Demande d'inclusion TZE200_nslr42tt.TS0601 / owon PC321 version tuya
Bonjour je viens de commander sur domadoo ce compteur de consommation mais je me suis trompé de version car en version Tuya.
Est-il possible de l’intégrer dans le plugin zigbee? (deja pris en compte dans zigbee2mqtt https://www.zigbee2mqtt.io/devices/TS0601_3_phase_clamp_meter.html
ci-dessous les informations brutes après inclusion via plugin zigbee et clef sonoff:
    "ieee": "a4:c1:38:5c:31:a8:84:5f",
    "nwk": 47303,
    "status": 2,
    "lqi": "36",
    "rssi": "None",
    "last_seen": "1672481838.685436",
    "node_descriptor": "01:40:8e:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 257,
            "profile_id": 260,
            "manufacturer": "_TZE200_nslr42tt",
            "model": "TS0601",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 8,
                    "name": "Level control",
                    "attributes": [
                            "id": 0,
                            "name": "current_level",
                            "value": 255
                    "id": 768,
                    "name": "Color Control",
                    "attributes": [
                            "id": 3,
                            "name": "current_x",
                            "value": 0
                            "id": 4,
                            "name": "current_y",
                            "value": 0
                            "id": 7,
                            "name": "color_temperature",
                            "value": 0
                    "id": 61184,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 69
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZE200_nslr42tt"
                            "id": 5,
                            "name": "model",
                            "value": "TS0601"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "model": "TS0601",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 257,
                "input_clusters": [
                    4,
                    5,
                    6,
                    8,
                    768,
                    61184,
                    0
                    25,
                    10
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zigpy.device"
merci bien
bonjour, tu as réussi a avoir des valeurs ?
l’équipement remonte en ampoule dimmable
Je ne l’ai pas réactivé. J’ai acheté la version non tuya.
Mais je vais essayer à nouveau dans quelques jours je pense.
Serait il possible de la part des dev de rajouter ce module ?
