Sur une 4.2a et le plugin gsh en beta de ce matin…
Lors de l’install des dépendances j’ai
+ touch /tmp/jeedom_install_in_progress_gsh
+ echo 1
+ echo 2
+ sudo apt update
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Get:3 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
Fetched 51.9 kB in 4s (13.7 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
+ echo 3
+ cd /var/www/html/core/class/../../plugins/gsh/resources/gshd
+ rm -rf node_modules
+ sudo npm install
added 65 packages from 25 contributors and audited 65 packages in 5.499s
found 1 low severity vulnerability
run `npm audit fix` to fix them, or `npm audit` for details
+ chown -R www-data:www-data
chown: missing operand after 'www-data:www-data'
Try 'chown --help' for more information.
+ echo 4
+ rm /tmp/jeedom_install_in_progress_gsh
Dans un script il vaut mieux utiliser apt-get que apt.
Pourquoi voit on les lignes echo 1 echo 2 ?
On a aussi
chown: missing operand after ‹ www-data:www-data ›
et j’ai aussi cela dans le log gsh_update
0000|********************************************************
0001|* Installation des dépendances *
0002|********************************************************
0003|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0004|Reading package lists...
0005|E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
0006|E: Unable to lock directory /var/lib/apt/lists/
0007|Reading package lists...
0008|Building dependency tree...
0009|Reading state information...
0010|lsb-release is already the newest version (10.2019051400).
0011|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0012|/var/www/html/plugins/gsh/core/class/../../resources/install_apt.sh: line 10: ${PROGRESS_FILE}: ambiguous redirect
0013|Version actuelle : 12
0014|Ok, version suffisante
0015|Reading package lists...
0016|Building dependency tree...
0017|Reading state information...
0018|Some packages could not be installed. This may mean that you have
0019|requested an impossible situation or if you are using the unstable
0020|distribution that some required packages have not yet been created
0021|or been moved out of Incoming.
0022|The following information may help to resolve the situation:
0023|The following packages have unmet dependencies:
0024|npm : Depends: nodejs (>= 6.11~) but it is not going to be installed
0025|Depends: node-abbrev (>= 1.1.1~) but it is not going to be installed
0026|Depends: node-ansi-regex (>= 3.0~) but it is not going to be installed
0027|Depends: node-ansistyles (>= 0.1.3~) but it is not going to be installed
0028|Depends: node-aproba (>= 1.2~) but it is not going to be installed
0029|Depends: node-archy (>= 1.0~) but it is not going to be installed
0030|Depends: node-cacache (>= 10.0.4~) but it is not going to be installed
0031|Depends: node-bluebird (>= 3.5.1~) but it is not going to be installed
0032|Depends: node-call-limit (>= 1.1~) but it is not going to be installed
0033|Depends: node-chownr (>= 1.0.1~) but it is not going to be installed
On voit qu’il y a un souci de droits, manque peut etre un sudo …
@naboleo y a quand même quelques souci même sous buster (pour faire suite à l’autre post avec ubuntu)
As-tu pareil ?
hello
Sur la version alpha, avec le plugin en beta, j’ai ça
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:4 https://download.docker.com/linux/debian buster InRelease
Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
Hit:6 https://packages.sury.org/php buster InRelease
Hit:7 https://repo.mosquitto.org/debian buster InRelease
Fetched 51.9 kB in 1s (64.7 kB/s)
Depends: node-config-chain (>= 1.1.11~) but it is not going to be installed
Depends: node-detect-indent (>= 5.0~) but it is not going to be installed
Depends: node-detect-newline (>= 2.1~) but it is not going to be installed
Depends: node-editor (>= 1.0~) but it is not going to be installed
Depends: node-fs-vacuum (>= 1.2.10~) but it is not going to be installed
Depends: node-fs-write-stream-atomic (>= 1.0.10~) but it is not going to be installed
Depends: node-glob (>= 7.1.2~) but it is not going to be installed
Depends: node-graceful-fs (>= 4.1.11~) but it is not going to be installed
Depends: node-has-unicode (>= 2.0.1~) but it is not going to be installed
Depends: node-hosted-git-info (>= 2.6~) but it is not going to be installed
Depends: node-iferr (>= 0.1.5~) but it is not going to be installed
Depends: node-inflight (>= 1.0.6~) but it is not going to be installed
Depends: node-inherits (>= 2.0.3~) but it is not going to be installed
Depends: node-ini (>= 1.3.5~) but it is not going to be installed
Depends: node-npm-package-arg but it is not going to be installed
Depends: node-promzard but it is not going to be installed
Depends: node-jsonstream (>= 1.3.2~) but it is not going to be installed
Depends: node-json-parse-better-errors (>= 1.0.1~) but it is not going to be installed
Depends: node-lazy-property (>= 1.0~) but it is not going to be installed
Depends: node-libnpx (>= 10.0.1~) but it is not going to be installed
Depends: node-lockfile (>= 1.0.3~) but it is not going to be installed
Depends: node-lru-cache (>= 4.1.1~) but it is not going to be installed
Depends: node-mississippi (>= 3.0~) but it is not going to be installed
Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed
Depends: node-move-concurrently (>= 1.0.1~) but it is not going to be installed
Depends: node-nopt but it is not going to be installed
Depends: node-normalize-package-data (>= 2.4~) but it is not going to be installed
Depends: node-gyp (>= 3.6.2~) but it is not going to be installed
Depends: node-resolve-from (>= 4.0~) but it is not going to be installed
Depends: node-encoding but it is not going to be installed
Depends: node-errno but it is not going to be installed
Depends: node-npmlog (>= 4.1.2~) but it is not going to be installed
Depends: node-once (>= 1.4~) but it is not going to be installed
Depends: node-opener (>= 1.4.3~) but it is not going to be installed
Depends: node-osenv (>= 0.1.5~) but it is not going to be installed
Depends: node-path-is-inside (>= 1.0.2~) but it is not going to be installed
Depends: node-promise-inflight (>= 1.0.1~) but it is not going to be installed
Depends: node-ansi but it is not going to be installed
Depends: node-qw (>= 1.0.1~) but it is not going to be installed
Depends: node-read (>= 1.0.7~) but it is not going to be installed
Depends: node-read-package-json (>= 2.0.13~) but it is not going to be installed
Depends: node-request (>= 2.83~) but it is not going to be installed
Depends: node-retry (>= 0.10.1~) but it is not going to be installed
Depends: node-rimraf (>= 2.6.2~) but it is not going to be installed
Depends: node-safe-buffer (>= 5.1.1~) but it is not going to be installed
Depends: node-semver (>= 5.5~) but it is not going to be installed
Depends: node-sha (>= 2.0.1~) but it is not going to be installed
Depends: node-slide (>= 1.1.6~) but it is not going to be installed
Depends: node-sorted-object (>= 2.0.1~) but it is not going to be installed
Depends: node-from2 but it is not going to be installed
Depends: node-stream-iterate but it is not going to be installed
Depends: node-ssri (>= 5.2.4~) but it is not going to be installed
Depends: node-strip-ansi (>= 4.0~) but it is not going to be installed
Depends: node-tar (>= 4.4~) but it is not going to be installed
Depends: node-text-table (>= 0.2~) but it is not going to be installed
Depends: node-uid-number (>= 0.0.6~) but it is not going to be installed
Depends: node-unique-filename (>= 1.1~) but it is not going to be installed
Depends: node-unpipe (>= 1.0~) but it is not going to be installed
Depends: node-boxen (>= 1.2.1~) but it is not going to be installed
Depends: node-import-lazy but it is not going to be installed
Depends: node-is-npm (>= 1.0~) but it is not going to be installed
Depends: node-latest-version (>= 3.0~) but it is not going to be installed
Depends: node-semver-diff (>= 2.0~) but it is not going to be installed
Depends: node-xdg-basedir (>= 3.0~) but it is not going to be installed
Depends: node-validate-npm-package-name (>= 3.0~) but it is not going to be installed
Depends: node-which (>= 1.3~) but it is not going to be installed
Depends: node-wrappy (>= 1.0.2~) but it is not going to be installed
Depends: node-write-file-atomic (>= 2.3~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
audited 65 packages in 0.66s
found 0 vulnerabilities
* Installation terminée *
Et au final ça marche … (vu que ça marchait déjà) donc il faut que je teste sur l’autre vm
Il y a pas les echo 12345, ni l’erreur sur le répertoire du chown
Regardes dans les logs
le gsh_update est a priori appelé dans packages on y voit la trace… avec un ambiguous redirect
Sur l’autre VM, 4.2 avec plugin stable
Version actuelle : 10
KO, version obsolète à upgrader
Suppression du Nodejs existant et installation du paquet recommandé
The following packages will be REMOVED:
gyp* libc-ares2* libjs-inherits* libjs-is-typedarray* libnode-dev*
libnode64* libuv1* libuv1-dev* node-abbrev* node-ajv* node-ansi*
node-ansi-align* node-ansi-regex* node-ansi-styles* node-ansistyles*
node-aproba* node-archy* node-are-we-there-yet* node-asn1* node-assert-plus*
node-asynckit* node-aws-sign2* node-aws4* node-balanced-match*
node-bcrypt-pbkdf* node-bluebird* node-boxen* node-brace-expansion*
node-builtin-modules* node-builtins* node-cacache* node-call-limit*
node-camelcase* node-caseless* node-chalk* node-chownr* node-cli-boxes*
node-cliui* node-clone* node-co* node-color-convert* node-color-name*
node-combined-stream* node-concat-map* node-concat-stream*
node-config-chain* node-console-control-strings* node-copy-concurrently*
node-core-util-is* node-cross-spawn* node-cyclist* node-dashdash*
node-decamelize* node-decompress-response* node-deep-extend* node-defaults*
node-delayed-stream* node-delegates* node-detect-indent*
node-detect-newline* node-duplexer3* node-duplexify* node-ecc-jsbn*
node-editor* node-encoding* node-end-of-stream* node-errno*
node-escape-string-regexp* node-execa* node-extend* node-extsprintf*
node-find-up* node-flush-write-stream* node-forever-agent* node-form-data*
node-from2* node-fs-vacuum* node-fs-write-stream-atomic* node-fs.realpath*
node-gauge* node-get-caller-file* node-get-stream* node-getpass* node-glob*
node-got* node-graceful-fs* node-gyp* node-har-schema* node-har-validator*
node-has-flag* node-has-symbol-support-x* node-has-to-string-tag-x*
node-has-unicode* node-hosted-git-info* node-http-signature*
node-iconv-lite* node-iferr* node-import-lazy* node-imurmurhash*
node-inflight* node-inherits* node-ini* node-invert-kv*
node-is-builtin-module* node-is-npm* node-is-object* node-is-plain-obj*
node-is-retry-allowed* node-is-stream* node-is-typedarray* node-isarray*
node-isexe* node-isstream* node-isurl* node-jsbn*
node-json-parse-better-errors* node-json-schema* node-json-stable-stringify*
node-json-stringify-safe* node-jsonify* node-jsonparse* node-jsonstream*
node-jsprim* node-latest-version* node-lazy-property* node-lcid*
node-libnpx* node-locate-path* node-lockfile* node-lowercase-keys*
node-lru-cache* node-mem* node-mime-types* node-mimic-fn*
node-mimic-response* node-minimatch* node-minimist* node-mississippi*
node-mkdirp* node-move-concurrently* node-mute-stream* node-node-uuid*
node-nopt* node-normalize-package-data* node-npm-package-arg*
node-npm-run-path* node-npmlog* node-oauth-sign* node-object-assign*
node-once* node-opener* node-os-locale* node-osenv* node-p-cancelable*
node-p-finally* node-p-limit* node-p-locate* node-p-timeout*
node-package-json* node-parallel-transform* node-path-exists*
node-path-is-absolute* node-path-is-inside* node-performance-now*
node-prepend-http* node-process-nextick-args* node-promise-inflight*
node-promzard* node-proto-list* node-prr* node-pump* node-pumpify*
node-punycode* node-qs* node-qw* node-rc* node-read* node-read-package-json*
node-readable-stream* node-registry-auth-token* node-registry-url*
node-request* node-require-directory* node-require-main-filename*
node-resolve-from* node-retry* node-rimraf* node-run-queue*
node-safe-buffer* node-semver* node-semver-diff* node-set-blocking*
node-sha* node-shebang-command* node-shebang-regex* node-signal-exit*
node-slash* node-slide* node-sorted-object* node-spdx-correct*
node-spdx-expression-parse* node-spdx-license-ids* node-sshpk* node-ssri*
node-stream-each* node-stream-iterate* node-stream-shift*
node-string-decoder* node-string-width* node-strip-ansi* node-strip-eof*
node-strip-json-comments* node-supports-color* node-tar* node-term-size*
node-text-table* node-through* node-through2* node-timed-out*
node-tough-cookie* node-tunnel-agent* node-tweetnacl* node-typedarray*
node-uid-number* node-unique-filename* node-unpipe* node-url-parse-lax*
node-url-to-options* node-util-deprecate* node-uuid*
node-validate-npm-package-license* node-validate-npm-package-name*
node-verror* node-wcwidth.js* node-which* node-which-module*
node-wide-align* node-widest-line* node-wrap-ansi* node-wrappy*
node-write-file-atomic* node-xdg-basedir* node-xtend* node-y18n*
node-yallist* node-yargs* node-yargs-parser* nodejs* nodejs-doc* npm*
0 upgraded, 0 newly installed, 250 to remove and 0 not upgraded.
After this operation, 50.9 MB disk space will be freed.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 63635 files and directories currently installed.)
Removing npm (5.8.0+ds6-4+deb10u2) ...
Removing node-gyp (3.8.0-6) ...
Removing gyp (0.1+20180428git4d467626-3) ...
Removing node-libnpx (10.2.0+repack-1) ...
Removing node-yargs (10.0.3-2) ...
Removing node-yargs-parser (11.1.1-1+deb10u1) ...
Removing node-tar (4.4.6+ds1-3) ...
Removing libnode-dev:amd64 (10.23.1~dfsg-1~deb10u1) ...
Removing node-cacache (11.3.2-2) ...
Removing node-mississippi (3.0.0-1) ...
Removing node-through2 (2.0.5-2) ...
Removing node-flush-write-stream (1.0.3-1) ...
Removing node-pumpify (1.5.1-1) ...
Removing node-request (2.88.1-2) ...
Removing node-is-typedarray (1.0.0-2) ...
Removing libjs-is-typedarray (1.0.0-2) ...
Removing libuv1-dev:amd64 (1.24.1-1) ...
Removing node-nopt (3.0.6-3) ...
Removing node-abbrev (1.1.1-1) ...
Removing node-har-validator (5.1.0-1) ...
Removing node-ajv (5.0.0-1) ...
Removing node-ansi (0.3.0-3) ...
Removing node-boxen (1.2.2-1) ...
Removing node-ansi-align (2.0.0-1) ...
Removing node-cliui (4.1.0-1) ...
Removing node-wrap-ansi (4.0.0-1) ...
Removing node-chalk (2.3.0-2) ...
Removing node-ansi-styles (3.2.1-1) ...
Removing node-ansistyles (0.1.3-1) ...
Removing node-npmlog (4.1.2-1) ...
Removing node-gauge (2.7.4-1) ...
Removing node-move-concurrently (1.0.1-2) ...
Removing node-archy (1.0.0-2) ...
Removing node-are-we-there-yet (1.1.4-1) ...
Removing node-http-signature (1.2.0-1) ...
Removing node-sshpk (1.13.1+dfsg-2) ...
Removing node-asn1 (0.2.3-1) ...
Removing node-dashdash (1.14.1-2) ...
Removing node-jsprim (1.4.0-1) ...
Removing node-verror (1.10.0-1) ...
Removing node-form-data (2.3.2-2) ...
Removing node-asynckit (0.4.0-2) ...
Removing node-aws-sign2 (0.7.1-1) ...
Removing node-aws4 (1.8.0-1) ...
Removing node-read-package-json (2.0.13-1) ...
Removing node-copy-concurrently (1.0.5-4) ...
Removing node-bcrypt-pbkdf (1.0.1-1) ...
Removing node-bluebird (3.5.1+dfsg2-2) ...
Removing node-normalize-package-data (2.4.0-1) ...
Removing node-is-builtin-module (2.0.0-1) ...
Removing node-builtin-modules (3.0.0-1) ...
Removing node-npm-package-arg (6.0.0-2) ...
Removing node-validate-npm-package-name (3.0.0-1) ...
Removing node-builtins (1.0.3-1) ...
Removing node-call-limit (1.1.0-1) ...
Removing node-camelcase (5.0.0-1) ...
Removing node-caseless (0.12.0-1) ...
Removing node-chownr (1.1.1-1) ...
Removing node-cli-boxes (1.0.0-1) ...
Removing node-widest-line (1.2.2-1) ...
Removing node-co (4.6.0-1) ...
Removing node-color-convert (1.9.0-3) ...
Removing node-color-name (1.1.3-1) ...
Removing node-combined-stream (1.0.7-1) ...
Removing node-concat-stream (1.6.2-1) ...
Removing node-config-chain (1.1.11-1) ...
Removing node-console-control-strings (1.1.0-1) ...
Removing node-term-size (1.2.0+dfsg-2) ...
Removing node-os-locale (2.0.0-1) ...
Removing node-execa (0.10.0+dfsg-1) ...
Removing node-cross-spawn (5.1.0-2) ...
Removing node-parallel-transform (1.1.0-2) ...
Removing node-cyclist (1.0.1-2) ...
Removing node-decamelize (1.2.0-1) ...
Removing node-latest-version (3.1.0-1) ...
Removing node-package-json (4.0.1-1) ...
Removing node-got (7.1.0-1) ...
Removing node-decompress-response (3.3.0-1) ...
Removing node-registry-url (3.1.0-1) ...
Removing node-registry-auth-token (3.3.1-1) ...
Removing node-rc (1.1.6-2) ...
Removing node-deep-extend (0.4.1-2) ...
Removing node-delayed-stream (0.0.5-1) ...
Removing node-delegates (1.0.0-1) ...
Removing node-detect-indent (5.0.0-1) ...
Removing node-detect-newline (2.1.0-1) ...
Removing node-duplexer3 (0.1.4-4) ...
Removing node-duplexify (3.6.1-1) ...
Removing node-ecc-jsbn (0.1.1-1) ...
Removing node-editor (1.0.0-1) ...
Removing node-encoding (0.1.12-2) ...
Removing node-stream-each (1.2.2-2) ...
Removing node-pump (3.0.0-1) ...
Removing node-end-of-stream (1.4.1-1) ...
Removing node-errno (0.1.4-1) ...
Removing node-escape-string-regexp (1.0.5-1) ...
Removing node-extend (3.0.2-1) ...
Removing node-extsprintf (1.3.0-1) ...
Removing node-find-up (2.1.0-1) ...
Removing node-forever-agent (0.6.1-1) ...
Removing node-from2 (2.3.0-1) ...
Removing node-fs-vacuum (1.2.10-2) ...
Removing node-fs-write-stream-atomic (1.0.10-4) ...
Removing node-get-caller-file (1.0.2-1) ...
Removing node-get-stream (3.0.0-1) ...
Removing node-getpass (0.1.7-1) ...
Removing node-write-file-atomic (2.3.0-1) ...
Removing node-sha (2.0.1-1) ...
Removing node-graceful-fs (4.1.11-1) ...
Removing node-har-schema (2.0.0-1) ...
Removing node-supports-color (4.4.0-2) ...
Removing node-has-flag (2.0.0-1) ...
Removing node-isurl (1.0.0-1) ...
Removing node-has-to-string-tag-x (1.4.1+dfsg-1) ...
Removing node-has-symbol-support-x (1.4.1+dfsg-1) ...
Removing node-has-unicode (2.0.1-2) ...
Removing node-hosted-git-info (2.7.1-1) ...
Removing node-iconv-lite (0.4.13-2) ...
Removing node-iferr (1.0.2-1) ...
Removing node-import-lazy (3.0.0.REALLY.2.1.0-1) ...
Removing node-unique-filename (1.1.0+ds-2) ...
Removing node-imurmurhash (0.1.4-1) ...
Removing node-ini (1.3.5-1) ...
Removing node-lcid (1.0.0-1) ...
Removing node-invert-kv (1.0.0-1) ...
Removing node-is-npm (1.0.0-1) ...
Removing node-is-object (1.0.1-1) ...
Removing node-is-plain-obj (1.1.0-1) ...
Removing node-is-retry-allowed (1.1.0-1) ...
Removing node-is-stream (1.1.0-1) ...
Removing node-which (1.3.0-2) ...
Removing node-isexe (2.0.0-4) ...
Removing node-isstream (0.1.2+dfsg-1) ...
Removing node-jsbn (1.1.0-1) ...
Removing node-json-parse-better-errors (1.0.2-2) ...
Removing node-json-schema (0.2.3-1) ...
Removing node-json-stable-stringify (1.0.1-1) ...
Removing node-json-stringify-safe (5.0.1-1) ...
Removing node-jsonify (0.0.0-1) ...
Removing node-jsonstream (1.3.2-1) ...
Removing node-jsonparse (1.3.1-6) ...
Removing node-lazy-property (1.0.0-3) ...
Removing node-locate-path (2.0.0-1) ...
Removing node-lockfile (1.0.4-1) ...
Removing node-lowercase-keys (1.0.0-2) ...
Removing node-lru-cache (5.1.1-4) ...
Removing node-mem (1.1.0-1) ...
Removing node-mime-types (2.1.21-1) ...
Removing node-mimic-fn (1.1.0-1) ...
Removing node-mimic-response (1.0.0-1) ...
Removing node-minimist (1.2.0-1+deb10u1) ...
Removing node-mkdirp (0.5.1-1) ...
Removing node-promzard (0.3.0-1) ...
Removing node-read (1.0.7-1) ...
Removing node-mute-stream (0.0.8-1) ...
Removing node-node-uuid (3.3.2-2) ...
Removing node-npm-run-path (2.0.2-2) ...
Removing node-oauth-sign (0.9.0-1) ...
Removing node-object-assign (4.1.1-2) ...
Removing node-opener (1.4.3-1) ...
Removing node-osenv (0.1.5-1) ...
Removing node-p-cancelable (0.3.0-1) ...
Removing node-p-timeout (1.2.0-1) ...
Removing node-p-finally (1.0.0-2) ...
Removing node-p-locate (2.0.0-1) ...
Removing node-p-limit (1.1.0-1) ...
Removing node-path-exists (3.0.0-1) ...
Removing node-path-is-inside (1.0.2-1) ...
Removing node-performance-now (2.1.0+debian-1) ...
Removing node-url-parse-lax (1.0.0-1) ...
Removing node-prepend-http (2.0.0-1) ...
Removing node-promise-inflight (1.0.1-1) ...
Removing node-proto-list (1.2.4-1) ...
Removing node-prr (1.0.1-1) ...
Removing node-tough-cookie (2.3.4+dfsg-1) ...
Removing node-punycode (2.1.1-2) ...
Removing node-qs (6.5.2-1) ...
Removing node-qw (1.0.1-1) ...
Removing node-require-directory (2.1.1-1) ...
Removing node-require-main-filename (1.0.1-1) ...
Removing node-resolve-from (4.0.0-1) ...
Removing node-retry (0.10.1-1) ...
Removing node-tunnel-agent (0.6.1-1) ...
Removing node-semver-diff (2.1.0-2) ...
Removing node-semver (5.5.1-1) ...
Removing node-set-blocking (2.0.0-1) ...
Removing node-shebang-command (1.2.0-1) ...
Removing node-shebang-regex (2.0.0-1) ...
Removing node-signal-exit (3.0.2-1) ...
Removing node-slash (1.0.0-1) ...
Removing node-slide (1.1.6-2) ...
Removing node-sorted-object (2.0.1-1) ...
Removing node-validate-npm-package-license (3.0.1-1) ...
Removing node-spdx-correct (1.0.2-1) ...
Removing node-spdx-expression-parse (1.0.4-1) ...
Removing node-spdx-license-ids (1.2.2-1) ...
Removing node-ssri (5.2.4-2) ...
Removing node-stream-iterate (1.2.0-4) ...
Removing node-stream-shift (1.0.0-1) ...
Removing node-strip-eof (1.0.0-2) ...
Removing node-strip-json-comments (2.0.1-2) ...
Removing node-text-table (0.2.0-2) ...
Removing node-through (2.3.8-1) ...
Removing node-timed-out (4.0.1-4) ...
Removing node-tweetnacl (0.14.5+dfsg-3) ...
Removing node-typedarray (0.0.6-1) ...
Removing node-uid-number (0.0.6-1) ...
Removing node-unpipe (1.0.0-1) ...
Removing node-url-to-options (1.0.1-1) ...
Removing node-uuid (3.3.2-2) ...
Removing node-which-module (2.0.0-1) ...
Removing node-wide-align (1.1.0-1) ...
Removing node-xdg-basedir (3.0.0-1) ...
Removing node-xtend (4.0.1-2) ...
Removing node-y18n (3.2.1-2) ...
Removing nodejs-doc (10.23.1~dfsg-1~deb10u1) ...
Removing node-yallist (3.0.3-1) ...
Removing node-readable-stream (2.3.6-1) ...
Removing node-run-queue (1.0.3-1) ...
Removing node-aproba (1.2.0-1) ...
Removing node-assert-plus (1.0.0-1) ...
Removing node-rimraf (2.6.2-1) ...
Removing node-glob (7.1.3-2) ...
Removing node-minimatch (3.0.4-3) ...
Removing node-brace-expansion (1.1.8-1) ...
Removing node-balanced-match (0.4.2-1) ...
Removing node-string-width (2.1.1-1) ...
Removing node-wcwidth.js (1.0.0-1) ...
Removing node-defaults (1.0.3-1) ...
Removing node-clone (2.1.2-1) ...
Removing node-concat-map (0.0.1-1) ...
Removing node-core-util-is (1.0.2-1) ...
Removing node-fs.realpath (1.0.0-1) ...
Removing node-inflight (1.0.6-1) ...
Removing node-isarray (2.0.4-1) ...
Removing node-once (1.4.0-3) ...
Removing node-path-is-absolute (1.0.0-1) ...
Removing node-process-nextick-args (2.0.0-1) ...
Removing node-string-decoder (1.2.0-1) ...
Removing node-safe-buffer (5.1.2-1) ...
Removing node-util-deprecate (1.0.2-1) ...
Removing node-wrappy (1.0.2-1) ...
Removing node-inherits (2.0.3-1) ...
Removing libjs-inherits (2.0.3-1) ...
Removing node-strip-ansi (4.0.0-1) ...
Removing node-ansi-regex (3.0.0-1) ...
Removing nodejs (10.23.1~dfsg-1~deb10u1) ...
Removing libnode64:amd64 (10.23.1~dfsg-1~deb10u1) ...
Removing libc-ares2:amd64 (1.14.0-1) ...
Removing libuv1:amd64 (1.24.1-1) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for libc-bin (2.28-10) ...
(Reading database ... 58545 files and directories currently installed.)
Purging configuration files for npm (5.8.0+ds6-4+deb10u2) ...
/var/www/html/plugins/gsh/core/class/../../resources/install_apt.sh: line 25: $LOG: ambiguous redirect
Utilisation du dépot officiel
## Installing the NodeSource Node.js 12.x repo...
## Populating apt-get cache...
+ apt-get update
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 https://packages.sury.org/php buster InRelease
## Confirming "buster" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/buster/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
## Creating apt sources list file for the NodeSource Node.js 12.x repo...
+ echo 'deb https://deb.nodesource.com/node_12.x buster main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src https://deb.nodesource.com/node_12.x buster main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
Hit:2 http://deb.debian.org/debian buster-updates InRelease
Hit:3 http://security.debian.org/debian-security buster/updates InRelease
Get:4 https://deb.nodesource.com/node_12.x buster InRelease [4584 B]
Hit:5 https://packages.sury.org/php buster InRelease
Get:6 https://deb.nodesource.com/node_12.x buster/main amd64 Packages [767 B]
Fetched 5351 B in 2s (2234 B/s)
## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
nodejs
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 18.1 MB of archives.
After this operation, 93.5 MB of additional disk space will be used.
Get:1 https://deb.nodesource.com/node_12.x buster/main amd64 nodejs amd64 12.20.1-1nodesource1 [18.1 MB]
Fetched 18.1 MB in 1s (18.0 MB/s)
Selecting previously unselected package nodejs.
Preparing to unpack .../nodejs_12.20.1-1nodesource1_amd64.deb ...
Unpacking nodejs (12.20.1-1nodesource1) ...
Setting up nodejs (12.20.1-1nodesource1) ...
Version actuelle : v12.20.1
npm WARN ts-node@8.2.0 requires a peer of typescript@>=2.0 but none is installed. You must install peer dependencies yourself.
audited 73 packages in 3.223s
et ça marche
Donc coquille dans le script de la beta…
