Démon zigbee2mqt NOK
> zigbee2mqtt@1.37.1 start
> node index.js
[2024-05-15 03:50:23] e[31merrore[39m: 	z2m: Failed to load external converter file '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js' (Cannot find module 'zigbee-herdsman-converters/lib/extend'
Require stack:
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/utils.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/settings.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js)
[2024-05-15 03:50:23] e[31merrore[39m: 	z2m: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
[2024-05-15 03:50:23] e[31merrore[39m: 	z2m: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
[2024-05-15 03:50:29] e[31merrore[39m: 	z2m: Error while starting zigbee-herdsman
[2024-05-15 03:50:29] e[31merrore[39m: 	z2m: Failed to start zigbee
[2024-05-15 03:50:29] e[31merrore[39m: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-05-15 03:50:29] e[31merrore[39m: 	z2m: Exiting...
[2024-05-15 03:50:30] e[31merrore[39m: 	z2m: Error: failed to connect to zigate adapter [object Object] after 5000ms
at ZiGateAdapter.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/zigate/adapter/zigateAdapter.ts:95:19)
at runNextTicks (node:internal/process/task_queues:60:5)
at listOnTimeout (node:internal/timers:538:9)
at processTimers (node:internal/timers:512:7)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:124:29)
at Zigbee.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/zigbee.ts:62:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/controller.ts:109:27)
at start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:107:5)
Informations Jeedom Luna
Core : 4.4.5 (V4-stable)
DNS Jeedom Luna : oui
Plugin : JeeZigbee
Version : 2024-04-24 01:01:56 (stable)
Statut Démon : Stoppé - (2024-05-15 06:15:05)
Bonjour ???
De toute évidence vous avez confondu la communauté avec un helpdesk (ce qui ne justifie pas la forme) donc passez par un ticket jeedom, svp.
Au moins y a un log… (bon il n’était pas collé dans un Texte préformaté, manifestement on ne peut pas tout avoir)
