Demande d'ajout module - Compteur de consommation - TS0601 - Tuya
J’ai acheté un compteur de consommation électrique sur AliExpress
Il s’agit du modèle TS0601 SMART_PLUG de Tuya.
Après l’avoir connecté à la clé Conbee2, il n’est pas référencé dans la liste des modules.
Je me demandais s’il y avait moyen de le rajouter car je ne peux malheureusement pas l’exploiter.
VOici les informations brutes :
    "ieee": "4c:5b:b3:ff:fe:d8:48:a0",
    "nwk": 9283,
    "status": 2,
    "lqi": "255",
    "rssi": "-55",
    "last_seen": "1701804340.505287",
    "node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 81,
            "profile_id": 260,
            "manufacturer": "_TZE204_cjbofhxw",
            "model": "TS0601",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 70
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZE204_cjbofhxw"
                            "id": 5,
                            "name": "model",
                            "value": "TS0601"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 61184,
                    "name": "Cluster",
                    "attributes": []
    "signature": {
        "model": "TS0601",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 81,
                "input_clusters": [
                    0,
                    4,
                    5,
                    61184
                    25,
                    10
    "class": "zigpy.device"
Si une autre personne à réussi à le faire fonctionner en créant à la mano les commandes, je suis preneur de l’astuce :slightly_smiling_face:
Merci à vous tous :+1:
Resté sur le plugin zigbee qui a ce jour est abandonné et ne sera plus mis à jour au profit du plugin jeezigbee (plugin-z2m) n’est pas une solution car vous rencontrerez le problème actuel à chaque achat de nouveau device. Je vous invite à migré vers le plugin jeezigbee qui s’appuie sur une base de device beaucoup plus grande et surtout mise à jour très régulièrement d’autant que ce nouveau plugin sera gratuit pour vous vu que vous avez déjà acheté l’ancien.
Merci @iPapy
Je suis effectivement passé à coté de cette important information :thinking:
Par conséquent, je sais ce que je vais avoir à faire dans les prochains jours :upside_down_face:
