OK @Mips et merci pour cette explication de texte. Je dormirai moins c… ce soir
Ci dessous les log demandés.
Je viens de voir que dans les log update j’ai une ligne « Package ‹ python3-serial › is not installed, so not removed »
Est ce la ou une des causes possibles ?
Voila les log zegbee_update pour les dépendances
Merci pour votre aide
Launch install of zigbee dependancy
Hit:1 http://security.debian.org/debian-security stretch/updates InRelease
Ign:2 http://ftp.uk.debian.org/debian stretch InRelease
Hit:3 http://ftp.uk.debian.org/debian stretch-updates InRelease
Hit:4 http://ftp.uk.debian.org/debian stretch Release
Hit:5 https://deb.nodesource.com/node_14.x stretch InRelease
Ign:6 https://oph.mdrjr.net/meveric all InRelease
Ign:7 https://oph.mdrjr.net/meveric stretch InRelease
Err:9 https://oph.mdrjr.net/meveric all Release
server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
Err:10 https://oph.mdrjr.net/meveric stretch Release
Reading package lists...
E: The repository 'https://oph.mdrjr.net/meveric all Release' does no longer have a Release file.
E: The repository 'https://oph.mdrjr.net/meveric stretch Release' does no longer have a Release file.
Cannot uninstall requirement serial, not installed
Building dependency tree...
Reading state information...
Package 'python3-serial' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 160 not upgraded.
python3-setuptools is already the newest version (33.1.1-1).
python3 is already the newest version (3.5.3-1).
python3-dev is already the newest version (3.5.3-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.12.4-1).
python3-pip is already the newest version (9.0.1-2+deb9u2).
Requirement already up-to-date: wheel in /usr/local/lib/python3.5/dist-packages
Collecting pyserial
Using cached https://files.pythonhosted.org/packages/07/bc/587a445451b253b285629263eb51c2d8e9bcea4fc97826266d186f96f558/pyserial-3.5-py2.py3-none-any.whl
Installing collected packages: pyserial
Successfully installed pyserial-3.5
Collecting zigpy
Using cached https://files.pythonhosted.org/packages/a6/f4/8ce902ed23c801a6a1d154da20f235bd83219044cdb673c4f882147f6e75/zigpy-0.38.0-py3-none-any.whl
Collecting pycryptodome (from zigpy)
Using cached https://files.pythonhosted.org/packages/64/ab/f2b4059ddf59bffbdbb4bdb60a6729c6c1de5eea1ef186d5a633ae12db3b/pycryptodome-3.11.0.tar.gz
Collecting crccheck (from zigpy)
Using cached https://files.pythonhosted.org/packages/df/4c/6937c142a315edc436e223aa936a57dd846751b3be37f43da0d9037f630b/crccheck-1.0-py3-none-any.whl
Collecting aiosqlite>=0.16.0 (from zigpy)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy)
Collecting bellows
Using cached https://files.pythonhosted.org/packages/c4/1e/cbf73c01f64c7d4709bb8fcf5eb53850ddbd2ef133677ed37f2764c2c54e/bellows-0.28.0-py3-none-any.whl
Collecting pure-pcapy3==1.0.1 (from bellows)
Using cached https://files.pythonhosted.org/packages/82/09/37b4f0200cd8ad359c553ac87cd068fe7cebb24f00e59ee0f5218f14b389/pure-pcapy3-1.0.1.tar.gz
Collecting zigpy>=0.37.0 (from bellows)
Collecting dataclasses; python_version < "3.7" (from bellows)
Using cached https://files.pythonhosted.org/packages/26/2f/1095cdc2868052dd1e64520f7c0d5c8c550ad297e944e641dbf1ffbb9a5d/dataclasses-0.6-py3-none-any.whl
Requirement already up-to-date: pyserial in /usr/local/lib/python3.5/dist-packages (from bellows)
Collecting click-log>=0.2.1 (from bellows)
Using cached https://files.pythonhosted.org/packages/38/52/a9dbb622f40ceeb09df141d855062cc9fbb38011f0ad8caee0cd840f399c/click_log-0.3.2-py2.py3-none-any.whl
Collecting pyserial-asyncio (from bellows)
Using cached https://files.pythonhosted.org/packages/27/24/c820cf15f87f7b164e83710c1852d4f900d9793961579e5ef64189bc0c10/pyserial_asyncio-0.6-py3-none-any.whl
Collecting voluptuous (from bellows)
Using cached https://files.pythonhosted.org/packages/c0/2c/ccbeb25364e3e0c5e4522f13d66e2fc639bb4d4ecdf73be0959552cbecb4/voluptuous-0.12.2.tar.gz
Collecting click (from bellows)
Using cached https://files.pythonhosted.org/packages/d2/3d/fa76db83bf75c4f8d338c2fd15c8d33fdd7ad23a9b5e57eb6c5de26b430e/click-7.1.2-py2.py3-none-any.whl
Requirement already up-to-date: setuptools in /usr/local/lib/python3.5/dist-packages (from pure-pcapy3==1.0.1->bellows)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.37.0->bellows)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.37.0->bellows) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.37.0->bellows)
Collecting zha-quirks
Using cached https://files.pythonhosted.org/packages/ec/fb/b4d8c012a072231132b0e91c231060eb0ee4d1e8968f1891d2af41bf4623/zha_quirks-0.0.62-py3-none-any.whl
Collecting zigpy>=0.32.0 (from zha-quirks)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.32.0->zha-quirks)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.32.0->zha-quirks) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.32.0->zha-quirks)
Collecting zigpy_znp
Using cached https://files.pythonhosted.org/packages/34/02/3f51c5071ed3c926a051d2dac0c44525ce7bc0846b2dc40d3f02616485b9/zigpy_znp-0.3.0-py3-none-any.whl
Collecting async-timeout (from zigpy_znp)
Using cached https://files.pythonhosted.org/packages/e1/1e/5a4441be21b0726c4464f3f23c8b19628372f606755a9d2e46c187e65ec4/async_timeout-3.0.1-py3-none-any.whl
Collecting coloredlogs (from zigpy_znp)
Using cached https://files.pythonhosted.org/packages/a7/06/3d6badcf13db419e25b07041d9c7b4a2c331d3f4e7134445ec5df57714cd/coloredlogs-15.0.1-py2.py3-none-any.whl
Collecting zigpy>=0.25.0 (from zigpy_znp)
Collecting voluptuous (from zigpy_znp)
Collecting pyserial-asyncio (from zigpy_znp)
Collecting humanfriendly>=9.1 (from coloredlogs->zigpy_znp)
Using cached https://files.pythonhosted.org/packages/f0/0f/310fb31e39e2d734ccaa2c0fb981ee41f7bd5056ce9bc29b2248bd569169/humanfriendly-10.0-py2.py3-none-any.whl
Collecting crccheck (from zigpy>=0.25.0->zigpy_znp)
Collecting aiohttp (from zigpy>=0.25.0->zigpy_znp)
Using cached https://files.pythonhosted.org/packages/9d/6c/429faa2d2f73973189ca0cfe141ff703417a5eebe18d78e6b25b70db0a34/aiohttp-3.6.3.tar.gz
Collecting pycryptodome (from zigpy>=0.25.0->zigpy_znp)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.25.0->zigpy_znp)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.25.0->zigpy_znp) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.25.0->zigpy_znp)
Collecting zigpy-xbee
Using cached https://files.pythonhosted.org/packages/77/a1/8f6360ba552c3ed0facd9cbc42bd833098842b5e80b628a89dd65268b638/zigpy_xbee-0.14.0-py3-none-any.whl
Collecting zigpy>=0.23.0 (from zigpy-xbee)
Collecting pyserial-asyncio (from zigpy-xbee)
Collecting crccheck (from zigpy>=0.23.0->zigpy-xbee)
Collecting voluptuous (from zigpy>=0.23.0->zigpy-xbee)
Collecting pycryptodome (from zigpy>=0.23.0->zigpy-xbee)
Collecting aiohttp (from zigpy>=0.23.0->zigpy-xbee)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.23.0->zigpy-xbee)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.23.0->zigpy-xbee) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.23.0->zigpy-xbee)
Collecting zigpy-deconz
Using cached https://files.pythonhosted.org/packages/7a/59/886522b628e3a4f22bf4ae542e621a57ba601d073a419427711c23bc804d/zigpy_deconz-0.13.0-py3-none-any.whl
Collecting pyserial-asyncio (from zigpy-deconz)
Collecting zigpy>=0.37.0 (from zigpy-deconz)
Requirement already up-to-date: pyserial in /usr/local/lib/python3.5/dist-packages (from pyserial-asyncio->zigpy-deconz)
Collecting pycryptodome (from zigpy>=0.37.0->zigpy-deconz)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.37.0->zigpy-deconz)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.37.0->zigpy-deconz) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.37.0->zigpy-deconz)
Collecting zigpy-zigate
Using cached https://files.pythonhosted.org/packages/08/65/c1c4b074b4d202587639d2efb066a792ad69d147b8639c3560e2308aff99/zigpy-zigate-0.7.4.tar.gz
Collecting pyserial-asyncio (from zigpy-zigate)
Collecting pyusb (from zigpy-zigate)
Using cached https://files.pythonhosted.org/packages/b5/28/b857ac783257f142932b23379d761a3d9becf6deecf5d14075ec19bdb890/pyusb-1.1.1-py3-none-any.whl
Collecting zigpy>=0.22.2 (from zigpy-zigate)
Requirement already up-to-date: pyserial in /usr/local/lib/python3.5/dist-packages (from pyserial-asyncio->zigpy-zigate)
Collecting crccheck (from zigpy>=0.22.2->zigpy-zigate)
Collecting pycryptodome (from zigpy>=0.22.2->zigpy-zigate)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.22.2->zigpy-zigate)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.22.2->zigpy-zigate) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.22.2->zigpy-zigate)
Requirement already up-to-date: tornado in /usr/local/lib/python3.5/dist-packages
grep: /usr/local/lib/python3.7/dist-packages/bellows/zigbee/application.py: No such file or directory
/var/www/html/plugins/zigbee/core/class/../../resources/install_apt.sh: line 39: [: -eq: unary operator expected
Everything is successfully installed!
et le zigbeed_1 pour le démon
[2021-10-11 17:41:12][INFO] : Start zigbeed
[2021-10-11 17:41:12][INFO] : Log level : debug
[2021-10-11 17:41:12][INFO] : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-11 17:41:12][INFO] : Device : Array
[2021-10-11 17:41:12][INFO] : Apikey : HAd52NjMUiQWX0Ia8lSngRIgt636yl78
[2021-10-11 17:41:12][INFO] : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2021-10-11 17:41:12][INFO] : Cycle : 0.3
[2021-10-11 17:41:12][INFO] : Controller : ezsp
[2021-10-11 17:41:12][INFO] : Channel : 15
[2021-10-11 17:41:12][INFO] : Data folder : /var/www/html/plugins/zigbee/data/1
[2021-10-11 17:41:12][INFO] : Device folder : /var/www/html/plugins/zigbee/data/device
[2021-10-11 17:41:12][INFO] : Folder OTA : None
[2021-10-11 17:41:12][INFO] : Zigpy advance configuration file : None
File "/var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py", line 235, in <module>
from bellows.zigbee.application import ControllerApplication
ImportError: No module named 'bellows'
[2021-10-11 19:08:29][INFO] : Start zigbeed
[2021-10-11 19:08:29][INFO] : Log level : debug
[2021-10-11 19:08:29][INFO] : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-11 19:08:29][INFO] : Device : pizigate:/dev/serial
[2021-10-11 19:08:29][INFO] : Apikey : HAd52NjMUiQWX0Ia8lSngRIgt636yl78
[2021-10-11 19:08:29][INFO] : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2021-10-11 19:08:29][INFO] : Cycle : 0.3
[2021-10-11 19:08:29][INFO] : Controller : ezsp
[2021-10-11 19:08:29][INFO] : Channel : 15
[2021-10-11 19:08:29][INFO] : Data folder : /var/www/html/plugins/zigbee/data/1
[2021-10-11 19:08:29][INFO] : Device folder : /var/www/html/plugins/zigbee/data/device
[2021-10-11 19:08:29][INFO] : Folder OTA : None
[2021-10-11 19:08:29][INFO] : Zigpy advance configuration file : None
[2021-10-11 19:39:12][INFO] : Start zigbeed
[2021-10-11 19:39:12][INFO] : Log level : debug
[2021-10-11 19:39:12][INFO] : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-11 19:39:12][INFO] : Device : auto
[2021-10-11 19:39:12][INFO] : Apikey : HAd52NjMUiQWX0Ia8lSngRIgt636yl78
[2021-10-11 19:39:12][INFO] : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2021-10-11 19:39:12][INFO] : Cycle : 0.3
[2021-10-11 19:39:12][INFO] : Controller : ezsp
[2021-10-11 19:39:12][INFO] : Channel : 15
[2021-10-11 19:39:12][INFO] : Data folder : /var/www/html/plugins/zigbee/data/1
[2021-10-11 19:39:12][INFO] : Device folder : /var/www/html/plugins/zigbee/data/device
[2021-10-11 19:39:12][INFO] : Folder OTA : None
[2021-10-11 19:39:12][INFO] : Zigpy advance configuration file : None
[2021-10-11 20:40:23][INFO] : Start zigbeed
[2021-10-11 20:40:23][INFO] : Log level : debug
[2021-10-11 20:40:23][INFO] : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-11 20:40:23][INFO] : Device : /dev/ttyUSB1
[2021-10-11 20:40:23][INFO] : Apikey : HAd52NjMUiQWX0Ia8lSngRIgt636yl78
[2021-10-11 20:40:23][INFO] : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2021-10-11 20:40:23][INFO] : Cycle : 0.3
[2021-10-11 20:40:23][INFO] : Controller : ezsp
[2021-10-11 20:40:23][INFO] : Channel : 15
[2021-10-11 20:40:23][INFO] : Data folder : /var/www/html/plugins/zigbee/data/1
[2021-10-11 20:40:23][INFO] : Device folder : /var/www/html/plugins/zigbee/data/device
[2021-10-11 20:40:23][INFO] : Folder OTA : None
[2021-10-11 20:40:23][INFO] : Zigpy advance configuration file : None
[2021-10-11 20:43:32][INFO] : Start zigbeed
[2021-10-11 20:43:32][INFO] : Log level : debug
[2021-10-11 20:43:32][INFO] : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-11 20:43:32][INFO] : Device : /dev/ttyUSB1
[2021-10-11 20:43:32][INFO] : Apikey : HAd52NjMUiQWX0Ia8lSngRIgt636yl78
[2021-10-11 20:43:32][INFO] : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2021-10-11 20:43:32][INFO] : Cycle : 0.3
[2021-10-11 20:43:32][INFO] : Controller : ezsp
[2021-10-11 20:43:32][INFO] : Channel : 15
[2021-10-11 20:43:32][INFO] : Data folder : /var/www/html/plugins/zigbee/data/1
[2021-10-11 20:43:32][INFO] : Device folder : /var/www/html/plugins/zigbee/data/device
[2021-10-11 20:43:32][INFO] : Folder OTA : None
[2021-10-11 20:43:32][INFO] : Zigpy advance configuration file : None
[2021-10-11 20:46:57][INFO] : Start zigbeed
[2021-10-11 20:46:57][INFO] : Log level : debug
[2021-10-11 20:46:57][INFO] : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-11 20:46:57][INFO] : Device : /dev/ttyUSB1
[2021-10-11 20:46:57][INFO] : Apikey : HAd52NjMUiQWX0Ia8lSngRIgt636yl78
[2021-10-11 20:46:57][INFO] : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2021-10-11 20:46:57][INFO] : Cycle : 0.3
[2021-10-11 20:46:57][INFO] : Controller : ezsp
[2021-10-11 20:46:57][INFO] : Channel : 15
[2021-10-11 20:46:57][INFO] : Data folder : /var/www/html/plugins/zigbee/data/1
[2021-10-11 20:46:57][INFO] : Device folder : /var/www/html/plugins/zigbee/data/device
[2021-10-11 20:46:57][INFO] : Folder OTA : None
[2021-10-11 20:46:57][INFO] : Zigpy advance configuration file : None
[2021-10-11 20:57:49][INFO] : Start zigbeed
[2021-10-11 20:57:49][INFO] : Log level : debug
[2021-10-11 20:57:49][INFO] : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-11 20:57:49][INFO] : Device : /dev/ttyUSB1
[2021-10-11 20:57:49][INFO] : Apikey : HAd52NjMUiQWX0Ia8lSngRIgt636yl78
[2021-10-11 20:57:49][INFO] : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2021-10-11 20:57:49][INFO] : Cycle : 0.3
[2021-10-11 20:57:49][INFO] : Controller : ezsp
[2021-10-11 20:57:49][INFO] : Channel : 15
[2021-10-11 20:57:49][INFO] : Data folder : /var/www/html/plugins/zigbee/data/1
[2021-10-11 20:57:49][INFO] : Device folder : /var/www/html/plugins/zigbee/data/device
[2021-10-11 20:57:49][INFO] : Folder OTA : None
[2021-10-11 20:57:49][INFO] : Zigpy advance configuration file : None
usage: zigbeed.py [-h] [--device DEVICE] [--loglevel LOGLEVEL]
[--callback CALLBACK] [--apikey APIKEY] [--cycle CYCLE]
[--pid PID] [--controller CONTROLLER]
[--sub_controller SUB_CONTROLLER]
[--data_folder DATA_FOLDER] [--device_folder DEVICE_FOLDER]
[--socketport SOCKETPORT] [--channel CHANNEL]
[--folder_OTA FOLDER_OTA]
[--zigpy_advance_config ZIGPY_ADVANCE_CONFIG]
zigbeed.py: error: argument --device: expected one argument
[2021-10-11 21:13:56][INFO] : Start zigbeed
[2021-10-11 21:13:56][INFO] : Log level : debug
[2021-10-11 21:13:56][INFO] : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-11 21:13:56][INFO] : Device : /dev/ttyUSB1
[2021-10-11 21:13:56][INFO] : Apikey : HAd52NjMUiQWX0Ia8lSngRIgt636yl78
[2021-10-11 21:13:56][INFO] : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2021-10-11 21:13:56][INFO] : Cycle : 0.3
[2021-10-11 21:13:56][INFO] : Controller : ezsp
[2021-10-11 21:13:56][INFO] : Channel : 15
[2021-10-11 21:13:56][INFO] : Data folder : /var/www/html/plugins/zigbee/data/1
[2021-10-11 21:13:56][INFO] : Device folder : /var/www/html/plugins/zigbee/data/device
[2021-10-11 21:13:56][INFO] : Folder OTA : None
[2021-10-11 21:13:56][INFO] : Zigpy advance configuration file : None
[2021-10-11 21:22:50][INFO] : Start zigbeed
[2021-10-11 21:22:50][INFO] : Log level : debug
[2021-10-11 21:22:50][INFO] : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-11 21:22:50][INFO] : Device : /dev/ttyUSB1
[2021-10-11 21:22:50][INFO] : Apikey : HAd52NjMUiQWX0Ia8lSngRIgt636yl78
[2021-10-11 21:22:50][INFO] : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2021-10-11 21:22:50][INFO] : Cycle : 0.3
[2021-10-11 21:22:50][INFO] : Controller : ezsp
[2021-10-11 21:22:50][INFO] : Channel : 15
[2021-10-11 21:22:50][INFO] : Data folder : /var/www/html/plugins/zigbee/data/1
[2021-10-11 21:22:50][INFO] : Device folder : /var/www/html/plugins/zigbee/data/device
[2021-10-11 21:22:50][INFO] : Folder OTA : None
[2021-10-11 21:22:50][INFO] : Zigpy advance configuration file : None
[2021-10-12 07:30:23][INFO] : Start zigbeed
[2021-10-12 07:30:23][INFO] : Log level : debug
[2021-10-12 07:30:23][INFO] : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-12 07:30:23][INFO] : Device : /dev/ttyUSB1
[2021-10-12 07:30:23][INFO] : Apikey : HAd52NjMUiQWX0Ia8lSngRIgt636yl78
[2021-10-12 07:30:23][INFO] : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2021-10-12 07:30:23][INFO] : Cycle : 0.3
[2021-10-12 07:30:23][INFO] : Controller : ezsp
[2021-10-12 07:30:23][INFO] : Channel : 15
[2021-10-12 07:30:23][INFO] : Data folder : /var/www/html/plugins/zigbee/data/1
[2021-10-12 07:30:23][INFO] : Device folder : /var/www/html/plugins/zigbee/data/device
[2021-10-12 07:30:23][INFO] : Folder OTA : None
[2021-10-12 07:30:23][INFO] : Zigpy advance configuration file : None
