Serait il possible d’ajouter la version variateur du bouton owon?
On peut le trouver ici :
Les données brut :
"ieee": "00:60:6e:ff:fe:97:bd:0a",
"nwk": 62027,
"status": 2,
"lqi": "None",
"rssi": "None",
"last_seen": "1684417061.525363",
"node_descriptor": "02:40:80:3c:11:52:52:00:00:2a:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 2048,
"profile_id": 260,
"manufacturer": "OWON",
"model": "SLC603",
"output_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"name": "Level control",
"attributes": []
"id": 768,
"name": "Color Control",
"attributes": []
"id": 4096,
"name": "LightLink",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 2
"id": 1,
"name": "app_version",
"value": 1
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 0
"id": 4,
"name": "manufacturer",
"value": "OWON"
"id": 5,
"name": "model",
"value": "SLC603"
"id": 6,
"name": "date_code",
"value": "20201028"
"id": 7,
"name": "power_source",
"value": 0
"id": 16384,
"name": "sw_build_id",
"value": ""
"id": 4096,
"attributes": []
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 33,
"name": "battery_percentage_remaining",
"value": 30
"signature": {
"model": "SLC603",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4412,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
4096,
1
3,
4,
6,
8,
768,
4096
"class": "zigpy.device"
et voici des log
[2023-05-18 15:37:43]DEBUG : {"devices":{"00:60:6e:ff:fe:97:bd:0a":{"1":{"6":{"cmd":[{"value":"2","cluster_name":"On\/Off"},{"value":"toggle()","cluster_name":"On\/Off"}]}}}}}
[2023-05-18 15:37:43]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::6::cmd::0 => 2 convert to 2
[2023-05-18 15:37:43]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::6::cmd::1 => toggle() convert to toggle()
[2023-05-18 15:37:47]DEBUG : {"devices":{"00:60:6e:ff:fe:97:bd:0a":{"1":{"8":{"cmd":{"0":{"value":"6","cluster_name":"Level control"},"1":{"value":"StepMode.Up","cluster_name":"Level control"},"1.1":{"value":"60","cluster_name":"Level control"},"1.2":{"value":"5","cluster_name":"Level control"}}}}}}}
[2023-05-18 15:37:47]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::8::cmd::0 => 6 convert to 6
[2023-05-18 15:37:47]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::8::cmd::1 => StepMode.Up convert to 1
[2023-05-18 15:37:47]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::8::cmd::1.1 => 60 convert to 60
[2023-05-18 15:37:47]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::8::cmd::1.2 => 5 convert to 5
[2023-05-18 15:37:47]DEBUG : {"devices":{"00:60:6e:ff:fe:97:bd:0a":{"1":{"6":{"cmd":[{"value":"2","cluster_name":"On\/Off"},{"value":"toggle()","cluster_name":"On\/Off"}]}}}}}
[2023-05-18 15:37:47]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::6::cmd::0 => 2 convert to 2
[2023-05-18 15:37:47]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::6::cmd::1 => toggle() convert to toggle()
[2023-05-18 15:37:48]DEBUG : {"devices":{"54:0f:57:ff:fe:1f:29:00":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}],"8":[{"value":"13","cluster_name":"Level control"}]}}}}
[2023-05-18 15:37:48]DEBUG : {"devices":{"00:60:6e:ff:fe:97:bd:0a":{"1":{"8":{"cmd":{"0":{"value":"2","cluster_name":"Level control"},"1":{"value":"StepMode.Down","cluster_name":"Level control"},"1.1":{"value":"90","cluster_name":"Level control"},"1.2":{"value":"5","cluster_name":"Level control"},"1.3":{"value":"None","cluster_name":"Level control"},"1.4":{"value":"None","cluster_name":"Level control"}}}}}}}
[2023-05-18 15:37:48]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::8::cmd::0 => 2 convert to 2
[2023-05-18 15:37:48]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::8::cmd::1 => StepMode.Down convert to 0
[2023-05-18 15:37:48]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::8::cmd::1.1 => 90 convert to 90
[2023-05-18 15:37:48]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::8::cmd::1.2 => 5 convert to 5
[2023-05-18 15:37:48]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::8::cmd::1.3 => None convert to None
[2023-05-18 15:37:48]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::8::cmd::1.4 => None convert to None
[2023-05-18 15:37:50]DEBUG : {"devices":{"00:60:6e:ff:fe:97:bd:0a":{"1":{"6":{"cmd":[{"value":"2","cluster_name":"On\/Off"},{"value":"toggle()","cluster_name":"On\/Off"}]}}}}}
[2023-05-18 15:37:50]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::6::cmd::0 => 2 convert to 2
[2023-05-18 15:37:50]DEBUG : Search command for 00:60:6e:ff:fe:97:bd:0a logicalId : 1::6::cmd::1 => toggle() convert to toggle()
Merci,
