /opt/TheengsGateway/lib/python3.9/site-packages (1.8.3)
[2025-01-03 11:03:24] ***************************
[2025-01-03 11:03:24] * Install ended *
100 2 100 2 0 0 2 0 0:00:01 --:--:-- 0:00:01 2
Merci pour une eventuelle solution
et bonne année
C’est plus là qu’il fut mettre l’antenne a jour
Mips
Janvier 3, 2025, 10:09
3
D’après la seule info que vous donnez vous êtes déjà en 1.8.3
stanthewizzard:
sans problème, pas de solution possible
LOL
dans ce cas il y a un pb d’affichage ?
Mips
Janvier 3, 2025, 11:52
5
Je ne sais pas, affichage de quoi? Ou?
Je ne vois aucun de vos écrans d’ici…
Relire point 9 de la doc svp https://mips2648.github.io/jeedom-plugins-docs/tgw/fr_FR/#tocAnchor-1-15
j’ai litteralement la meme capture d’ecran que @lperenna
j’ai beau cliquer sur mise a jour
le log effectivement indique que tout va bien
mais l’affichage me met en boucle la maj 1.8.3
cela réponds à tes questions ? (on peut se tutoyer nous l’avons deja fait sur un autre thread)
Mips
Janvier 4, 2025, 2:18
7
ok, je peux avoir les logs et les autres infos demandées dans la doc du coup stp?
idéalement les logs lors de l’action « refresh » => le flèche bleue en face du numéro de version.
dans le log on devrait voir ce qu’il se passe
excuse moi je n’avais pas compris.
Alors en cliquant sur la fleche circulaire bleu en face de Version Gateway
je n’ai rien dans
tgw
tgw_45_update
C’est vide et si c’est bien là que je dois chercher ?
dois-je passer en debug ?
Bonjour.
Comment avez eu l’information qu’il y avait cette mise à jour ?
J’ai la même copie d’écran qu’ @lperenna mais pas de message pour faire cette mise à jour.
DigiH
Janvier 4, 2025, 3:44
11
@Mips
Cela pourrait-il avoir quelque chose à voir avec
committed 02:56PM - 04 Dec 24 UTC
et le changement de nom sans lettres majuscules?
Bien que cela ne pose pas de problème avec une installation pip normale, cela pourrait-il faire une différence avec le plug-in TGW?
Mips
Janvier 4, 2025, 6:01
12
Merci pour le lien; je vais lire ça asap.
edit:
C’est bien la cause merci.
pour info les installations sont bien fait via pip, le plugin ne fait rien de particulier concernant l’installation mais l’utilisation de pip pour récupérer les numéros de versions est impossible sur un pi0, c’est beaucoup trop lent.
Mips
Janvier 5, 2025, 7:04
14
Une nouvelle version est disponible en stable pour fixer le problème de détection de la version.
3 « J'aime »
chez moi ce matin avec la dernière version j’ai quand même reçu une notif de mise à jour de l’antenne.
[2025-01-03 11:03:32] *************************************
[2025-01-03 11:03:32] * Launch install of dependencies *
[2025-01-03 11:03:32] == Version Debian:11
[2025-01-03 11:03:32] == Version Python:3.9.2
[2025-01-03 11:03:32] Reading package lists...
[2025-01-03 11:03:33] Building dependency tree...
[2025-01-03 11:03:33] Reading state information...
[2025-01-03 11:03:35] curl is already the newest version (7.74.0-1.3+deb11u14).
[2025-01-03 11:03:35] 0 upgraded, 0 newly installed, 0 to remove and 179 not upgraded.
100 2 100 2 0 0 19 0 --:--:-- --:--:-- --:--:-- 19
[2025-01-03 11:03:35] Hit:1 http://security.debian.org bullseye-security InRelease
[2025-01-03 11:03:35] Hit:2 http://deb.debian.org/debian bullseye InRelease
[2025-01-03 11:03:36] Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
[2025-01-03 11:03:36] Get:4 http://deb.debian.org/debian bullseye-backports InRelease [49.0 kB]
[2025-01-03 11:03:36] Get:5 https://download.docker.com/linux/debian bullseye InRelease [43.3 kB]
[2025-01-03 11:03:36] Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
[2025-01-03 11:03:36] Hit:7 http://fi.mirror.armbian.de/apt buster InRelease
[2025-01-03 11:03:38] Fetched 136 kB in 3s (49.2 kB/s)
[2025-01-03 11:03:41] Reading package lists...
[2025-01-03 11:03:41] ********************************
[2025-01-03 11:03:41] * Install dependencies & venv *
100 2 100 2 0 0 36 0 --:--:-- --:--:-- --:--:-- 36
[2025-01-03 11:03:42] Reading package lists...
[2025-01-03 11:03:43] Building dependency tree...
[2025-01-03 11:03:43] Reading state information...
[2025-01-03 11:03:44] logrotate is already the newest version (3.18.0-2+deb11u2).
[2025-01-03 11:03:44] python3-pip is already the newest version (20.3.4-4+deb11u1).
[2025-01-03 11:03:44] python3 is already the newest version (3.9.2-3).
[2025-01-03 11:03:44] python3-venv is already the newest version (3.9.2-3).
[2025-01-03 11:03:44] 0 upgraded, 0 newly installed, 0 to remove and 179 not upgraded.
[2025-01-03 11:03:44] Reading package lists...
[2025-01-03 11:03:45] Building dependency tree...
[2025-01-03 11:03:45] Reading state information...
[2025-01-03 11:03:47] 0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 179 not upgraded.
[2025-01-03 11:03:47] Need to get 1039 kB of archives.
[2025-01-03 11:03:47] After this operation, 0 B of additional disk space will be used.
[2025-01-03 11:03:47] Get:1 http://security.debian.org bullseye-security/main arm64 bluez arm64 5.55-3.1+deb11u2 [1039 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
[2025-01-03 11:03:48] Fetched 1039 kB in 0s (4144 kB/s)
[2025-01-03 11:03:48] (Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 67752 files and directories currently installed.)
[2025-01-03 11:03:48] Preparing to unpack .../bluez_5.55-3.1+deb11u2_arm64.deb ...
[2025-01-03 11:03:48] Unpacking bluez (5.55-3.1+deb11u2) over (5.55-3.1+deb11u2) ...
[2025-01-03 11:03:49] Setting up bluez (5.55-3.1+deb11u2) ...
[2025-01-03 11:03:51] Processing triggers for man-db (2.9.4-2) ...
[2025-01-03 11:03:59] Processing triggers for dbus (1.12.28-0+deb11u1) ...
Requirement already satisfied: pip in /opt/TheengsGateway/lib/python3.9/site-packages (24.3.1)
Requirement already satisfied: setuptools in /opt/TheengsGateway/lib/python3.9/site-packages (75.6.0)
[2025-01-03 11:04:39] ****************************
[2025-01-03 11:04:39] * Install TheengsGateway *
100 2 100 2 0 0 39 0 --:--:-- --:--:-- --:--:-- 39
[2025-01-03 11:04:40] Requirement already satisfied: TheengsGateway in /opt/TheengsGateway/lib/python3.9/site-packages (1.5.0)
[2025-01-03 11:04:40] Requirement already satisfied: bleak>=0.19.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (0.22.3)
[2025-01-03 11:04:40] Requirement already satisfied: bluetooth-adapters>=0.15.3 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (0.20.2)
[2025-01-03 11:04:40] Requirement already satisfied: bluetooth-clocks<1.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (0.2.0)
[2025-01-03 11:04:40] Requirement already satisfied: bluetooth-numbers<2.0,>=1.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (1.1.2)
[2025-01-03 11:04:40] Requirement already satisfied: importlib-metadata in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (8.5.0)
[2025-01-03 11:04:40] Requirement already satisfied: paho-mqtt<3.0.0,>=2.0.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (2.1.0)
[2025-01-03 11:04:40] Requirement already satisfied: pycryptodomex>=3.18.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (3.21.0)
[2025-01-03 11:04:40] Requirement already satisfied: TheengsDecoder>=1.7.8 in /opt/TheengsGateway/lib/python3.9/site-packages (from TheengsGateway) (1.8.3)
[2025-01-03 11:04:40] Requirement already satisfied: async-timeout<5,>=3.0.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from bleak>=0.19.0->TheengsGateway) (4.0.3)
[2025-01-03 11:04:40] Requirement already satisfied: dbus-fast<3,>=1.83.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from bleak>=0.19.0->TheengsGateway) (2.24.4)
[2025-01-03 11:04:40] Requirement already satisfied: typing-extensions>=4.7.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from bleak>=0.19.0->TheengsGateway) (4.12.2)
[2025-01-03 11:04:40] Requirement already satisfied: aiooui>=0.1.1 in /opt/TheengsGateway/lib/python3.9/site-packages (from bluetooth-adapters>=0.15.3->TheengsGateway) (0.1.7)
[2025-01-03 11:04:40] Requirement already satisfied: uart-devices>=0.1.0 in /opt/TheengsGateway/lib/python3.9/site-packages (from bluetooth-adapters>=0.15.3->TheengsGateway) (0.1.0)
[2025-01-03 11:04:40] Requirement already satisfied: usb-devices>=0.4.5 in /opt/TheengsGateway/lib/python3.9/site-packages (from bluetooth-adapters>=0.15.3->TheengsGateway) (0.4.5)
[2025-01-03 11:04:40] Requirement already satisfied: zipp>=3.20 in /opt/TheengsGateway/lib/python3.9/site-packages (from importlib-metadata->TheengsGateway) (3.21.0)
[2025-01-03 11:04:40] ***************************
[2025-01-03 11:04:40] * Install ended *
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
100 2 0 2 0 0 0 0 --:--:-- 0:00:02 --:--:-- 0
Mips
Janvier 6, 2025, 12:03
17
Je ne sais pas de quoi vous parlez ni pourquoi vous montrez un log d’installation d’antenne (c’est totalement hors sujet), avec la dernière version de quoi?
du plugin en question tgw
Mips
Janvier 6, 2025, 12:10
19
Il va falloir communiquer avec plus que des demi phrases et fournir plus d’info si vous espérez de l’aide.
je reçois une notif de mise à jour de l’antenne (voir message), je pensais que la dernière version du plugin inclurait cette mise à jour, je me trompe surement.
Comment puis je faire cette mise à jour ?
Mips
Janvier 6, 2025, 12:18
21
Suffit de lire le changelog pour savoir ce qu’il se trouve dans la mise à jour
En allant dans la page de config de l’équipement
