Je souhaiterais l’ajout dans le plugin de l’interrupteur 1 bouton, filaire, sans neutre de Zemismart.
Voici le lien sur ALiExpress :
Interrupteurs Zigbee Zemismart sur Aliexpress
Voici les infos brutes
"ieee": "84:2e:14:ff:fe:fa:18:c4",
"nwk": 37650,
"status": 2,
"lqi": "196",
"rssi": "-51",
"last_seen": "1617964157.7089617",
"node_descriptor": "02:40:80:02:10:52:00:02:00:2c:00:02:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": "_TYZB01_xfpdrwvc",
"model": "TS0011",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 65
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TYZB01_xfpdrwvc"
"id": 5,
"name": "model",
"value": "TS0011"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"signature": {
"model": "TS0011",
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 512,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 512,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
0,
4,
5,
6
25
"class": "zigpy.device"
Et voici le debug Zigbee
[2021-04-09 12:50:58][DEBUG] : {"devices":{"00:15:8d:00:03:41:c2:c5":{"1":{"2820":{"1285":{"value":"237","cluster_name":"Electrical Measurement"}}}}}}
[2021-04-09 12:50:58][DEBUG] : Search attribut for 00:15:8d:00:03:41:c2:c5 logicalId : 1::2820::1285 => 237
[2021-04-09 12:51:06][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2021-04-09 12:51:07][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device auto --loglevel debug --socketport 8065 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey U3Pdn5cU5YT9XUrVlcauNLVMk56itBDe --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller deconz --sub_controller auto --channel 15 --folder_OTA /var/www/html/plugins/zigbee/data/ota
[2021-04-09 12:51:08][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device auto --loglevel debug --socketport 8090 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey U3Pdn5cU5YT9XUrVlcauNLVMk56itBDe --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_2.pid --data_folder /var/www/html/plugins/zigbee/data/2 --device_folder /var/www/html/plugins/zigbee/data/device --controller ezsp --sub_controller elelabs --channel 20 --folder_OTA /var/www/html/plugins/zigbee/data/ota
[2021-04-09 12:51:08][DEBUG] : null
[2021-04-09 12:51:09][DEBUG] : null
[2021-04-09 12:51:12][DEBUG] : {"devices":{"84:2e:14:ff:fe:fa:18:c4":{"1":[{"1":{"value":"65","cluster_name":"Basic"},"65506":{"value":"19","cluster_name":"Basic"}}]}}}
[2021-04-09 12:51:12][DEBUG] : Search attribut for 84:2e:14:ff:fe:fa:18:c4 logicalId : 1::0::1 => 65
[2021-04-09 12:51:12][DEBUG] : Search attribut for 84:2e:14:ff:fe:fa:18:c4 logicalId : 1::0::65506 => 19
[2021-04-09 12:51:12][DEBUG] : {"devices":{"00:15:8d:00:03:41:c2:c5":{"1":{"2820":{"1285":{"value":"235","cluster_name":"Electrical Measurement"}}}}}}
[2021-04-09 12:51:12][DEBUG] : Search attribut for 00:15:8d:00:03:41:c2:c5 logicalId : 1::2820::1285 => 235
[2021-04-09 12:51:23][DEBUG] : {"devices":{"84:2e:14:ff:fe:fa:18:c4":{"1":{"6":{"0":{"value":"Bool.true","cluster_name":"On\/Off"},"16385":{"value":"0","cluster_name":"On\/Off"},"16386":{"value":"0","cluster_name":"On\/Off"}}}}}}
[2021-04-09 12:51:23][DEBUG] : Search attribut for 84:2e:14:ff:fe:fa:18:c4 logicalId : 1::6::0 => Bool.true
[2021-04-09 12:51:23][DEBUG] : Search attribut for 84:2e:14:ff:fe:fa:18:c4 logicalId : 1::6::16385 => 0
[2021-04-09 12:51:23][DEBUG] : Search attribut for 84:2e:14:ff:fe:fa:18:c4 logicalId : 1::6::16386 => 0
[2021-04-09 12:51:24][DEBUG] : {"devices":{"84:2e:14:ff:fe:fa:18:c4":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-04-09 12:51:24][DEBUG] : Search attribut for 84:2e:14:ff:fe:fa:18:c4 logicalId : 1::6::0 => Bool.false
[2021-04-09 12:51:26][DEBUG] : {"devices":{"84:2e:14:ff:fe:fa:18:c4":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-04-09 12:51:26][DEBUG] : Search attribut for 84:2e:14:ff:fe:fa:18:c4 logicalId : 1::6::0 => Bool.true
[2021-04-09 12:51:29][DEBUG] : {"devices":{"84:2e:14:ff:fe:fa:18:c4":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-04-09 12:51:29][DEBUG] : Search attribut for 84:2e:14:ff:fe:fa:18:c4 logicalId : 1::6::0 => Bool.false
[2021-04-09 12:51:33][DEBUG] : {"devices":{"84:2e:14:ff:fe:fa:18:c4":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-04-09 12:51:33][DEBUG] : Search attribut for 84:2e:14:ff:fe:fa:18:c4 logicalId : 1::6::0 => Bool.true
[2021-04-09 12:51:36][DEBUG] : {"devices":{"84:2e:14:ff:fe:fa:18:c4":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-04-09 12:51:36][DEBUG] : Search attribut for 84:2e:14:ff:fe:fa:18:c4 logicalId : 1::6::0 => Bool.false
[2021-04-09 12:51:40][DEBUG] : {"devices":{"84:2e:14:ff:fe:fa:18:c4":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-04-09 12:51:40][DEBUG] : Search attribut for 84:2e:14:ff:fe:fa:18:c4 logicalId : 1::6::0 => Bool.true
Il y a des photos sur le site ALiExpress mais je peux faire une photo d’un des miens sur le mur…
Merci d’avance
