Demon NOK suite à dernière mise à jour
N’est pas présent en 4.3
Ah oups c vrai j’oublie tjrs que je suis sur 4.4 beta sur ma prod
j’ai effectué les manip demandées par Fabrice, toujours le même problème, voir log ci-dessous
les logs étaient illisibles, j’ai supprimé
vous devez les copier dans un Texte préformaté (bouton </>)
Désolé voici le nouveau log
0001|[PROGRESS][1]
0002|****Update from 4.3.21 (2023-12-31 10:00:05)****
0003|Parameters : {"preUpdate":"0","backup::before":"0","plugins":"0","core":"1","force":"0","update::reapply":""}
0004|Send begin of update event...OK
0005|[PROGRESS][5]
0006|Check rights...
0007|OK
0008|[PROGRESS][10]
0009|[PROGRESS][15]
0010|Download url : https://github.com/jeedom/core/archive/V4-stable.zip
0011|Download in progress...--2023-12-31 09:00:15--  https://github.com/jeedom/core/archive/V4-stable.zip
0012|Resolving github.com (github.com)... 140.82.121.4
0013|Connecting to github.com (github.com)|140.82.121.4|:443... connected.
0014|HTTP request sent, awaiting response... 302 Found
0015|Location: https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable [following]
0016|--2023-12-31 09:00:16--  https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable
0017|Resolving codeload.github.com (codeload.github.com)... 140.82.121.9
0018|Connecting to codeload.github.com (codeload.github.com)|140.82.121.9|:443... connected.
0019|HTTP request sent, awaiting response... 200 OK
0020|Length: 82253287 (78M) [application/zip]
0021|Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0022|0K ........ ........ ........ ........ .....
0023|.. ........  3% 11.4M 7s
0024|3072K ........ ........ ........ ........ ........ ........  7% 50.3M 4s
0025|6144K ........ ........ ........ ........ ........ ........ 11% 29.1M 3s
0026|9216K ........ ........ ........ ........ ........ ........ 15% 17.0M 3s
0027|12288K ........ ........ ........ ........ ........ ........ 19% 28.8M 3s
0028|15360K ........ ........ ........ ........ ........ ........ 22% 17.0M 3s
0029|18432K ........ ........ ........ ........ ........ ........ 26% 29.2M 3s
0030|21504K ........ ........ ........ ........ ........ ........ 30% 20.2M 3s
0031|24576K ........ ........ ........ ........ ........ ........ 34% 22.5M 2s
0032|27648K ......
0033|.. ........ ........ ........ ........ ........ 38% 20.5M 2s
0034|30720K ........ ........ ........ ........ ........ ........ 42% 11.0M 2s
0035|33792K ........ ........ ........ ........ ........ ........ 45% 8.94M 2s
0036|36864K ........ ........ ........ ........ ........ ........ 49% 40.3M 2s
0037|39936K ........ ........ ........ ........ ........ ........ 53% 48.1M 2s
0038|43008K ........ ........ ........ ........ ........ ........ 57% 87.5M 2s
0039|46080K ........ ........ ........ ........ ........ ....
0040|.... 61% 19.0M 1s
0041|49152K ........ ........ ........ ........ ........ ........ 65% 32.1M 1s
0042|52224K ........ ........ ........ ........ ........ ........ 68% 16.9M 1s
0043|55296K ........ ........ ........ ........ ........ ........ 72% 29.9M 1s
0044|58368K ........ ........ ........ ........ ........ ........ 76% 16.7M 1s
0045|61440K ........ ........ ........ ........ ........ ........ 80% 29.9M 1s
0046|64512K ........ ........ ........ ........ ........ ........ 84% 26.0M 1s
0047|67584K ........ ........ ........ ........ ........ ........ 87% 18.5M 0s
0048|70656K ........ ........ ........ ........ ........ ........ 91% 29.5M 0s
0049|73728K ........
0050|........ ........ ........ ........ ........ 95% 17.2M 0s
0051|76800K ........ ........ ........ ........ ........ ........ 99% 29.7M 0s
0052|79872K .......                                              100%  174M=3.7s
0053|2023-12-31 09:00:20 (21.4 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [82253287/82253287]
0054|[PROGRESS][25]
0055|OK
0056|Cleaning folders...
0057|OK
0058|[PROGRESS][30]
0059|Create temporary folder...OK
0060|[PROGRESS][35]
0061|Unzip in progress...
0062|OK
0063|[PROGRESS][40]
0064|Clean temporary files (tmp)...OK
0065|Disable all task
0066|kill: (4934): No such process
0067|.. OK
0068|Disable all scenario... OK
0069|[PROGRESS][45]
0070|Moving files...
0071|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/de_DE/noteVersion.md because size is 0
0072|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/en_US/noteVersion.md because size is 0
0073|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/es_ES/noteVersion.md because size is 0
0074|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/fr_FR/noteVersion.md because size is 0
0075|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/pt_PT/noteVersion.md because size is 0
0076|OK
0077|[PROGRESS][50]
0078|Remove temporary files...OK
0079|[PROGRESS][52]
0080|Remove useless files...
0081|Cleaning 3rdparty
0082|Cleaning desktop
0083|Cleaning mobile
0084|Cleaning core
0085|Cleaning docs
0086|Cleaning install
0087|Cleaning script
0088|find: '/var/www/html/install/../script/*': No such file or directory
0089|Cleaning vendor
0090|[PROGRESS][55]
0091|Check jeedom consistency...
0092|[START CONSISTENCY]
0093|[START CHECK AND FIX DB]
0094|[END CHECK AND FIX DB]
0095|Check jeedom package...
0096|OK
0097|Check jeedom database...OK
0098|Check crons...
0099|Check filesystem right...
0100|OK
0101|Flush cache widget...
0102|Check jeedom object...OK
0103|Check jeedom cmd...OK
0104|Set cache hour...OK
0105|Check nodejs...
0106|E: Sub-process /usr/bin/dpkg returned an error code (2)
0107|Hit:1 http://deb.debian.org/debian buster InRelease
0108|Hit:2 http://deb.debian.org/debian buster-updates InRelease
0109|Get:3 http://deb.debian.org/debian buster-backports InRelease [51.4 kB]
0110|Hit:4 http://security.debian.org buster/updates InRelease
0111|Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
0112|Fetched 51.4 kB in 1s (41.1 kB/s)
0113|Reading package lists...
0114|Reading package lists...
0115|Building dependency tree...
0116|Reading state information...
0117|apt-utils is already the newest version (1.8.2.3).
0118|build-essential is already the newest version (12.6).
0119|lsb-release is already the newest version (10.2019051400).
0120|git is already the newest version (1:2.20.1-2+deb10u8).
0121|0 upgraded, 0 newly installed, 0 to remove and 166 not upgraded.
0122|[Check Version NodeJS actuelle : v16.19.0 : [  KO  ]
0123|Installation de NodeJS 18
0124|Utilisation du dépot officiel
0125|deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
0126|Hit:1 http://deb.debian.org/debian buster InRelease
0127|Hit:2 http://deb.debian.org/debian buster-updates InRelease
0128|Hit:3 http://security.debian.org buster/updates InRelease
0129|Hit:4 http://deb.debian.org/debian buster-backports InRelease
0130|Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
0131|Reading package lists...
0132|Reading package lists...
0133|Building dependency tree...
0134|Reading state information...
0135|The following packages will be upgraded:
0136|nodejs
0137|1 upgraded, 0 newly installed, 0 to remove and 165 not upgraded.
0138|Need to get 0 B/29.0 MB of archives.
0139|After this operation, 61.2 MB of additional disk space will be used.
0140|(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
dpkg: unrecoverable fatal error, aborting:
0141|files list file for package 'tzdata' is missing final newline
0142|[Check Version NodeJS après install : v16.19.0 : [  KO  ] -> relancez les dépendances
0143|[Check Prefix : /usr/local and sudo prefix : /usr/local and www-data prefix : /usr/local : [  OK  ]
0144|OK
0145|[END CONSISTENCY]
0146|OK
0147|Check update...OK
0148|***************Jeedom is up to date in 4.3.21***************
0149|[PROGRESS][75]
0150|[PROGRESS][90]
0151|Check update
0152|OK
0153|[PROGRESS][95]
0154|Enable scenario : OK
0155|Enable task : OK
0156|[PROGRESS][100]
0157|Launch cron dependancy plugins...OK
0158|Send end of update event...OK
0159|Update duration : 78s
0160|[END UPDATE SUCCESS]
Faites cela en SSH :
sudo dpkg ––configure –a
sudo apt install -f
sudo apt-get clean
sudo apt-get autoremove
sudo apt-get update
Puis, redémarrez Jeedom et tentez une nouvelle installation de la mise à jour de Jeedom et mettez les logs de nouveau ici.
ou en SSH :
sudo /var/www/html/resources/install_nodejs.sh
EDIT : Zwave JS est HS après la dernière MàJ - #35 par akenad
akenad :slight_smile:
ha, il ne l’aurait pas fait depuis la réponse n°5 ?
:slight_smile:
L’avantage de lui faire faire depuis l’interface de Jeedom, on a des logs.
tenté dans la réponse n°7 (sans le sudo)
ça n’a pas l’air d’être la VM jeedom freebox delta.
C’est à cause de ce message que je n’ai pas relevé cette commande (et surtout, pour avoir les logs depuis l’interface de Jeedoom).
nouveau log après les différentes actions demandées par Fabrice
0001|[PROGRESS][1]
0002|****Update from 4.3.21 (2023-12-31 14:14:55)****
0005|[PROGRESS][5]
0007|OK
0008|[PROGRESS][10]
0009|[PROGRESS][15]
0011|Download in progress...--2023-12-31 13:15:01--  https://github.com/jeedom/core/archive/V4-stable.zip
0016|--2023-12-31 13:15:01--  https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable
0022|0K ......
0023|.. ........ ........ ........ ........ ........  3% 9.62M 8s
0024|3072K ........ ........ ........ ........ ........ ........  7% 42.1M 5s
0025|6144K ........ ........ ........ ........ ........ ........ 11% 29.3M 4s
0026|9216K ........ ........ ........ ........ ........ ........ 15% 19.7M 4s
0027|12288K ........ ........ ........ ........ ........ ........ 19% 25.9M 3s
0028|15360K ........ ........ ........ ........ ........ ........ 22% 19.7M 3s
0029|18432K ........ ........ ........ ........ ........ ........ 26% 27.0M 3s
0030|21504K ........ ........ ........ ........ ........ ........ 30% 19.3M 3s
0031|24576K ........ ........ ........ ........ ........ ........ 34% 28.8M 2s
0032|27648K ........ ........ ........ ........ ........ ........ 38% 30.0M 2s
0033|30720K .
0034|....... ........ ........ ........ ........ ........ 42% 18.8M 2s
0035|33792K ........ ........ ........ ........ ........ ........ 45% 26.4M 2s
0036|36864K ........ ........ ........ ........ ........ ........ 49% 17.9M 2s
0037|39936K ........ ........ ........ ........ ........ ........ 53% 28.1M 2s
0038|43008K ........ ........ ........ ........ ........ ........ 57% 20.2M 2s
0039|46080K ........ ........ ........ ........ ........ ........ 61% 27.2M 1s
0040|49152K ........ ........ ........ ........ ........ ........ 65% 19.4M 1s
0041|52224K ........ ........ ........ ........ ........ ........ 68% 29.6M 1s
0042|55296K ........ ........ ........ ....
0043|.... ........ ........ 72% 30.2M 1s
0044|58368K ........ ........ ........ ........ ........ ........ 76% 18.2M 1s
0046|64512K ........ ........ ........ ........ ........ ........ 84% 17.7M 1s
0047|67584K ........ ........ ........ ........ ........ ........ 87% 30.1M 0s
0048|70656K ........ ........ ........ ........ ........ ........ 91% 30.4M 0s
0049|73728K ........ ........ ........ ........ ........ ........ 95% 18.3M 0s
0050|76800K ........ ........ ........ ........ ........ ........ 99% 31.2M 0s
0051|79872K .......                                              100%  171M=3.4s
0052|2023-12-31 13:15:05 (22.9 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [82253287/82253287]
0053|[PROGRESS][25]
0054|OK
0055|Cleaning folders...
0056|OK
0057|[PROGRESS][30]
0058|Create temporary folder...OK
0059|[PROGRESS][35]
0060|Unzip in progress...
0061|OK
0062|[PROGRESS][40]
0063|Clean temporary files (tmp)...OK
0064|Disable all task
0065|kill: (8058): No such process
0066|.. OK
0067|Disable all scenario.
0068|.. OK
0069|[PROGRESS][45]
0070|Moving files...Ignore file /tmp/jeedom_unzip/core-4-stable///docs/de_DE/noteVersion.md because size is 0
0071|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/en_US/noteVersion.md because size is 0
0072|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/es_ES/noteVersion.md because size is 0
0073|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/fr_FR/noteVersion.md because size is 0
0074|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/pt_PT/noteVersion.md because size is 0
0075|OK
0076|[PROGRESS][50]
0077|Remove temporary files...OK
0078|[PROGRESS][52]
0079|Remove useless files...
0080|Cleaning 3rdparty
0081|Cleaning desktop
0082|Cleaning mobile
0083|Cleaning core
0084|Cleaning docs
0085|Cleaning install
0086|Cleaning script
0087|find: '/var/www/html/install/../script/*': No such file or directory
0088|Cleaning vendor
0089|[PROGRESS][55]
0090|Check jeedom consistency...
0091|[START CONSISTENCY]
0092|[START CHECK AND FIX DB]
0093|[END CHECK AND FIX DB]
0094|Check jeedom package...
0095|OK
0096|Check jeedom database...OK
0097|Check crons...
0098|Check filesystem right...
0099|OK
0100|Flush cache widget...
0101|Check jeedom object...OK
0102|Check jeedom cmd...OK
0103|Set cache hour...OK
0104|Check nodejs...
0105|E: Sub-process /usr/bin/dpkg returned an error code (2)
0106|Get:1 http://security.debian.org buster/updates InRelease [34.8 kB]
0107|Hit:2 http://deb.debian.org/debian buster InRelease
0108|Hit:3 http://deb.debian.org/debian buster-updates InRelease
0109|Hit:4 http://deb.debian.org/debian buster-backports InRelease
0110|Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
0111|Get:6 http://security.debian.org buster/updates/main Sources [362 kB]
0112|Get:7 http://security.debian.org buster/updates/main arm64 Packages [566 kB]
0113|Fetched 964 kB in 2s (514 kB/s)
0115|Reading package lists...
0116|Building dependency tree...
0117|Reading state information...
0118|apt-utils is already the newest version (1.8.2.3).
0119|build-essential is already the newest version (12.6).
0120|lsb-release is already the newest version (10.2019051400).
0121|git is already the newest version (1:2.20.1-2+deb10u8).
0122|0 upgraded, 0 newly installed, 0 to remove and 166 not upgraded.
0123|[Check Version NodeJS actuelle : v16.19.0 : [  KO  ]
0124|Installation de NodeJS 18
0125|Utilisation du dépot officiel
0126|deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
0127|Hit:1 http://deb.debian.org/debian buster InRelease
0128|Hit:2 http://security.debian.org buster/updates InRelease
0129|Hit:3 http://deb.debian.org/debian buster-updates InRelease
0130|Hit:4 http://deb.debian.org/debian buster-backports InRelease
0131|Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
0133|Reading package lists...
0134|Building dependency tree...
0135|Reading state information...
0136|The following packages will be upgraded:
0137|nodejs
0138|1 upgraded, 0 newly installed, 0 to remove and 165 not upgraded.
0139|Need to get 0 B/29.0 MB of archives.
0140|After this operation, 61.2 MB of additional disk space will be used.
0141|(Reading database ...
0142|files list file for package 'tzdata' is missing final newline
0143|[Check Version NodeJS après install : v16.19.0 : [  KO  ] -> relancez les dépendances
0144|[Check Prefix : /usr/local and sudo prefix : /usr/local and www-data prefix : /usr/local : [  OK  ]
0145|OK
0146|[END CONSISTENCY]
0147|OK
0148|Check update...OK
0149|***************Jeedom is up to date in 4.3.21***************
0150|[PROGRESS][75]
0151|[PROGRESS][90]
0152|Check update
0153|OK
0154|[PROGRESS][95]
0155|Enable scenario : OK
0156|Enable task : OK
0157|[PROGRESS][100]
0158|Launch cron dependancy plugins...OK
0159|Send end of update event...OK
0160|Update duration : 77s
0161|[END UPDATE SUCCESS]
Aller dans :
Réglages > Système > Configuration > OS/DB > Administration système > Ouvrir
taper commande :
Merci akenad, nécessaire effectué mais rien de nouveau
résultat à l’écran ?
Aller dans :
taper commande :
node -v
v16.19.0
Peux-tu copier coller le retour de ?:
Hit:1 http://security.debian.org buster/updates InRelease
  nodejs
@nebz idée ?
Oui il a un problème dans son système de packages.
Nodejs étant un package comme les autres il repose dessus aussi. Pour moi, sauvegarde, réinstallation, restauration, ou s’embêter à essayer de réparer sans résultat garanti…
