Demon Jeezigbee plante sans arret
Bonjour je suis embêté, je n y connais rien et mon service Zigbee ne marche plus. le demon s’arrête sans arrêt. Avant tout marchait bien. S’agirait il d un problème de clef Sonoff HS?
 echo '*******************Begin of package installation******************'
+ touch /tmp/jeedom_install_in_progress_z2m
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/z2m/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/z2m/resources/pre-install.sh
Launch pre-install of z2m dependancy
+ echo 3
+ php /var/www/html/core/class/../php/jeecli.php plugin install mqtt2
+ echo 4
apt: no process found
apt-get: no process found
+ sudo apt update
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
Reading package lists...
Building dependency tree...
Reading state information...
16 packages can be upgraded. Run 'apt list --upgradable' to see them.
+ echo 5
apt-utils is already the newest version (2.2.4).
lsb-release is already the newest version (11.1.0).
git is already the newest version (1:2.30.2-1+deb11u3).
0 upgraded, 0 newly installed, 0 to remove and 16 not upgraded.
[Check Version NodeJS actuelle : v20.18.0 : [  OK  ]
Clean npm cache
npm warn using --force Recommended protections disabled.
+ echo 6
+ sudo apt install -o Dpkg::Options::=--force-confdef -y php-yaml
php-yaml is already the newest version (2.2.1+2.1.0+2.0.4+1.3.2-2).
+ echo 7
+ sudo systemctl restart apache2
+ echo 8
+ sudo chmod +x /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ echo Launch post-install of z2m dependancy
+ realpath /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ dirname /var/www/html/plugins/z2m/resources/post-install.sh
+ BASEDIR=/var/www/html/plugins/z2m/resources
+ [ -d /var/www/html/plugins/z2m/resources/zigbee2mqtt ]
+ rm -rf /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ mkdir /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ git clone --depth 1 https://github.com/Koenkk/zigbee2mqtt.git /var/www/html/plugins/z2m/resources/zigbee2mqtt
Cloning into '/var/www/html/plugins/z2m/resources/zigbee2mqtt'...
+ cd /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ [ -f /var/www/html/plugins/z2m/resources/../data/wanted_z2m_version ]
+ cat /var/www/html/plugins/z2m/resources/../data/wanted_z2m_version
+ wanted_z2m_version=1.41.0
+ [ ! -z 1.41.0 ]
+ echo Need version : 1.41.0
+ git fetch --all --tags
Fetching origin
From https://github.com/Koenkk/zigbee2mqtt
* [new tag]           0.1.0      -> 0.1.0
* [new tag]           0.1.1      -> 0.1.1
* [new tag]           0.1.2      -> 0.1.2
* [new tag]           0.1.3      -> 0.1.3
* [new tag]           0.1.4      -> 0.1.4
* [new tag]           0.1.5      -> 0.1.5
* [new tag]           0.1.6      -> 0.1.6
* [new tag]           0.1.7      -> 0.1.7
* [new tag]           0.1.8      -> 0.1.8
* [new tag]           0.2.0      -> 0.2.0
* [new tag]           1.0.0      -> 1.0.0
* [new tag]           1.0.1      -> 1.0.1
* [new tag]           1.1.0      -> 1.1.0
* [new tag]           1.1.1      -> 1.1.1
* [new tag]           1.10.0     -> 1.10.0
* [new tag]           1.11.0     -> 1.11.0
* [new tag]           1.12.0     -> 1.12.0
* [new tag]           1.12.1     -> 1.12.1
* [new tag]           1.12.2     -> 1.12.2
* [new tag]           1.13.0     -> 1.13.0
* [new tag]           1.13.1     -> 1.13.1
* [new tag]           1.14.0     -> 1.14.0
* [new tag]           1.14.1     -> 1.14.1
* [new tag]           1.14.2     -> 1.14.2
* [new tag]           1.14.3     -> 1.14.3
* [new tag]           1.14.4     -> 1.14.4
* [new tag]           1.15.0     -> 1.15.0
* [new tag]           1.16.0     -> 1.16.0
* [new tag]           1.16.1     -> 1.16.1
* [new tag]           1.16.2     -> 1.16.2
* [new tag]           1.17.0     -> 1.17.0
* [new tag]           1.17.1     -> 1.17.1
* [new tag]           1.18.0     -> 1.18.0
* [new tag]           1.18.1     -> 1.18.1
* [new tag]           1.18.2     -> 1.18.2
* [new tag]           1.18.3     -> 1.18.3
* [new tag]           1.19.0     -> 1.19.0
* [new tag]           1.19.1     -> 1.19.1
* [new tag]           1.2.0      -> 1.2.0
* [new tag]           1.2.1      -> 1.2.1
* [new tag]           1.20.0     -> 1.20.0
* [new tag]           1.21.0     -> 1.21.0
* [new tag]           1.21.1     -> 1.21.1
* [new tag]           1.21.2     -> 1.21.2
* [new tag]           1.22.0     -> 1.22.0
* [new tag]           1.22.1     -> 1.22.1
* [new tag]           1.22.2     -> 1.22.2
* [new tag]           1.23.0     -> 1.23.0
* [new tag]           1.24.0     -> 1.24.0
* [new tag]           1.25.0     -> 1.25.0
* [new tag]           1.25.1     -> 1.25.1
* [new tag]           1.25.2     -> 1.25.2
* [new tag]           1.26.0     -> 1.26.0
* [new tag]           1.27.0     -> 1.27.0
* [new tag]           1.27.1     -> 1.27.1
* [new tag]           1.27.2     -> 1.27.2
* [new tag]           1.28.0     -> 1.28.0
* [new tag]           1.28.1     -> 1.28.1
* [new tag]           1.28.2     -> 1.28.2
* [new tag]           1.28.3     -> 1.28.3
* [new tag]           1.28.4     -> 1.28.4
* [new tag]           1.29.0     -> 1.29.0
* [new tag]           1.29.1     -> 1.29.1
* [new tag]           1.29.2     -> 1.29.2
* [new tag]           1.3.0      -> 1.3.0
* [new tag]           1.3.1      -> 1.3.1
* [new tag]           1.30.0     -> 1.30.0
* [new tag]           1.30.1     -> 1.30.1
* [new tag]           1.30.2     -> 1.30.2
* [new tag]           1.30.3     -> 1.30.3
* [new tag]           1.30.4     -> 1.30.4
* [new tag]           1.31.0     -> 1.31.0
* [new tag]           1.31.1     -> 1.31.1
* [new tag]           1.31.2     -> 1.31.2
* [new tag]           1.32.0     -> 1.32.0
* [new tag]           1.32.1     -> 1.32.1
* [new tag]           1.32.2     -> 1.32.2
* [new tag]           1.33.0     -> 1.33.0
* [new tag]           1.33.1     -> 1.33.1
* [new tag]           1.33.2     -> 1.33.2
* [new tag]           1.34.0     -> 1.34.0
* [new tag]           1.35.0     -> 1.35.0
* [new tag]           1.35.1     -> 1.35.1
* [new tag]           1.35.2     -> 1.35.2
* [new tag]           1.35.3     -> 1.35.3
* [new tag]           1.36.0     -> 1.36.0
* [new tag]           1.36.1     -> 1.36.1
* [new tag]           1.37.0     -> 1.37.0
* [new tag]           1.37.1     -> 1.37.1
* [new tag]           1.38.0     -> 1.38.0
* [new tag]           1.39.0     -> 1.39.0
* [new tag]           1.39.1     -> 1.39.1
* [new tag]           1.4.0      -> 1.4.0
* [new tag]           1.40.0     -> 1.40.0
* [new tag]           1.40.1     -> 1.40.1
* [new tag]           1.40.2     -> 1.40.2
* [new tag]           1.41.0     -> 1.41.0
* [new tag]           1.42.0     -> 1.42.0
* [new tag]           1.5.0      -> 1.5.0
* [new tag]           1.5.1      -> 1.5.1
* [new tag]           1.6.0      -> 1.6.0
* [new tag]           1.7.0      -> 1.7.0
* [new tag]           1.7.1      -> 1.7.1
* [new tag]           1.8.0      -> 1.8.0
* [new tag]           1.9.0      -> 1.9.0
+ git checkout tags/1.41.0
Note: switching to 'tags/1.41.0'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
git switch -c <new-branch-name>
Or undo this operation with:
git switch -
Turn off this advice by setting config variable advice.detachedHead to false
HEAD is now at cc31ceab chore(dev): release 1.41.0 (#24173)
+ npm ci
npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
added 649 packages, and audited 650 packages in 40s
90 packages are looking for funding
run `npm fund` for details
2 vulnerabilities (1 low, 1 high)
To address all issues, run:
npm audit fix
Run `npm audit` for details.
+ npm run build
> zigbee2mqtt@1.41.0 build
> tsc && node index.js writehash
+ chown www-data:www-data -R /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ echo 9
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end z2m
rm: invalid option -- '/'
Try 'rm --help' for more information.
+ echo 10
+ rm /tmp/jeedom_install_in_progress_z2m
> zigbee2mqtt@1.41.0 start
> node index.js
Starting Zigbee2MQTT without watchdog.
[2025-01-03 17:41:10] e[31merrore[39m: 	z2m: Failed to load external converter file '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js' (Cannot find module 'zigbee-herdsman-converters/lib/extend'
Require stack:
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/utils.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/settings.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js)
[2025-01-03 17:41:10] e[31merrore[39m: 	z2m: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
[2025-01-03 17:41:10] e[31merrore[39m: 	z2m: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
[2025-01-03 17:41:11] e[31merrore[39m: 	zh:ezsp:uart: Error while parsing to NpiFrame 'Error: <-- CRC error: a96b2a164fa674eb04aaa76d499db3d80aaece67235f7e|235f|1d29'
[2025-01-03 17:41:18] e[31merrore[39m: 	zh:ezsp:uart: --> Error: Error: {"sequence":1} after 4000ms
[2025-01-03 17:41:18] e[31merrore[39m: 	zh:ezsp:uart: -!- break waiting (1)
[2025-01-03 17:41:18] e[31merrore[39m: 	zh:ezsp:uart: Can't send DATA frame (0,1,0): 1800012800
[2025-01-03 17:41:23] e[31merrore[39m: 	zh:ezsp:uart: --> Error: Error: {"sequence":1} after 4000ms
[2025-01-03 17:41:23] e[31merrore[39m: 	zh:ezsp:uart: -!- break rewaiting (1)
[2025-01-03 17:41:23] e[31merrore[39m: 	zh:ezsp:uart: Can't resend DATA frame (0,1,1): 1800012800
[2025-01-03 17:41:23] e[31merrore[39m: 	z2m: Error while starting zigbee-herdsman
[2025-01-03 17:41:23] e[31merrore[39m: 	z2m: Failed to start zigbee
[2025-01-03 17:41:23] e[31merrore[39m: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2025-01-03 17:41:23] e[31merrore[39m: 	z2m: Exiting...
[2025-01-03 17:41:23] e[31merrore[39m: 	z2m: Error: Failure send getNetworkParameters:{"type":"Buffer","data":[24,0,1,40,0]}
at /var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:679:23
at Queue.execute (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20)
at Ezsp.execCommand (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:666:16)
at Driver.needsToBeInitialised (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:310:27)
at Driver.startup (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:242:13)
at EZSPAdapter.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:152:16)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/zigbee.ts:69:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/controller.ts:161:27)
at start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:154:5)
> node index.js
[2025-01-03 17:46:58] e[31merrore[39m: 	z2m: Failed to load external converter file '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js' (Cannot find module 'zigbee-herdsman-converters/lib/extend'
Require stack:
[2025-01-03 17:46:58] e[31merrore[39m: 	z2m: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
[2025-01-03 17:46:58] e[31merrore[39m: 	z2m: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
[2025-01-03 17:46:59] e[31merrore[39m: 	zh:ezsp:uart: Error while parsing to NpiFrame 'Error: <-- CRC error: 9c47b76b3e879874f7cf7d8bfc3b3ea3ebccdfe0e07e|e0e0|6aab'
[2025-01-03 17:48:06] e[31merrore[39m: 	z2m: Publish 'set' 'state' to '0xa4c138931d36c9f0' failed: 'Error: ZCL command 0xa4c138931d36c9f0/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 5235 - 1 - 5 - 6 - 11 after 10000ms)'
Merci de votre aide
Informations Jeedom
Core : 4.4.19 (master)
DNS Jeedom : oui
Plugin : JeeZigbee
Version : 2024-12-17 01:01:46 (stable)
Statut Démon : Stoppé - (2025-01-03 17:36:08)
a quelle moment il a plus fonctionné ?
je ne sais pas trop… je tournais avec zigbeelinker que j ai supprimé car le demon s’arrêtait sans arrêt. De plus je voulais passer par le plugin officiel, j ai donc refais l’installation hier avec jeezigbee , tout marchais bien et depuis deux trois heure ca replante. J ai essayé de ragarder le shema des module sur la page Z2m, il ma demandé de renseigner une info, je ne sais plus exactement ce qui était noté, j 'ai donc renseigné l’identifiant qui etait noté en dessous
Mettre à jour le firmware de la Sonoff ZBDongle-E : [RTEX] Box Jeedom Atlas - plugin MQTT Manager (mqtt2) Mode Broker local - avec plugins abonnés Z-Wave JS (zwavejs) et JeeZigbee (z2m)
et dans la configuration du plugin z2m, sélectionner type de contrôleur Ember.
akenad :slight_smile:
ok merci je vais essayer ^^
voila j’ai mis a jours en sélectionnant elelabs/pop , le port de la clef puis dernier firware zigbee
puis sélection ember
relance dépendances
ca ne marche toujours pas.
tu peu passer les log après le redémarrage du daemon suite a la mise à jour du firmware?
et aussi nous donner la config du plugin plugin-z2m .
ember c est a sélectionné pour la mise a jour ou dans la config du protocole ?
[2025-01-03 18:57:50] ALERT  : sudo chmod +x /var/www/html/plugins/z2m/core/class/../../resources/misc/update-firmware-elelabs.sh;sudo /var/www/html/plugins/z2m/core/class/../../resources/misc/update-firmware-elelabs.sh /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231121165355-if00 ncp-uart-hw-v7.4.3.0-elelabs-elx0x3-115200.gbl
Begin update of /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231121165355-if00 with firmware ncp-uart-hw-v7.4.3.0-elelabs-elx0x3-115200.gbl
--2025-01-03 18:57:50--  https://github.com/Elelabs/elelabs-zigbee-ezsp-utility/archive/master.zip
Resolving github.com (github.com)... 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://codeload.github.com/Elelabs/elelabs-zigbee-ezsp-utility/zip/refs/heads/master [following]
--2025-01-03 18:57:50--  https://codeload.github.com/Elelabs/elelabs-zigbee-ezsp-utility/zip/refs/heads/master
Resolving codeload.github.com (codeload.github.com)... 140.82.121.10
Connecting to codeload.github.com (codeload.github.com)|140.82.121.10|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1247988 (1.2M) [application/zip]
Saving to: '/tmp/elelabs.zip'
0K .......... .......... .......... .......... ..........  4%  779K 2s
50K .......... .......... .......... .......... ..........  8% 1.48M 1s
100K .......... .......... .......... .......... .......... 12% 15.5M 1s
150K .......... .......... .......... .......... .......... 16% 1.66M 1s
200K .......... .......... .......... .......... .......... 20% 14.7M 1s
250K .......... .......... .......... .......... .......... 24% 15.7M 0s
300K .......... .......... .......... .......... .......... 28% 15.7M 0s
350K .......... .......... .......... .......... .......... 32% 2.10M 0s
400K .......... .......... .......... .......... .......... 36% 15.3M 0s
450K .......... .......... .......... .......... .......... 41% 14.9M 0s
500K .......... .......... .......... .......... .......... 45% 15.3M 0s
550K .......... .......... .......... .......... .......... 49% 15.9M 0s
600K .......... .......... .......... .......... .......... 53% 15.7M 0s
650K .......... .......... .......... .......... .......... 57% 15.4M 0s
700K .......... .......... .......... .......... .......... 61% 4.33M 0s
750K .......... .......... .......... .......... .......... 65% 14.4M 0s
800K .......... .......... .......... .......... .......... 69% 14.3M 0s
850K .......... .......... .......... .......... .......... 73% 15.1M 0s
900K .......... .......... .......... .......... .......... 77% 15.7M 0s
950K .......... .......... .......... .......... .......... 82% 15.5M 0s
1000K .......... .......... .......... .......... .......... 86% 15.8M 0s
1050K .......... .......... .......... .......... .......... 90% 15.6M 0s
1100K .......... .......... .......... .......... .......... 94% 15.3M 0s
1150K .......... .......... .......... .......... .......... 98% 15.8M 0s
1200K .......... ........                                   100% 15.4M=0.2s
2025-01-03 18:57:51 (5.35 MB/s) - '/tmp/elelabs.zip' saved [1247988/1247988]
Archive:  elelabs.zip
7fc415497f7e2b3410e3350b359ac5c71043399e
creating: elelabs-zigbee-ezsp-utility-master/
extracting: elelabs-zigbee-ezsp-utility-master/.gitignore
inflating: elelabs-zigbee-ezsp-utility-master/CHANGELOG.md
inflating: elelabs-zigbee-ezsp-utility-master/Elelabs_EzspFwUtility.py
inflating: elelabs-zigbee-ezsp-utility-master/LICENSE
inflating: elelabs-zigbee-ezsp-utility-master/README.md
creating: elelabs-zigbee-ezsp-utility-master/data/
creating: elelabs-zigbee-ezsp-utility-master/data/EFR32MG13/
inflating: elelabs-zigbee-ezsp-utility-master/data/EFR32MG13/ELE_MG13_ot_rcp_115200_120_211116.gbl
inflating: elelabs-zigbee-ezsp-utility-master/data/EFR32MG13/ELE_MG13_ot_rcp_123_220206.gbl
inflating: elelabs-zigbee-ezsp-utility-master/data/EFR32MG13/ELE_MG13_zb_ncp_115200_610_211112.gbl
inflating: elelabs-zigbee-ezsp-utility-master/data/EFR32MG13/ELX0X3_MG13_6.0.3_ezsp_v6.gbl
inflating: elelabs-zigbee-ezsp-utility-master/data/EFR32MG13/ELX0X3_MG13_6.7.0_ezsp_v8.gbl
creating: elelabs-zigbee-ezsp-utility-master/data/EFR32MG21/
inflating: elelabs-zigbee-ezsp-utility-master/data/EFR32MG21/ELU0141_MG21_ot_rcp_123_211204.gbl
inflating: elelabs-zigbee-ezsp-utility-master/data/EFR32MG21/ELU0141_MG21_zb_ncp_6103_211204.gbl
inflating: elelabs-zigbee-ezsp-utility-master/data/EFR32MG21/ELU0143_MG21_ot_rcp_123_211211.gbl
inflating: elelabs-zigbee-ezsp-utility-master/data/EFR32MG21/ELU0143_MG21_zb_ncp_6103_211211.gbl
creating: elelabs-zigbee-ezsp-utility-master/img/
inflating: elelabs-zigbee-ezsp-utility-master/img/ele_update_thread.png
inflating: elelabs-zigbee-ezsp-utility-master/img/ele_update_zigbee.png
inflating: elelabs-zigbee-ezsp-utility-master/img/logo.jpg
inflating: elelabs-zigbee-ezsp-utility-master/img/probe_btl.png
inflating: elelabs-zigbee-ezsp-utility-master/img/probe_thread.png
inflating: elelabs-zigbee-ezsp-utility-master/img/probe_zigbee.png
inflating: elelabs-zigbee-ezsp-utility-master/img/restart_btl.png
inflating: elelabs-zigbee-ezsp-utility-master/img/restart_nrml.png
extracting: elelabs-zigbee-ezsp-utility-master/requirements.txt
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: setuptools in /usr/local/lib/python3.9/dist-packages (75.3.0)
WARNING: Error parsing dependencies of gpg: Invalid version: '1.14.0-unknown'
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager, possibly rendering your system unusable.It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv. Use the --root-user-action option if you know what you are doing and want to suppress this warning.
Requirement already satisfied: wheel in /usr/lib/python3/dist-packages (0.34.2)
Requirement already satisfied: pyserial==3.4 in /usr/local/lib/python3.9/dist-packages (from -r requirements.txt (line 1)) (3.4)
Requirement already satisfied: xmodem==0.4.6 in /usr/local/lib/python3.9/dist-packages (from -r requirements.txt (line 2)) (0.4.6)
2025/01/03 18:57:57 Elelabs_EzspFwUtility:   Generic Zigbee EZSP adapter detected:
2025/01/03 18:57:57 Elelabs_EzspFwUtility:   Firmware: 6.10.3-41
2025/01/03 18:57:57 Elelabs_EzspFwUtility:   EZSP v8
--2025-01-03 18:57:58--  https://github.com/darkxst/silabs-firmware-builder/raw/main/firmware_builds/elelabs-elx0x3/ncp-uart-hw-v7.4.3.0-elelabs-elx0x3-115200.gbl
Location: https://raw.githubusercontent.com/darkxst/silabs-firmware-builder/main/firmware_builds/elelabs-elx0x3/ncp-uart-hw-v7.4.3.0-elelabs-elx0x3-115200.gbl [following]
--2025-01-03 18:57:58--  https://raw.githubusercontent.com/darkxst/silabs-firmware-builder/main/firmware_builds/elelabs-elx0x3/ncp-uart-hw-v7.4.3.0-elelabs-elx0x3-115200.gbl
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 2606:50c0:8000::154, 2606:50c0:8001::154, 2606:50c0:8002::154, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|2606:50c0:8000::154|:443... connected.
Length: 237504 (232K) [application/octet-stream]
Saving to: 'ncp-uart-hw-v7.4.3.0-elelabs-elx0x3-115200.gbl'
0K .......... .......... .......... .......... .......... 21% 6.54M 0s
50K .......... .......... .......... .......... .......... 43% 13.7M 0s
100K .......... .......... .......... .......... .......... 64% 21.9M 0s
150K .......... .......... .......... .......... .......... 86% 17.2M 0s
200K .......... .......... .......... .                    100% 29.6M=0.02s
2025-01-03 18:57:58 (13.2 MB/s) - 'ncp-uart-hw-v7.4.3.0-elelabs-elx0x3-115200.gbl' saved [237504/237504]
2025/01/03 18:58:00 Elelabs_EzspFwUtility:   Generic Zigbee EZSP adapter detected:
2025/01/03 18:58:00 Elelabs_EzspFwUtility:   Firmware: 6.10.3-41
2025/01/03 18:58:00 Elelabs_EzspFwUtility:   EZSP v8
2025/01/03 18:58:00 Elelabs_EzspFwUtility:   Launch in bootloader mode
2025/01/03 18:58:09 Elelabs_EzspFwUtility:   EZSP adapter in bootloader mode detected:
2025/01/03 18:58:09 Elelabs_EzspFwUtility:   Gecko Bootloader v1.12.00
2025/01/03 18:58:10 Elelabs_EzspFwUtility:   Successfully restarted into X-MODEM mode! Starting upload of the new firmware... DO NOT INTERRUPT(!)
2025/01/03 18:58:43 Elelabs_EzspFwUtility:   Firmware upload complete
2025/01/03 18:58:43 Elelabs_EzspFwUtility:   Rebooting NCP...
2025/01/03 18:58:55 Elelabs_EzspFwUtility:   EZSP adapter in bootloader mode detected:
2025/01/03 18:58:55 Elelabs_EzspFwUtility:   Gecko Bootloader v1.12.00
2025/01/03 18:59:01 Elelabs_EzspFwUtility:   EZSP adapter in bootloader mode detected:
2025/01/03 18:59:01 Elelabs_EzspFwUtility:   Gecko Bootloader v1.12.00
2025/01/03 18:59:01 Elelabs_EzspFwUtility:   Launch in normal application mode
2025/01/03 18:59:09 Elelabs_EzspFwUtility:   EZSP adapter in bootloader mode detected:
2025/01/03 18:59:09 Elelabs_EzspFwUtility:   Gecko Bootloader v1.12.00
2025/01/03 18:59:15 Elelabs_EzspFwUtility:   EZSP adapter in bootloader mode detected:
2025/01/03 18:59:15 Elelabs_EzspFwUtility:   Gecko Bootloader v1.12.00
End of update successfull
[2025-01-03 18:59:17] ALERT  : Fin de la mise à jour du firmware de la clef
Dans la configuration du plugin z2m, sélectionner type de contrôleur Ember.
je recommence la mise a jour pour vous fournir des log propres
Pour la mise à jour du firmware de la Sonoff ZBDongle-E, voir mon premier post.
au départ
je clic sur mettre a jour le firmware
[2025-01-03 19:19:02] ALERT  : sudo chmod +x /var/www/html/plugins/z2m/core/class/../../resources/misc/update-firmware-elelabs.sh;sudo /var/www/html/plugins/z2m/core/class/../../resources/misc/update-firmware-elelabs.sh /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231121165355-if00 zigbee
kill: (9): No such process
Begin update of /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231121165355-if00 with firmware zigbee
--2025-01-03 19:19:02--  https://github.com/Elelabs/elelabs-zigbee-ezsp-utility/archive/master.zip
Resolving github.com (github.com)... 140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443... connected.
--2025-01-03 19:19:03--  https://codeload.github.com/Elelabs/elelabs-zigbee-ezsp-utility/zip/refs/heads/master
0K .......... .......... .......... .......... ..........  4% 2.20M 1s
50K .......... .......... .......... .......... ..........  8% 4.06M 0s
100K .......... .......... .......... .......... .......... 12% 15.0M 0s
150K .......... .......... .......... .......... .......... 16% 5.83M 0s
200K .......... .......... .......... .......... .......... 20% 15.6M 0s
250K .......... .......... .......... .......... .......... 24% 8.54M 0s
300K .......... .......... .......... .......... .......... 28% 14.0M 0s
350K .......... .......... .......... .......... .......... 32% 15.2M 0s
400K .......... .......... .......... .......... .......... 36% 15.1M 0s
450K .......... .......... .......... .......... .......... 41% 14.3M 0s
500K .......... .......... .......... .......... .......... 45% 13.5M 0s
550K .......... .......... .......... .......... .......... 49% 13.0M 0s
600K .......... .......... .......... .......... .......... 53% 14.2M 0s
650K .......... .......... .......... .......... .......... 57% 15.0M 0s
700K .......... .......... .......... .......... .......... 61% 15.1M 0s
750K .......... .......... .......... .......... .......... 65% 15.6M 0s
800K .......... .......... .......... .......... .......... 69% 15.8M 0s
850K .......... .......... .......... .......... .......... 73% 15.4M 0s
900K .......... .......... .......... .......... .......... 77% 15.5M 0s
950K .......... .......... .......... .......... .......... 82% 15.8M 0s
1000K .......... .......... .......... .......... .......... 86% 15.2M 0s
1050K .......... .......... .......... .......... .......... 90% 15.4M 0s
1100K .......... .......... .......... .......... .......... 94% 15.8M 0s
1150K .......... .......... .......... .......... .......... 98% 15.6M 0s
1200K .......... ........                                   100% 15.3M=0.1s
2025-01-03 19:19:03 (10.4 MB/s) - '/tmp/elelabs.zip' saved [1247988/1247988]
2025/01/03 19:19:14 Elelabs_EzspFwUtility:   EZSP adapter in bootloader mode detected:
2025/01/03 19:19:14 Elelabs_EzspFwUtility:   Gecko Bootloader v1.12.00
2025/01/03 19:19:21 Elelabs_EzspFwUtility:   EZSP adapter in bootloader mode detected:
2025/01/03 19:19:21 Elelabs_EzspFwUtility:   Gecko Bootloader v1.12.00
2025/01/03 19:19:21 Elelabs_EzspFwUtility:   The product not in the normal EZSP mode.
'restart' into normal mode or use 'flash' utility instead
2025/01/03 19:19:27 Elelabs_EzspFwUtility:   EZSP adapter in bootloader mode detected:
2025/01/03 19:19:27 Elelabs_EzspFwUtility:   Gecko Bootloader v1.12.00
2025/01/03 19:19:27 Elelabs_EzspFwUtility:   Launch in normal application mode
2025/01/03 19:19:35 Elelabs_EzspFwUtility:   EZSP adapter in bootloader mode detected:
2025/01/03 19:19:35 Elelabs_EzspFwUtility:   Gecko Bootloader v1.12.00
2025/01/03 19:19:41 Elelabs_EzspFwUtility:   EZSP adapter in bootloader mode detected:
2025/01/03 19:19:41 Elelabs_EzspFwUtility:   Gecko Bootloader v1.12.00
[2025-01-03 19:19:43] ALERT  : Fin de la mise à jour du firmware de la clef
> node index.js
[2025-01-03 19:19:50] e[31merrore[39m: 	z2m: Failed to load external converter file '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js' (Cannot find module 'zigbee-herdsman-converters/lib/extend'
Require stack:
[2025-01-03 19:19:50] e[31merrore[39m: 	z2m: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
[2025-01-03 19:19:50] e[31merrore[39m: 	z2m: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
[2025-01-03 19:20:03] e[31merrore[39m: 	z2m: Error while starting zigbee-herdsman
[2025-01-03 19:20:03] e[31merrore[39m: 	z2m: Failed to start zigbee
[2025-01-03 19:20:03] e[31merrore[39m: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2025-01-03 19:20:03] e[31merrore[39m: 	z2m: Exiting...
[2025-01-03 19:20:04] e[31merrore[39m: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:684:19)
at EmberAdapter.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1598:24)
je le trouve pas :frowning:
Voir : Silabs Firmware Flasher | Web based flasher for ZB-GW04 and ZBDongle-E. MultiPAN RCP firmware enables these devices to be used with Silabs Multiprotocol Addon in Home Assistant. Allow Zigbee and Thread to co-exist on the same dongle. Get ahead of the tech an experiment with Matter!
thx merci
Merci d’utiliser la balise prévue à cet effet pour poster des logs à l’avenir sinon c’est illisible:
saisissez ou collez du code ici
