Pourriez-vous ajouter ce nouvel équipement au niveau du plug-in Zigbee s’il vous plait ?
Par avance merci.
Cordialement
Lal
Modèle
Multiprise Silvercrest HG6338-FR
https://www.lidl.fr/p/smart-home/bloc-multiprise-usb-connecte/p74016
Informations Brutes
"ieee": "50:32:5f:ff:fe:30:2a:09",
"nwk": 64020,
"status": 2,
"lqi": "200",
"rssi": "-50",
"last_seen": "1645713448.7348309",
"node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 266,
"profile_id": 260,
"manufacturer": "_TZ3000_vzopcetz",
"model": "TS011F",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 70
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_vzopcetz"
"id": 5,
"name": "model",
"value": "TS011F"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 1
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"model": "TS011F",
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 266,
"input_clusters": [
0,
3,
4,
5,
6
25,
10
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
Le Log
[2022-02-25 09:06:18][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyUSB1 --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey qr5SS92XBcp00NsPmnhYCfIZqhXeDhWD --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller ezsp --sub_controller elelabs --channel 15
[2022-02-25 09:06:22][DEBUG] : null
[2022-02-25 09:06:35][DEBUG] : {"devices":{"50:32:5f:ff:fe:30:2a:09":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2022-02-25 09:06:35][DEBUG] : Search attribut for 50:32:5f:ff:fe:30:2a:09 logicalId : 1::6::0 => Bool.true convert to 1
[2022-02-25 09:06:37][DEBUG] : {"devices":{"50:32:5f:ff:fe:30:2a:09":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2022-02-25 09:06:37][DEBUG] : Search attribut for 50:32:5f:ff:fe:30:2a:09 logicalId : 1::6::0 => Bool.false convert to 0
[2022-02-25 09:06:48][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-02-25 09:06:48][DEBUG] : {"ieee":"50:32:5f:ff:fe:30:2a:09","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2022-02-25 09:06:49][DEBUG] : {"devices":{"50:32:5f:ff:fe:30:2a:09":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2022-02-25 09:06:49][DEBUG] : Search attribut for 50:32:5f:ff:fe:30:2a:09 logicalId : 1::6::0 => Bool.true convert to 1
[2022-02-25 09:06:50][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-02-25 09:06:50][DEBUG] : {"ieee":"50:32:5f:ff:fe:30:2a:09","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false}
[2022-02-25 09:06:50][DEBUG] : {"devices":{"50:32:5f:ff:fe:30:2a:09":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2022-02-25 09:06:50][DEBUG] : Search attribut for 50:32:5f:ff:fe:30:2a:09 logicalId : 1::6::0 => Bool.false convert to 0
[2022-02-25 09:06:52][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-02-25 09:06:52][DEBUG] : {"ieee":"50:32:5f:ff:fe:30:2a:09","cmd":[{"endpoint":2,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2022-02-25 09:06:52][ERROR] : Erreur exécution de la commande [Bureau][TZ3000_vzopcetz.TS011F 50:32:5f:ff:fe:30:2a:09][On 2] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"50:32:5f:ff:fe:30:2a:09","cmd":[{"endpoint":2,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[50:32:5f:ff:fe:30:2a:09][zdevices.command] Endpoint not found : 2","code":0}
[2022-02-25 09:06:59][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-02-25 09:06:59][DEBUG] : {"ieee":"50:32:5f:ff:fe:30:2a:09","cmd":[{"endpoint":3,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2022-02-25 09:06:59][ERROR] : Erreur exécution de la commande [Bureau][TZ3000_vzopcetz.TS011F 50:32:5f:ff:fe:30:2a:09][On 3] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"50:32:5f:ff:fe:30:2a:09","cmd":[{"endpoint":3,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[50:32:5f:ff:fe:30:2a:09][zdevices.command] Endpoint not found : 3","code":0}
[2022-02-25 09:07:26][DEBUG] : {"devices":{"50:32:5f:ff:fe:30:2a:09":{"1":[{"1":{"value":"70","cluster_name":"Basic"}}]}}}
[2022-02-25 09:07:26][DEBUG] : Search attribut for 50:32:5f:ff:fe:30:2a:09 logicalId : 1::0::1 => 70 convert to 70
[2022-02-25 09:08:08][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyUSB1 --loglevel info --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey qr5SS92XBcp00NsPmnhYCfIZqhXeDhWD --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller ezsp --sub_controller elelabs --channel 15
