Je viens d’essayer en SSH et voila ce que j’obtiens :
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting zhaquirks
Could not install packages due to an EnvironmentError: 404 Client Error: Not Found for url: https://pypi.org/simple/zhaquirks/
Pour le journal des dépendances, c’est bien cela ? :
Launch install of zigbee dependancy
Hit:1 http://deb.debian.org/debian buster InRelease
Get:2 http://deb.debian.org/debian-security buster/updates InRelease [65.4 kB]
Get:3 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Get:4 http://archive.raspberrypi.org/debian buster InRelease [32.9 kB]
Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
Get:6 http://deb.debian.org/debian-security buster/updates/main armhf Packages [266 kB]
Get:7 http://deb.debian.org/debian-security buster/updates/main arm64 Packages [267 kB]
Get:8 http://archive.raspberrypi.org/debian buster/main armhf Packages [372 kB]
Get:9 http://archive.raspberrypi.org/debian buster/main arm64 Packages [283 kB]
Fetched 1337 kB in 4s (349 kB/s)
Reading package lists...
Skipping serial as it is not installed.
Building dependency tree...
Reading state information...
Package 'python3-serial' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
python3-setuptools is already the newest version (40.8.0-1).
python3 is already the newest version (3.7.3-1).
python3-dev is already the newest version (3.7.3-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.21.0-1).
python3-pip is already the newest version (18.1-5+rpt1).
Requirement already up-to-date: wheel in /usr/local/lib/python3.7/dist-packages (0.36.2)
Requirement already up-to-date: pyserial in /usr/local/lib/python3.7/dist-packages (3.5)
Requirement already up-to-date: zigpy in /usr/local/lib/python3.7/dist-packages (0.33.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.10.1)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.17.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.12.1)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy) (1.0)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy) (3.7.4.3)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (5.1.0)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (3.0.1)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (1.6.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (20.3.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy) (3.0.4)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy) (2.6)
Requirement already up-to-date: bellows in /usr/local/lib/python3.7/dist-packages (0.23.1)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from bellows) (0.5)
Requirement already satisfied, skipping upgrade: pure-pcapy3==1.0.1 in /usr/local/lib/python3.7/dist-packages (from bellows) (1.0.1)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from bellows) (0.12.1)
Requirement already satisfied, skipping upgrade: zigpy>=0.21.0 in /usr/local/lib/python3.7/dist-packages (from bellows) (0.33.0)
Requirement already satisfied, skipping upgrade: click in /usr/local/lib/python3.7/dist-packages (from bellows) (7.1.2)
Requirement already satisfied, skipping upgrade: click-log>=0.2.1 in /usr/local/lib/python3.7/dist-packages (from bellows) (0.3.2)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->bellows) (3.5)
Requirement already satisfied, skipping upgrade: setuptools in /usr/local/lib/python3.7/dist-packages (from pure-pcapy3==1.0.1->bellows) (56.0.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.21.0->bellows) (3.10.1)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.21.0->bellows) (0.17.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.21.0->bellows) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.21.0->bellows) (1.0)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.21.0->bellows) (3.7.4.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (20.3.0)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (5.1.0)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (3.0.1)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (3.0.4)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (1.6.3)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.21.0->bellows) (2.6)
Collecting git+https://github.com/jeedom/zha-device-handlers
Cloning https://github.com/jeedom/zha-device-handlers to /tmp/pip-req-build-oeb79u85
fatal: could not read Username for 'https://github.com': No such device or address
Command "git clone -q https://github.com/jeedom/zha-device-handlers /tmp/pip-req-build-oeb79u85" failed with error code 128 in None
Requirement already up-to-date: zigpy_znp in /usr/local/lib/python3.7/dist-packages (0.4.0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (0.12.1)
Requirement already satisfied, skipping upgrade: coloredlogs in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (15.0)
Requirement already satisfied, skipping upgrade: zigpy>=0.25.0 in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (0.33.0)
Requirement already satisfied, skipping upgrade: async-timeout in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (3.0.1)
Requirement already satisfied, skipping upgrade: pyserial-asyncio; platform_system != "Windows" in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (0.5)
Requirement already satisfied, skipping upgrade: humanfriendly>=9.1 in /usr/local/lib/python3.7/dist-packages (from coloredlogs->zigpy_znp) (9.1)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.25.0->zigpy_znp) (1.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.25.0->zigpy_znp) (0.17.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.25.0->zigpy_znp) (3.10.1)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.25.0->zigpy_znp) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio; platform_system != "Windows"->zigpy_znp) (3.5)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.25.0->zigpy_znp) (3.7.4.3)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (5.1.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (3.0.4)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (1.6.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (20.3.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.25.0->zigpy_znp) (2.6)
Requirement already up-to-date: zigpy-xbee in /usr/local/lib/python3.7/dist-packages (0.13.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-xbee) (0.5)
Requirement already satisfied, skipping upgrade: zigpy>=0.23.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-xbee) (0.33.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-xbee) (3.5)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (1.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (0.17.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (3.10.1)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (0.12.1)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.23.0->zigpy-xbee) (3.7.4.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.0.1)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.0.4)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (1.6.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (20.3.0)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (5.1.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.23.0->zigpy-xbee) (2.6)
Requirement already up-to-date: zigpy-deconz in /usr/local/lib/python3.7/dist-packages (0.12.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-deconz) (0.5)
Requirement already satisfied, skipping upgrade: zigpy>=0.24.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-deconz) (0.33.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-deconz) (3.5)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (3.10.1)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (1.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (0.17.0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (0.12.1)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (1.6.3)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (5.1.0)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (3.7.4.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (3.0.1)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (20.3.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (3.0.4)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.24.0->zigpy-deconz) (2.6)
Requirement already up-to-date: zigpy-zigate in /usr/local/lib/python3.7/dist-packages (0.7.4)
Requirement already satisfied, skipping upgrade: RPi.GPIO in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.7.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.5)
Requirement already satisfied, skipping upgrade: pyusb in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (1.1.1)
Requirement already satisfied, skipping upgrade: zigpy>=0.22.2 in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.33.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-zigate) (3.5)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (0.17.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (3.10.1)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (1.0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (0.12.1)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.22.2->zigpy-zigate) (3.7.4.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (20.3.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.0.4)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.0.1)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (1.6.3)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (5.1.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.22.2->zigpy-zigate) (2.6)
Requirement already up-to-date: zigpy-cc in /usr/local/lib/python3.7/dist-packages (0.5.2)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-cc) (0.5)
Requirement already satisfied, skipping upgrade: zigpy>=0.23.1 in /usr/local/lib/python3.7/dist-packages (from zigpy-cc) (0.33.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-cc) (3.5)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (0.17.0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (0.12.1)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (1.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (3.10.1)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.23.1->zigpy-cc) (3.7.4.3)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (1.6.3)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (5.1.0)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (3.0.1)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (3.0.4)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (20.3.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.23.1->zigpy-cc) (2.6)
Requirement already up-to-date: tornado in /usr/local/lib/python3.7/dist-packages (6.1)
Everything is successfully installed!
Là je suis perdu…
Cordialement
