Hello
J’ai un problème de dépendance avec le plugin MyAudi version : 2025-04-18 01:08:01
== 03/06/2025 14:33:28 == Dependencies installation for myaudi
[ 5% ] : Clean apt...
[ 9% ] : Clean apt : [ OK ]
[ 10% ] : Update apt...
[ 19% ] : Update apt : [ OK ]
[ 20% ] : Init python3 & prerequisites...
[ 29% ] : Init python3 & prerequisites : [ OK ]
[ 30% ] : Init PyEnv...
** PyEnv required: 3.9.2 < 3.11 **
[ 39% ] : Init PyEnv : [ OK ]
[ 40% ] : install or update PyEnv...
[ 49% ] : install or update PyEnv : [ OK ]
[ 50% ] : Install Python 3.11 with PyEnv...
** python3 path: /opt/pyenv/versions/3.11.11/bin/python3 **
[ 59% ] : Install Python 3.11 with PyEnv : [ OK ]
[ 60% ] : Setting up virtual environment...
** Version of python in VENV: Python 3.11.11
[ 69% ] : Setting up virtual environment : [ OK ]
[ 70% ] : Install the required python packages...
[ 79% ] : Install the required python packages : ERROR
[ 80% ] : Restoring folders and files rights...
[ 89% ] : Restoring folders and files rights : [ OK ]
[ 90% ] : Summary of installed packages...
packaging==24.2
[ 99% ] : Summary of installed packages : [ OK ]
[100% ] : Finished !
== KO == Installation Error
== ANALYSING LOGS...
== NO KNOWN ERROR DETECTED
== Error in step : Install the required python packages
== Line 222
== The command `/var/www/html/plugins/myaudi/resources/venv/bin/python3 -m pip install --upgrade -r /var/www/html/plugins/myaudi/resources/requirements.txt' has an issue
== Return code is 1
== Error message :
Collecting jeedomdaemon~=1.2.9 (from -r /var/www/html/plugins/myaudi/resources/requirements.txt (line 1))
Using cached jeedomdaemon-1.2.9-py3-none-any.whl.metadata (5.2 kB)
ERROR: Could not find a version that satisfies the requirement audiconnectpy~=2.5.50 (from versions: none)
ERROR: No matching distribution found for audiconnectpy~=2.5.50
Une idée de la solution
