J’ai acheté cette sonde sur domadoo qui doit être très proche du modèle AAQS-S01, mais ça ne doit pas être tout à fait le même;
Le modèle reçu est : Xiaomi VOCKQJK11LM, pourtant chez domadoo c’est le AAQS-001 qui est référencé.
"ieee": "54:ef:44:10:00:2a:6c:0e",
"nwk": 51083,
"status": 2,
"lqi": "None",
"rssi": "None",
"last_seen": "None",
"node_descriptor": "02:40:80:5f:11:7f:64:00:00:2c:64:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 770,
"profile_id": 260,
"manufacturer": "LUMI",
"model": "lumi.airmonitor.acn01",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "BasicCluster",
"attributes": [
"id": 4,
"name": "manufacturer",
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.airmonitor.acn01"
"id": 3,
"name": "Identify",
"attributes": []
"id": 1026,
"name": "Temperature Measurement",
"attributes": [
"id": 0,
"name": "measured_value",
"value": 2202
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 30
"id": 33,
"name": "battery_percentage_remaining",
"value": 200
"id": 1029,
"name": "Relative Humidity Measurement",
"attributes": []
"id": 12,
"name": "AnalogInputCluster",
"attributes": [
"id": 85,
"name": "present_value",
"value": 88
"id": 1070,
"name": "VOC Level",
"attributes": [
"id": 0,
"value": 88
"signature": {
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4447,
"maximum_buffer_size": 127,
"maximum_incoming_transfer_size": 100,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 100,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 770,
"input_clusters": [
0,
3,
1026,
1,
1029,
12,
1070
25
"class": "zhaquirks.xiaomi.aqara.tvoc"
Logs zigbee :
[2021-11-14 08:55:10][DEBUG] : Connection made
[2021-11-14 08:55:10][DEBUG] : Command Command.read_parameter (1, <NetworkParameter.protocol_version: 34>, b'')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a02000800010022
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a02000a000300220e01
[2021-11-14 08:55:10][DEBUG] : Read parameter protocol_version response: [270]
[2021-11-14 08:55:10][DEBUG] : Command Command.version (0,)
[2021-11-14 08:55:10][DEBUG] : Send: 0x0d0300090000000000
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0d0300090000076f26
[2021-11-14 08:55:10][DEBUG] : Version response: 266f0700
[2021-11-14 08:55:10][DEBUG] : Command Command.device_state (0, 0, 0)
[2021-11-14 08:55:10][DEBUG] : Send: 0x0704000800000000
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0704000800a2006f
[2021-11-14 08:55:10][DEBUG] : Device state response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 162>, 0, 111]
[2021-11-14 08:55:10][DEBUG] : Network state transition: OFFLINE -> CONNECTED
[2021-11-14 08:55:10][DEBUG] : Command Command.read_parameter (1, <NetworkParameter.mac_address: 1>, b'')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a05000800010001
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a0500100009000108e804ffff2e2100
[2021-11-14 08:55:10][DEBUG] : Read parameter mac_address response: [00:21:2e:ff:ff:04:e8:08]
[2021-11-14 08:55:10][DEBUG] : Command Command.read_parameter (1, <NetworkParameter.aps_designed_coordinator: 9>, b'')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a06000800010009
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a0600090002000901
[2021-11-14 08:55:10][DEBUG] : Read parameter aps_designed_coordinator response: [1]
[2021-11-14 08:55:10][DEBUG] : Command Command.write_parameter (5, <NetworkParameter.watchdog_ttl: 38>, b'X\x02\x00\x00')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0b07000c0005002658020000
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0b07000800010026
[2021-11-14 08:55:10][DEBUG] : Write parameter watchdog_ttl: SUCCESS
[2021-11-14 08:55:10][DEBUG] : Send: 0x0708000800000000
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0708000800a20026
[2021-11-14 08:55:10][DEBUG] : Device state response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 162>, 0, 38]
[2021-11-14 08:55:10][DEBUG] : Command Command.read_parameter (1, <NetworkParameter.nwk_address: 7>, b'')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a09000800010007
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a09000a000300070000
[2021-11-14 08:55:10][DEBUG] : Read parameter nwk_address response: [0x0000]
[2021-11-14 08:55:10][DEBUG] : Command Command.read_parameter (1, <NetworkParameter.nwk_panid: 5>, b'')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a0a000800010005
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a0a000a00030005621a
[2021-11-14 08:55:10][DEBUG] : Read parameter nwk_panid response: [0x1a62]
[2021-11-14 08:55:10][DEBUG] : Command Command.read_parameter (1, <NetworkParameter.nwk_extended_panid: 8>, b'')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a0b000800010008
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a0b00100009000808e804ffff2e2100
[2021-11-14 08:55:10][DEBUG] : Read parameter nwk_extended_panid response: [00:21:2e:ff:ff:04:e8:08]
[2021-11-14 08:55:10][DEBUG] : Command Command.read_parameter (1, <NetworkParameter.channel_mask: 10>, b'')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a0c00080001000a
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a0c000c0005000a00800000
[2021-11-14 08:55:10][DEBUG] : Read parameter channel_mask response: [<Channels.CHANNEL_15: 32768>]
[2021-11-14 08:55:10][DEBUG] : Command Command.read_parameter (1, <NetworkParameter.aps_extended_panid: 11>, b'')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a0d00080001000b
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a0d00100009000b0000000000000000
[2021-11-14 08:55:10][DEBUG] : Read parameter aps_extended_panid response: [00:00:00:00:00:00:00:00]
[2021-11-14 08:55:10][DEBUG] : Command Command.read_parameter (1, <NetworkParameter.trust_center_address: 14>, b'')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a0e00080001000e
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a0e00100009000e08e804ffff2e2100
[2021-11-14 08:55:10][DEBUG] : Read parameter trust_center_address response: [00:21:2e:ff:ff:04:e8:08]
[2021-11-14 08:55:10][DEBUG] : Command Command.read_parameter (1, <NetworkParameter.security_mode: 16>, b'')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a0f000800010010
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a0f00090002001003
[2021-11-14 08:55:10][DEBUG] : Read parameter security_mode response: [3]
[2021-11-14 08:55:10][DEBUG] : Command Command.read_parameter (1, <NetworkParameter.current_channel: 28>, b'')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a1000080001001c
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a1000090002001c0f
[2021-11-14 08:55:10][DEBUG] : Read parameter current_channel response: [15]
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a11000800010022
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a11000a000300220e01
[2021-11-14 08:55:10][DEBUG] : Command Command.read_parameter (1, <NetworkParameter.nwk_update_id: 36>, b'')
[2021-11-14 08:55:10][DEBUG] : Send: 0x0a12000800010024
[2021-11-14 08:55:10][DEBUG] : Frame received: 0x0a1200090002002401
[2021-11-14 08:55:10][DEBUG] : Read parameter nwk_update_id response: [1]
[2021-11-14 08:55:10][INFO] : [00:21:2e:ff:ff:04:e8:08][listener.device_initialized] new=False
[2021-11-14 08:55:10][INFO] : [start_zigbee] Init and start http server : {'database_path': '/var/www/html/plugins/zigbee/data/1/network_deconz.db', 'device': {'path': '/dev/ttyACM0'}, 'network': {'channel': 11}}
[2021-11-14 08:55:10][INFO] : [start_zigbee] Start zigbee network
Merci d’avance.
