Dépendances sur antenne BLEA - buster
A priori il manque une version de pip compatible pour l’instant
*			 Installation des dépendances			 *
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
libffi-dev is already the newest version (3.2.1-9).
libopenjp2-7 is already the newest version (2.3.0-2).
libopenjp2-7 set to manually installed.
libssl-dev is already the newest version (1.1.1c-1).
libtiff5 is already the newest version (4.0.10-4).
libtiff5 set to manually installed.
python3-dev is already the newest version (3.7.3-1).
python3-dev set to manually installed.
python3-setuptools is already the newest version (40.8.0-1).
python3-setuptools set to manually installed.
rfkill is already the newest version (2.33.1-0.1).
rfkill set to manually installed.
bluetooth is already the newest version (5.50-1+rpt1).
The following additional packages will be installed:
  libatlas3-base libbluetooth3 libgfortran5 python3-certifi python3-chardet
  python3-idna python3-urllib3
Suggested packages:
  libatlas-doc liblapack-doc python3-openssl python3-socks python3-wxgtk3.0
  | python3-wxgtk
  libatlas-base-dev libatlas3-base libbluetooth-dev libbluetooth3 libgfortran5
  python3-certifi python3-chardet python3-idna python3-pyudev python3-requests
  python3-serial python3-urllib3
0 upgraded, 12 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,458 kB/6,380 kB of archives.
After this operation, 36.0 MB of additional disk space will be used.
Get:1 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf libatlas-base-dev armhf 3.10.3-8+rpi1 [2,966 kB]
Get:2 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf python3-certifi all 2018.8.24-1 [140 kB]
Get:3 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf python3-chardet all 3.0.4-3 [80.5 kB]
Get:4 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf python3-pyudev all 0.21.0-1 [40.2 kB]
Get:5 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf python3-urllib3 all 1.24.1-1 [97.1 kB]
Get:6 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf python3-requests all 2.21.0-1 [66.9 kB]
Get:7 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf python3-serial all 3.4-4 [67.6 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 3,458 kB in 12s (281 kB/s)
Selecting previously unselected package libgfortran5:armhf.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 58010 files and directories currently installed.)
Preparing to unpack .../00-libgfortran5_8.3.0-6+rpi1_armhf.deb ...
Unpacking libgfortran5:armhf (8.3.0-6+rpi1) ...
Selecting previously unselected package libatlas3-base:armhf.
Preparing to unpack .../01-libatlas3-base_3.10.3-8+rpi1_armhf.deb ...
Unpacking libatlas3-base:armhf (3.10.3-8+rpi1) ...
Selecting previously unselected package libatlas-base-dev:armhf.
Preparing to unpack .../02-libatlas-base-dev_3.10.3-8+rpi1_armhf.deb ...
Unpacking libatlas-base-dev:armhf (3.10.3-8+rpi1) ...
Selecting previously unselected package libbluetooth3:armhf.
Preparing to unpack .../03-libbluetooth3_5.50-1+rpt1_armhf.deb ...
Unpacking libbluetooth3:armhf (5.50-1+rpt1) ...
Selecting previously unselected package libbluetooth-dev:armhf.
Preparing to unpack .../04-libbluetooth-dev_5.50-1+rpt1_armhf.deb ...
Unpacking libbluetooth-dev:armhf (5.50-1+rpt1) ...
Selecting previously unselected package python3-certifi.
Preparing to unpack .../05-python3-certifi_2018.8.24-1_all.deb ...
Unpacking python3-certifi (2018.8.24-1) ...
Selecting previously unselected package python3-chardet.
Preparing to unpack .../06-python3-chardet_3.0.4-3_all.deb ...
Unpacking python3-chardet (3.0.4-3) ...
Selecting previously unselected package python3-idna.
Preparing to unpack .../07-python3-idna_2.6-1_all.deb ...
Unpacking python3-idna (2.6-1) ...
Selecting previously unselected package python3-pyudev.
Preparing to unpack .../08-python3-pyudev_0.21.0-1_all.deb ...
Unpacking python3-pyudev (0.21.0-1) ...
Selecting previously unselected package python3-urllib3.
Preparing to unpack .../09-python3-urllib3_1.24.1-1_all.deb ...
Unpacking python3-urllib3 (1.24.1-1) ...
Selecting previously unselected package python3-requests.
Preparing to unpack .../10-python3-requests_2.21.0-1_all.deb ...
Unpacking python3-requests (2.21.0-1) ...
Selecting previously unselected package python3-serial.
Preparing to unpack .../11-python3-serial_3.4-4_all.deb ...
Unpacking python3-serial (3.4-4) ...
Setting up python3-serial (3.4-4) ...
Setting up python3-chardet (3.0.4-3) ...
Setting up python3-certifi (2018.8.24-1) ...
Setting up python3-idna (2.6-1) ...
Setting up libgfortran5:armhf (8.3.0-6+rpi1) ...
Setting up python3-urllib3 (1.24.1-1) ...
Setting up libbluetooth3:armhf (5.50-1+rpt1) ...
Setting up python3-pyudev (0.21.0-1) ...
Setting up libatlas3-base:armhf (3.10.3-8+rpi1) ...
update-alternatives: using /usr/lib/arm-linux-gnueabihf/atlas/libblas.so.3 to provide /usr/lib/arm-linux-gnueabihf/libblas.so.3 (libblas.so.3-arm-linux-gnueabihf) in auto mode
update-alternatives: using /usr/lib/arm-linux-gnueabihf/atlas/liblapack.so.3 to provide /usr/lib/arm-linux-gnueabihf/liblapack.so.3 (liblapack.so.3-arm-linux-gnueabihf) in auto mode
Setting up libatlas-base-dev:armhf (3.10.3-8+rpi1) ...
update-alternatives: using /usr/lib/arm-linux-gnueabihf/atlas/libblas.so to provide /usr/lib/arm-linux-gnueabihf/libblas.so (libblas.so-arm-linux-gnueabihf) in auto mode
update-alternatives: using /usr/lib/arm-linux-gnueabihf/atlas/liblapack.so to provide /usr/lib/arm-linux-gnueabihf/liblapack.so (liblapack.so-arm-linux-gnueabihf) in auto mode
Setting up python3-requests (2.21.0-1) ...
Setting up libbluetooth-dev:armhf (5.50-1+rpt1) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for libc-bin (2.28-10+rpi1) ...
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/171 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 58514 files and directories currently installed.)
Preparing to unpack .../python3-pip_18.1-5+rpt1_all.deb ...
Unpacking python3-pip (18.1-5+rpt1) over (18.1-5+rpt1) ...
Setting up python3-pip (18.1-5+rpt1) ...
  File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 583, in _build_master
    ws.require(__requires__)
  File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 900, in require
    needed = self.resolve(parse_requirements(requirements))
  File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 791, in resolve
    raise VersionConflict(dist, req).with_context(dependent_req)
pkg_resources.VersionConflict: (pip 18.1 (/usr/lib/python3/dist-packages), Requirement.parse('pip==9.0.1'))
During handling of the above exception, another exception occurred:
  File "/usr/local/bin/pip3", line 6, in <module>
    from pkg_resources import load_entry_point
  File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 3191, in <module>
    @_call_aside
  File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 3175, in _call_aside
    f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 3204, in _initialize_master_working_set
    working_set = WorkingSet._build_master()
  File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 585, in _build_master
    return cls._build_from_requirements(__requires__)
  File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 598, in _build_from_requirements
    dists = ws.resolve(reqs, Environment())
  File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 786, in resolve
    raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'pip==9.0.1' distribution was not found and is required by the application
git is already the newest version (1:2.20.1-2).
libglib2.0-dev is already the newest version (2.58.3-2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    @_call_aside
    f(*args, **kwargs)
    @_call_aside
    f(*args, **kwargs)
    @_call_aside
    f(*args, **kwargs)
    @_call_aside
    f(*args, **kwargs)
    @_call_aside
    f(*args, **kwargs)
    @_call_aside
    f(*args, **kwargs)
Please do not run git as root, your regular user account is enough :)
If you need to run git with root rights for some other application than
what comes preinstalled on this image you can remove this sanity check:
    sudo rm /root/bin/git
You might have to restart your login session after doing that.
/home/root/blead/resources/install_apt.sh: line 28: cd: /tmp/bluepy: No such file or directory
python3: can't open file 'setup.py': [Errno 2] No such file or directory
rm: cannot remove '/tmp/bluepy': No such file or directory
    @_call_aside
    f(*args, **kwargs)
    @_call_aside
    f(*args, **kwargs)
*			 Installation terminée					*
Et Ludo doit mettre une perruque et se lustrer la boule pour avoir des détails ?
T’as le droit d’être un peu bavard et expliquer un peu. Être beta testeur ça se limite pas a copier coller un log.
Pour info le script marche en buster. C’est pour ça que la c’est vraiment abusé ton raccourci
Tu veux que je précise qu’à priori le script trouve une version de pip 18.1 mais que les dépendances sont strictement fixées à 9.0.1 ???
Je ne suis même pas certain que ce soit en lien avec le script de Ludo, mais juste avec les packages en prérequis… D’où le fait que le message soit plus là à titre informatif qu’en attende d’une solution
Pour le reste, il n’y a rien de spécifique un bête PI3 avec octopi/octoprint, migré sur buster, à jour coté apt…
OctoPrint version : 1.3.11
OctoPi version    : 0.16.0
A l’inverse, si tu dis que ça marche, dans quel cas chez toi ?
Tu vois d’un coup tu donnes bien plus de détails.
A commencer que tes sur un pi donc pas sur une debian mais raspbian. Bon est-ce une image octoprint, ça on le saura au prochain épisode.
Que c’est pas un buster clean mais suite à un upgrade de distrib, ce qui est rarement conseillé … et on voit pour quoi.
Bref d’un ‹ blea marche pas sur buster ›, c’est bien plus réduit comme cas.
Et vu ton cas, je laisse Ludo voir mais ça mériterait un test sur un buster propre et non upgrade
Essaye de directement fournir le plus d’informations des le début la prochaine fois et précis aussi dans les titres
Bon je suis reparti d’une installation directement sous buster pour octoprint :
De base ça bloque sur la récupération du git
pi@octopi:/tmp $ sudo git clone https://github.com/sarakha63/bluepy.git
[sudo] password for pi:
Et ça déroule la suite comme si tout allais bien…
Donc soit il faut faire le git sans le sudo, soit virer le fichier comme indiqué…
Après modif locale et lancement manuel, ça passe jusqu’au bout
J’ai déjà vu plusieurs personne avec ce problème sur le forum (même sous stretch) mais je n’ai jamais compris d’où venait leur version… mais pour moi ce n’est pas un cas « buster »
Perso, a chaque fois que j’ai installé une debian ou raspbian (stretch), je n’avais pas ce /root/bin/git et l’install des dépendances de BLEA passaient sans soucis.
stefane26 a testé aussi (sous stretch) et confirme que ça résoud son souci…
Par exemple,je viens de déployer une image buster officielle sur un pi3 et c’est pas présent à la base
Mais c’est clairement contenu dans l’image octopi.
Donc ce n’est pas Debian Buster (qui est l’officielle Buster, rendons à Debian les jouets Pixar)
Ce n’est pas Raspbian Buster
C’est l’image Octopi
Et si ludo doit s’amuser à donner un script pour tous les jouets qui s’amusent à faire des bizarreries sur leur OS, on peut l’inscrire au premier asile venu
Certes, gérer toutes les images c’est difficile, mais lancer le git clone sans le sudo, ne doit pas changer beaucoup le résultat sur l’image officielle, mais ça rends octopi compatible… Ainsi que toutes les autres distrib qui disposent de ce fichier à cet endroit. Vu le message d’erreur de git, ça doit être un truc assez courant pour que ça donne un message
