je viens de tester chez moi
Résumé
"result":[
"data":[
"ep_id":5,
"label":"Batterie faible",
"name":"battery_warning",
"signal_id":5,
"ui":{
"access":"r",
"display":"warning",
"icon_range":[
0,
10
"icon_url":"/resources/images/home/pictos/batt_0.png",
"status_text_range":[
"Batterie critique",
"Batterie faible"
"unit":"%"
"value":null,
"value_type":"int"
"ep_id":2,
"history":[
"timestamp":1562420228,
"value":"2"
"timestamp":1564681003,
"value":"2"
"timestamp":1565425735,
"value":"2"
"timestamp":1565428754,
"value":"2"
"timestamp":1565438999,
"value":"1"
"timestamp":1565439029,
"value":"2"
"timestamp":1565447142,
"value":"2"
"timestamp":1565451641,
"value":"2"
"timestamp":1565994606,
"value":"2"
"timestamp":1566022892,
"value":"1"
"timestamp":1566022893,
"value":"2"
"timestamp":1566210160,
"value":"2"
"timestamp":1566311218,
"value":"2"
"timestamp":1566486549,
"value":"2"
"timestamp":1566837857,
"value":"2"
"timestamp":1566903876,
"value":"2"
"timestamp":1567005781,
"value":"2"
"timestamp":1567166036,
"value":"1"
"value":"2"
"timestamp":1567166043,
"value":"1"
"timestamp":1567166052,
"value":"2"
"timestamp":1567870699,
"value":"2"
"timestamp":1569002374,
"value":"2"
"timestamp":1569012721,
"value":"2"
"timestamp":1569053834,
"value":"2"
"timestamp":1570893871,
"value":"1"
"timestamp":1570893874,
"value":"2"
"timestamp":1592917885,
"value":"2"
"timestamp":1592932377,
"value":"2"
"timestamp":1593332949,
"value":"2"
"label":"Bouton appuyé",
"name":"pushed",
"signal_id":2,
"ui":{
"access":"r",
"display":"none",
"icon_range":[
1,
2,
3,
4
"icon_url":"/resources/images/home/pictos/kfb_button_%.png",
"range":[
0,
1,
2,
3
null,
"Alarme principale",
"Désactivation",
"Alarme secondaire"
"value":null,
"value_type":"int"
"ep_type":"slot",
"group":{
"icon_url":"",
"label":""
"icon_url":"/resources/images/home/pictos/telecommande.png",
"label":"FREEBOX - Télécommande",
"node_id":10,
"type":"alarm_remote"
"success":true
la batterie remonte une valeur nulle
"ep_id":5,
"signal_id":5,
"ui":{
"access":"r",
"icon_range":[
0,
10
"Batterie faible"
"unit":"%"
"value":null,
"value_type":"int"
et cela correspond bien a ce qui est dans jeedom
- logicalId est bien égal eq_id = 5
