Demande d'ajout pour ampoule couleur smart bulb zigbee
Bonjour, je vais tenter ma 1ere demande d’ajout de matériel non reconnu, en espérant que ce soit accepté et que je la ferai conformément.
lumiere
je l’ai acheté sur Aliexpress [ici]
(https://fr.aliexpress.com/item/1005003097642075.html?gatewayAdapt=glo2fra&spm=a2g0o.9042311.0.0.53fb6c37KaVe2J)
Informations brutes :
    "ieee": "a4:c1:38:48:f3:fe:2d:45",
    "nwk": 52315,
    "status": 2,
    "lqi": "156",
    "rssi": "-61",
    "last_seen": "1642539292.766795",
    "node_descriptor": "01:40:8e:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 269,
            "profile_id": 260,
            "manufacturer": "_TZ3210_remypqqm",
            "model": "TS0505B",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
                    "id": 4096,
                    "name": "LightLink",
                    "attributes": []
                    "id": 8,
                    "name": "Level control",
                    "attributes": []
                    "id": 768,
                    "name": "Color Control",
                    "attributes": []
                    "id": 61184,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 94
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3210_remypqqm"
                            "id": 5,
                            "name": "model",
                            "value": "TS0505B"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "model": "TS0505B",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 269,
                "input_clusters": [
                    3,
                    4,
                    5,
                    6,
                    4096,
                    8,
                    768,
                    61184,
                    0
                    25,
                    10
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zigpy.device"
[2022-01-18 21:34:36][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyS2 --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey 463UjCsR16wm2CA4HEEwgGHQXCkaBAiO --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller ezsp --sub_controller elelabs --channel 15 --folder_OTA /var/www/html/plugins/zigbee/data/ota
[2022-01-18 21:34:37][DEBUG] : null
[2022-01-18 21:35:03][DEBUG] : {"devices":{"a4:c1:38:48:f3:fe:2d:45":{"1":{"61184":{"cmd":{"0":{"value":"6","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"1","cluster_name":"Cluster"},"1.2":{"value":"81","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"255","cluster_name":"Cluster"},"1.7":{"value":"255","cluster_name":"Cluster"},"1.8":{"value":"255","cluster_name":"Cluster"},"1.9":{"value":"206","cluster_name":"Cluster"}}}}}}}
[2022-01-18 21:35:03][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::0 => 6 convert to 6
[2022-01-18 21:35:03][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2022-01-18 21:35:03][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.1 => 1 convert to 1
[2022-01-18 21:35:03][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.2 => 81 convert to 81
[2022-01-18 21:35:03][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2022-01-18 21:35:03][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2022-01-18 21:35:03][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2022-01-18 21:35:03][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.6 => 255 convert to 255
[2022-01-18 21:35:03][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.7 => 255 convert to 255
[2022-01-18 21:35:03][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.8 => 255 convert to 255
[2022-01-18 21:35:03][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.9 => 206 convert to 206
[2022-01-18 21:35:10][DEBUG] : {"devices":{"a4:c1:38:48:f3:fe:2d:45":{"1":{"61184":{"cmd":{"0":{"value":"6","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"1","cluster_name":"Cluster"},"1.2":{"value":"81","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"255","cluster_name":"Cluster"},"1.7":{"value":"255","cluster_name":"Cluster"},"1.8":{"value":"255","cluster_name":"Cluster"},"1.9":{"value":"206","cluster_name":"Cluster"}}}}}}}
[2022-01-18 21:35:10][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::0 => 6 convert to 6
[2022-01-18 21:35:10][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2022-01-18 21:35:10][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.1 => 1 convert to 1
[2022-01-18 21:35:10][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.2 => 81 convert to 81
[2022-01-18 21:35:10][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2022-01-18 21:35:10][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2022-01-18 21:35:10][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2022-01-18 21:35:10][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.6 => 255 convert to 255
[2022-01-18 21:35:10][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.7 => 255 convert to 255
[2022-01-18 21:35:10][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.8 => 255 convert to 255
[2022-01-18 21:35:10][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.9 => 206 convert to 206
[2022-01-18 21:42:00][DEBUG] : {"devices":{"a4:c1:38:48:f3:fe:2d:45":{"1":{"61184":{"cmd":{"0":{"value":"6","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"1","cluster_name":"Cluster"},"1.2":{"value":"81","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"255","cluster_name":"Cluster"},"1.7":{"value":"255","cluster_name":"Cluster"},"1.8":{"value":"255","cluster_name":"Cluster"},"1.9":{"value":"206","cluster_name":"Cluster"}}}}}}}
[2022-01-18 21:42:00][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::0 => 6 convert to 6
[2022-01-18 21:42:00][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2022-01-18 21:42:00][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.1 => 1 convert to 1
[2022-01-18 21:42:00][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.2 => 81 convert to 81
[2022-01-18 21:42:00][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2022-01-18 21:42:00][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2022-01-18 21:42:00][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2022-01-18 21:42:00][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.6 => 255 convert to 255
[2022-01-18 21:42:00][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.7 => 255 convert to 255
[2022-01-18 21:42:00][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.8 => 255 convert to 255
[2022-01-18 21:42:00][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.9 => 206 convert to 206
[2022-01-18 21:45:03][DEBUG] : http://127.0.0.1:8089/device/all type : GET
[2022-01-18 21:45:03][DEBUG] : null
[2022-01-18 21:46:24][DEBUG] : {"devices":{"00:12:4b:00:24:c2:50:d0":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2022-01-18 21:46:24][DEBUG] : Search attribut for 00:12:4b:00:24:c2:50:d0 logicalId : 1::6::0 => Bool.false convert to 0
[2022-01-18 21:46:38][DEBUG] : {"devices":{"00:12:4b:00:24:c2:51:83":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2022-01-18 21:46:38][DEBUG] : Search attribut for 00:12:4b:00:24:c2:51:83 logicalId : 1::6::0 => Bool.true convert to 1
[2022-01-18 21:47:02][DEBUG] : {"devices":{"00:12:4b:00:24:c1:18:ac":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2022-01-18 21:47:02][DEBUG] : Search attribut for 00:12:4b:00:24:c1:18:ac logicalId : 1::6::0 => Bool.true convert to 1
[2022-01-18 21:50:59][DEBUG] : {"devices":{"80:4b:50:ff:fe:0b:d2:4f":{"1":{"1":{"33":{"value":"200","cluster_name":"Power Configuration"}}}}}}
[2022-01-18 21:51:05][DEBUG] : {"devices":{"80:4b:50:ff:fe:0b:d2:4f":{"1":{"1":{"32":{"value":"32","cluster_name":"Power Configuration"}}}}}}
[2022-01-18 21:53:52][DEBUG] : {"devices":{"a4:c1:38:48:f3:fe:2d:45":{"1":{"61184":{"cmd":{"0":{"value":"6","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"1","cluster_name":"Cluster"},"1.2":{"value":"81","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"255","cluster_name":"Cluster"},"1.7":{"value":"255","cluster_name":"Cluster"},"1.8":{"value":"255","cluster_name":"Cluster"},"1.9":{"value":"206","cluster_name":"Cluster"}}}}}}}
[2022-01-18 21:53:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::0 => 6 convert to 6
[2022-01-18 21:53:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2022-01-18 21:53:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.1 => 1 convert to 1
[2022-01-18 21:53:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.2 => 81 convert to 81
[2022-01-18 21:53:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2022-01-18 21:53:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2022-01-18 21:53:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2022-01-18 21:53:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.6 => 255 convert to 255
[2022-01-18 21:53:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.7 => 255 convert to 255
[2022-01-18 21:53:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.8 => 255 convert to 255
[2022-01-18 21:53:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.9 => 206 convert to 206
[2022-01-18 21:54:52][DEBUG] : {"devices":{"a4:c1:38:48:f3:fe:2d:45":{"1":{"61184":{"cmd":{"0":{"value":"6","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"1","cluster_name":"Cluster"},"1.2":{"value":"81","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"255","cluster_name":"Cluster"},"1.7":{"value":"255","cluster_name":"Cluster"},"1.8":{"value":"255","cluster_name":"Cluster"},"1.9":{"value":"206","cluster_name":"Cluster"}}}}}}}
[2022-01-18 21:54:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::0 => 6 convert to 6
[2022-01-18 21:54:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2022-01-18 21:54:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.1 => 1 convert to 1
[2022-01-18 21:54:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.2 => 81 convert to 81
[2022-01-18 21:54:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2022-01-18 21:54:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2022-01-18 21:54:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2022-01-18 21:54:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.6 => 255 convert to 255
[2022-01-18 21:54:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.7 => 255 convert to 255
[2022-01-18 21:54:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.8 => 255 convert to 255
[2022-01-18 21:54:52][DEBUG] : Search command for a4:c1:38:48:f3:fe:2d:45 logicalId : 1::61184::cmd::1.9 => 206 convert to 206
[2022-01-18 22:00:03][DEBUG] : http://127.0.0.1:8089/device/all type : GET
[2022-01-18 22:00:03][DEBUG] : null
[2022-01-18 22:01:24][DEBUG] : {"devices":{"00:12:4b:00:24:c2:50:d0":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2022-01-18 22:01:24][DEBUG] : Search attribut for 00:12:4b:00:24:c2:50:d0 logicalId : 1::6::0 => Bool.false convert to 0
[2022-01-18 22:01:39][DEBUG] : {"devices":{"00:12:4b:00:24:c2:51:83":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2022-01-18 22:01:39][DEBUG] : Search attribut for 00:12:4b:00:24:c2:51:83 logicalId : 1::6::0 => Bool.true convert to 1
[2022-01-18 22:02:04][DEBUG] : {"devices":{"00:12:4b:00:24:c1:18:ac":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2022-01-18 22:02:04][DEBUG] : Search attribut for 00:12:4b:00:24:c1:18:ac logicalId : 1::6::0 => Bool.true convert to 1
[2022-01-18 22:02:21][DEBUG] : http://127.0.0.1:8089/device/info?ieee=a4%3Ac1%3A38%3A48%3Af3%3Afe%3A2d%3A45 type : GET
[2022-01-18 22:02:21][DEBUG] : {"ieee":"a4:c1:38:48:f3:fe:2d:45"}
merci pour votre aide :+1:
Pour comprendre le fonctionnement, une fois la demande comment fait on pour savoir si la demande est accepté et suivre la progression…
Merci en tout cas du travail et du temps que vous consacrer pour la communauté :+1: :grinning:
Quel est le rapport avec github aussi ?
Il faut regarder le site compatibility.jeedom.com, quand la demande sera traitée tu auras ton module sur le site.
super merci Loic :+1: donc ma demande est conforme ? et en moyenne ça donne quoi , 1 semaine, 1 mois ? je consulterai toutes les semaines on verra bien… :grinning:
Ya pas de moyen ca peut etre demain (ici ca sera le cas) comme 1 an ca dépend de ma charge de travail.
ah ok c’est vous qui vous en occupé, en tout cas merci pour tout et je serais patient…
Patient ? Ca sera demain en beta c’est trop long ?
non 1 jour c’est top :sweat_smile:, patient pour les futures demande :grinning:
