Je souhaiterais faire ajouter le détecteur de présence Trust ZPIR-8000 que je viens d’acheter. Il semble qu’il y ait un quirk le concernant dans zha-quirks. Il ressemble à ça :
Voici ses infos brutes :
"ieee": "00:15:8d:00:02:02:c4:49",
"nwk": 23312,
"status": 2,
"lqi": "255",
"rssi": "-49",
"last_seen": "1626852292.5334585",
"node_descriptor": "02:40:80:37:10:7f:64:00:00:00:64:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1026,
"profile_id": 260,
"manufacturer": "ADUROLIGHT",
"model": "VMS_ADUROLIGHT",
"output_clusters": [],
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 1
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "ADUROLIGHT"
"id": 5,
"name": "model",
"value": "VMS_ADUROLIGHT"
"id": 6,
"name": "date_code",
"value": "2017-09-12"
"id": 7,
"name": "power_source",
"value": 3
"id": 16384,
"name": "sw_build_id",
"value": "v0.1.4"
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 33,
"name": "battery_percentage_remaining",
"value": 140
"id": 3,
"name": "Identify",
"attributes": []
"id": 1280,
"name": "IAS Zone",
"attributes": [
"id": 0,
"name": "zone_state",
"value": 0
"id": 16,
"name": "cie_addr",
"value": [
45,
1,
5,
255,
255,
46,
33,
0
"id": 65535,
"name": "Manufacturer Specific",
"attributes": []
"signature": {
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4151,
"maximum_buffer_size": 127,
"maximum_incoming_transfer_size": 100,
"server_mask": 0,
"maximum_outgoing_transfer_size": 100,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
1,
3,
1280,
65535
"class": "zhaquirks.trust.zpir8000"
Voici le log debug quand je passe devant le module (filtré sur l’adresse MAC de celui-ci, j’ai juste gardé la ligne indiquant le démarrage du démon):
[2021-07-21 09:29:12][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device auto --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey 2Y8lHAarXn8K6nmM637vMuWGNs1tia3O --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller deconz --sub_controller auto --channel 15 --folder_OTA /var/www/html/plugins/zigbee/data/ota
[2021-07-21 09:29:14][DEBUG] : null
[2021-07-21 09:29:57][DEBUG] : {"devices":{"00:15:8d:00:02:02:c4:49":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Restore_reports|Alarm_2","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-07-21 09:29:57][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1 => ZoneStatus.Restore_reports|Alarm_2 convert to 1
[2021-07-21 09:29:57][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2021-07-21 09:29:57][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-07-21 09:29:57][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-07-21 09:30:17][DEBUG] : {"devices":{"00:15:8d:00:02:02:c4:49":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Restore_reports","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-07-21 09:30:17][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1 => ZoneStatus.Restore_reports convert to ZoneStatus.Restore_reports
[2021-07-21 09:30:17][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2021-07-21 09:30:17][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-07-21 09:30:17][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-07-21 09:30:46][DEBUG] : {"devices":{"00:15:8d:00:02:02:c4:49":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Restore_reports|Alarm_2","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-07-21 09:30:46][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1 => ZoneStatus.Restore_reports|Alarm_2 convert to 1
[2021-07-21 09:30:46][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2021-07-21 09:30:46][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-07-21 09:30:46][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-07-21 09:31:06][DEBUG] : {"devices":{"00:15:8d:00:02:02:c4:49":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Restore_reports","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-07-21 09:31:06][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1 => ZoneStatus.Restore_reports convert to ZoneStatus.Restore_reports
[2021-07-21 09:31:06][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2021-07-21 09:31:06][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-07-21 09:31:06][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-07-21 09:31:21][DEBUG] : {"devices":{"00:15:8d:00:02:02:c4:49":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Restore_reports|Alarm_2","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-07-21 09:31:21][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1 => ZoneStatus.Restore_reports|Alarm_2 convert to 1
[2021-07-21 09:31:21][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2021-07-21 09:31:21][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-07-21 09:31:21][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-07-21 09:31:41][DEBUG] : {"devices":{"00:15:8d:00:02:02:c4:49":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Restore_reports","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-07-21 09:31:41][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1 => ZoneStatus.Restore_reports convert to ZoneStatus.Restore_reports
[2021-07-21 09:31:41][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2021-07-21 09:31:41][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-07-21 09:31:41][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-07-21 09:32:11][DEBUG] : {"devices":{"00:15:8d:00:02:02:c4:49":{"1":{"1280":{"cmd":{"1":{"value":"0","cluster_name":"IAS Zone"},"1.1":{"value":"0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-07-21 09:32:11][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1 => 0 convert to 0
[2021-07-21 09:32:11][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.1 => 0 convert to 0
[2021-07-21 09:32:11][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-07-21 09:32:11][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-07-21 09:32:11][DEBUG] : {"devices":{"00:15:8d:00:02:02:c4:49":{"1":{"1280":[{"value":"0","cluster_name":"IAS Zone"}]}}}}
[2021-07-21 09:32:11][DEBUG] : Search attribut for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::0 => 0 convert to 0
[2021-07-21 09:32:35][DEBUG] : {"devices":{"00:15:8d:00:02:02:c4:49":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Restore_reports|Alarm_2","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-07-21 09:32:35][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1 => ZoneStatus.Restore_reports|Alarm_2 convert to 1
[2021-07-21 09:32:35][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2021-07-21 09:32:35][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-07-21 09:32:35][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-07-21 09:32:55][DEBUG] : {"devices":{"00:15:8d:00:02:02:c4:49":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Restore_reports","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-07-21 09:32:55][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1 => ZoneStatus.Restore_reports convert to ZoneStatus.Restore_reports
[2021-07-21 09:32:55][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2021-07-21 09:32:55][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-07-21 09:32:55][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-07-21 09:33:25][DEBUG] : {"devices":{"00:15:8d:00:02:02:c4:49":{"1":{"1280":{"cmd":{"1":{"value":"0","cluster_name":"IAS Zone"},"1.1":{"value":"0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-07-21 09:33:25][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1 => 0 convert to 0
[2021-07-21 09:33:25][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.1 => 0 convert to 0
[2021-07-21 09:33:25][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-07-21 09:33:25][DEBUG] : Search command for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-07-21 09:33:25][DEBUG] : {"devices":{"00:15:8d:00:02:02:c4:49":{"1":{"1280":[{"value":"0","cluster_name":"IAS Zone"}]}}}}
[2021-07-21 09:33:25][DEBUG] : Search attribut for 00:15:8d:00:02:02:c4:49 logicalId : 1::1280::0 => 0 convert to 0
Merci d’avance pour son ajout dans Jeedom.
