Hello @Loic !
Je rebondis sur le sujet, car je pense que j’ai exactement le même problème que QTN avec le Starkvind (erreur du Cluster not found 514, code:0).
L’erreur est la suivante quand je clique sur le bouton AUTO par exemple :
Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(PUT), data : {"ieee":"cc:86:ec:ff:fe:6d:33:57","attributes":[{"endpoint":1,"cluster_type":"in","cluster":514,"attributes":{"0":5}}],"allowQueue":false} erreur : {"state":"error","result":"[cc:86:ec:ff:fe:6d:33:57][zdevices.write_attributes] Cluster not found : 514","code":0}
Voici plus d’informations :
Les infos brutes :
"ieee": "cc:86:ec:ff:fe:6d:33:57",
"nwk": 56279,
"status": 2,
"lqi": "168",
"rssi": "0",
"last_seen": "1658859101.741628",
"node_descriptor": "01:40:8e:7c:11:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 7,
"profile_id": 260,
"manufacturer": "IKEA of Sweden",
"model": "STARKVIND Air purifier",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 1024,
"name": "Illuminance Measurement",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 16
"id": 2,
"name": "stack_version",
"value": 103
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "IKEA of Sweden"
"id": 5,
"name": "model",
"value": "STARKVIND Air purifier"
"id": 6,
"name": "date_code",
"value": "20210428"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "1.0.033"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": [
"id": 4,
"name": "name_support",
"value": 0
"id": 64599,
"name": "Manufacturer Specific",
"attributes": []
"id": 64637,
"name": "Ikea Airpurifier",
"attributes": [
"id": 1,
"name": "replace_filter",
"value": 0
"id": 4,
"name": "air_quality_25pm",
"value": 10
"id": 7,
"name": "fan_speed",
"value": 10
"id": 1066,
"name": "PM2.5",
"attributes": [
"id": 0,
"name": "measured_value",
"value": 10
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4476,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 7,
"input_clusters": [
0,
3,
4,
5,
64599,
64637,
1066
25,
1024
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zhaquirks.ikea.starkvind"
Le JSON :
"name": "IKEA_of_Sweden.STARKVIND_Air_purifier",
"configuration": [],
"commands": [
"logicalId": "refresh",
"name": "Rafraîchir",
"type": "action",
"subType": "other",
"isHistorized": "0",
"template": {
"dashboard": "default",
"mobile": "default"
"isVisible": "1"
"logicalId": "1::514::0",
"name": "Mode",
"type": "info",
"subType": "numeric",
"template": {
"mobile": "default"
"isVisible": "1"
"logicalId": "attributes::1::in::514::0::0",
"name": "Off",
"type": "action",
"subType": "other",
"template": {
"mobile": "default"
"value": "Mode",
"isVisible": "1"
"logicalId": "attributes::1::in::514::0::1",
"name": "Bas",
"type": "action",
"subType": "other",
"template": {
"mobile": "default"
"value": "Mode",
"isVisible": "1"
"logicalId": "attributes::1::in::514::0::2",
"name": "Moyen",
"type": "action",
"subType": "other",
"template": {
"mobile": "default"
"value": "Mode",
"isVisible": "1"
"logicalId": "attributes::1::in::514::0::3",
"name": "Rapide",
"type": "action",
"subType": "other",
"template": {
"mobile": "default"
"value": "Mode",
"isVisible": "1"
"logicalId": "attributes::1::in::514::0::5",
"name": "Auto",
"type": "action",
"subType": "other",
"template": {
"mobile": "default"
"isVisible": "1"
"logicalId": "1::64599::0",
"name": "Durée de fonctionnement du filtre",
"type": "info",
"template": {
"mobile": "default"
"isVisible": "1"
"logicalId": "1::64599::2",
"name": "Durée de vie restante du filtre",
"type": "info",
"template": {
"mobile": "default"
"isVisible": "1"
"logicalId": "1::64599::1",
"name": "Etat filtre",
"type": "info",
"template": {
"mobile": "default"
"isVisible": "1"
"logicalId": "1::64599::4",
"name": "Qualité de lair",
"type": "info",
"template": {
"mobile": "default"
"isVisible": "1"
"logicalId": "1::64599::8",
"name": "Temps de fonctionnement",
"type": "info",
"template": {
"mobile": "default"
"isVisible": "1"
"logicalId": "1::64599::7",
"name": "Mode en cours",
"type": "info",
"template": {
"mobile": "default"
"isVisible": "1"
"ref": "IKEA_of_Sweden.STARKVIND_Air_purifier"
Et quand je renseigne l’attribut 1 dans les actions voici ce que cela donne :
Voilà, j’espère avoir été le plus complet possible, j’ai essayé de trouver comment faire la liaison entre attributs et les boutons qu’il y a dans le dashboard, mais j’avoue ne pas avoir trouver la solution et le lien entre les éléments
Merci beaucoup
