Bonjour, est-il possible d’intégrer les nouvelles ampoules lexman ZBEK-11
Voici le lien
Ampoule ZBEK-11
Les infos brutes
"ieee": "38:5b:44:ff:fe:41:d9:ed",
"nwk": 12343,
"status": 2,
"lqi": "236",
"rssi": "-66",
"last_seen": "1672078476.373374",
"node_descriptor": "01:40:8e:77:12:52:00:04:00:2c:00:04:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 268,
"profile_id": 260,
"manufacturer": "Adeo",
"model": "ZBEK-11",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 2
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "Adeo"
"id": 5,
"name": "model",
"value": "ZBEK-11"
"id": 6,
"name": "date_code",
"value": "20211207"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "2.11.01"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 8,
"name": "Level control",
"attributes": [
"id": 0,
"name": "current_level",
"value": 254
"id": 768,
"name": "Color Control",
"attributes": [
"id": 3,
"name": "current_x",
"value": 29991
"id": 4,
"name": "current_y",
"value": 26872
"id": 7,
"name": "color_temperature",
"value": 153
"id": 4096,
"name": "LightLink",
"attributes": []
"id": 64599,
"name": "Manufacturer Specific",
"attributes": []
"id": 64642,
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"model": "ZBEK-11",
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4727,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 1024,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 1024,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 268,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768,
4096,
64599,
64642
25
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
le log zigbee
0000|[2022-12-26 19:13:22]INFO : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyACM0 --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey UCXwKSlrqbYhF3TlrMi4f1jQcK76wr96KmBgLAlPW4kSeU9veYRg3f6h6AkAfPuO --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller deconz --sub_controller auto --channel 15
0001|[2022-12-26 19:13:26]DEBUG : null
0002|[2022-12-26 19:13:38]DEBUG : http://127.0.0.1:8089/device/command type : PUT
0003|[2022-12-26 19:13:38]DEBUG : {"ieee":"38:5b:44:ff:fe:41:d9:ed","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false}
0004|[2022-12-26 19:13:39]DEBUG : {"devices":{"38:5b:44:ff:fe:41:d9:ed":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
0005|[2022-12-26 19:13:39]DEBUG : Search attribut for 38:5b:44:ff:fe:41:d9:ed logicalId : 1::6::0 => Bool.false convert to 0
0006|[2022-12-26 19:13:40]DEBUG : http://127.0.0.1:8089/device/command type : PUT
0007|[2022-12-26 19:13:40]DEBUG : {"ieee":"38:5b:44:ff:fe:41:d9:ed","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
0008|[2022-12-26 19:13:40]DEBUG : {"devices":{"38:5b:44:ff:fe:41:d9:ed":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
0009|[2022-12-26 19:13:40]DEBUG : Search attribut for 38:5b:44:ff:fe:41:d9:ed logicalId : 1::6::0 => Bool.true convert to 1
0010|[2022-12-26 19:13:42]DEBUG : http://127.0.0.1:8089/device/command type : PUT
0011|[2022-12-26 19:13:42]DEBUG : {"ieee":"38:5b:44:ff:fe:41:d9:ed","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":[0,0]}],"allowQueue":false}
0012|[2022-12-26 19:13:43]ERROR : Erreur exécution de la commande [Salon][Lumière Salon 1][Luminosité] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"38:5b:44:ff:fe:41:d9:ed","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":[0,0]}],"allowQueue":false} erreur : {"state":"error","result":"[0x3037:1:0x0008]: Message send failure","code":0}
0013|[2022-12-26 19:13:55]DEBUG : http://127.0.0.1:8089/device/command type : PUT
0014|[2022-12-26 19:13:55]DEBUG : {"ieee":"38:5b:44:ff:fe:41:d9:ed","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":[159,0]}],"allowQueue":false}
0015|[2022-12-26 19:13:56]DEBUG : {"devices":{"38:5b:44:ff:fe:41:d9:ed":{"1":{"8":[{"value":"159","cluster_name":"Level control"}]}}}}
0016|[2022-12-26 19:13:56]DEBUG : Search attribut for 38:5b:44:ff:fe:41:d9:ed logicalId : 1::8::0 => 159 convert to 159
0017|[2022-12-26 19:13:56]DEBUG : http://127.0.0.1:8089/device/command type : PUT
0018|[2022-12-26 19:13:56]DEBUG : {"ieee":"38:5b:44:ff:fe:41:d9:ed","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":[254,0]}],"allowQueue":false}
0019|[2022-12-26 19:13:57]DEBUG : {"devices":{"38:5b:44:ff:fe:41:d9:ed":{"1":{"8":[{"value":"254","cluster_name":"Level control"}]}}}}
0020|[2022-12-26 19:13:57]DEBUG : Search attribut for 38:5b:44:ff:fe:41:d9:ed logicalId : 1::8::0 => 254 convert to 254
0021|[2022-12-26 19:14:05]DEBUG : http://127.0.0.1:8089/device/command type : PUT
0022|[2022-12-26 19:14:05]DEBUG : {"ieee":"38:5b:44:ff:fe:41:d9:ed","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color","await":1,"args":[34310,20529,0]}],"allowQueue":false}
0023|[2022-12-26 19:14:06]DEBUG : http://127.0.0.1:8089/device/command type : PUT
0024|[2022-12-26 19:14:06]DEBUG : {"ieee":"38:5b:44:ff:fe:41:d9:ed","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color_temp","await":1,"args":[264,0]}],"allowQueue":false}
0025|[2022-12-26 19:14:06]DEBUG : {"devices":{"38:5b:44:ff:fe:41:d9:ed":{"1":{"768":{"7":{"value":"264","cluster_name":"Color Control"}}}}}}
0026|[2022-12-26 19:14:06]DEBUG : Search attribut for 38:5b:44:ff:fe:41:d9:ed logicalId : 1::768::7 => 264 convert to 264
0027|[2022-12-26 19:14:07]DEBUG : http://127.0.0.1:8089/device/command type : PUT
0028|[2022-12-26 19:14:07]DEBUG : {"ieee":"38:5b:44:ff:fe:41:d9:ed","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color_temp","await":1,"args":[500,0]}],"allowQueue":false}
0029|[2022-12-26 19:14:10]DEBUG : http://127.0.0.1:8089/device/command type : PUT
0030|[2022-12-26 19:14:10]DEBUG : {"ieee":"38:5b:44:ff:fe:41:d9:ed","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color_temp","await":1,"args":[0,0]}],"allowQueue":false}
0031|[2022-12-26 19:14:36]DEBUG : {"devices":{"38:5b:44:ff:fe:41:d9:ed":{"1":{"768":{"7":{"value":"153","cluster_name":"Color Control"}}}}}}
0032|[2022-12-26 19:14:36]DEBUG : Search attribut for 38:5b:44:ff:fe:41:d9:ed logicalId : 1::768::7 => 153 convert to 153
0033|[2022-12-26 19:15:07]DEBUG : http://127.0.0.1:8089/device/all type : GET
0034|[2022-12-26 19:15:07]DEBUG : null
0035|[2022-12-26 19:18:16]DEBUG : http://127.0.0.1:8089/device/info?ieee=38%3A5b%3A44%3Aff%3Afe%3A41%3Ad9%3Aed type : GET
0036|[2022-12-26 19:18:16]DEBUG : {"ieee":"38:5b:44:ff:fe:41:d9:ed"}
et l’image
Merci pour votre réactivité
