Demande d'ajout d'équipement Multiprise Lidl HG6338-FR
Pourriez-vous ajouter ce nouvel équipement au niveau du plug-in Zigbee s’il vous plait ?
Par avance merci.
Cordialement
Lal
Modèle
Multiprise Silvercrest HG6338-FR
https://www.lidl.fr/p/smart-home/bloc-multiprise-usb-connecte/p74016
HG6338
Informations Brutes
    "ieee": "50:32:5f:ff:fe:30:2a:09",
    "nwk": 64020,
    "status": 2,
    "lqi": "200",
    "rssi": "-50",
    "last_seen": "1645713448.7348309",
    "node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 266,
            "profile_id": 260,
            "manufacturer": "_TZ3000_vzopcetz",
            "model": "TS011F",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 70
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_vzopcetz"
                            "id": 5,
                            "name": "model",
                            "value": "TS011F"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "model": "TS011F",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 266,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6
                    25,
                    10
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zigpy.device"
Le Log
[2022-02-25 09:06:18][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyUSB1 --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey qr5SS92XBcp00NsPmnhYCfIZqhXeDhWD --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller ezsp --sub_controller elelabs --channel 15
[2022-02-25 09:06:22][DEBUG] : null
[2022-02-25 09:06:35][DEBUG] : {"devices":{"50:32:5f:ff:fe:30:2a:09":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2022-02-25 09:06:35][DEBUG] : Search attribut for 50:32:5f:ff:fe:30:2a:09 logicalId : 1::6::0 => Bool.true convert to 1
[2022-02-25 09:06:37][DEBUG] : {"devices":{"50:32:5f:ff:fe:30:2a:09":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2022-02-25 09:06:37][DEBUG] : Search attribut for 50:32:5f:ff:fe:30:2a:09 logicalId : 1::6::0 => Bool.false convert to 0
[2022-02-25 09:06:48][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-02-25 09:06:48][DEBUG] : {"ieee":"50:32:5f:ff:fe:30:2a:09","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2022-02-25 09:06:49][DEBUG] : {"devices":{"50:32:5f:ff:fe:30:2a:09":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2022-02-25 09:06:49][DEBUG] : Search attribut for 50:32:5f:ff:fe:30:2a:09 logicalId : 1::6::0 => Bool.true convert to 1
[2022-02-25 09:06:50][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-02-25 09:06:50][DEBUG] : {"ieee":"50:32:5f:ff:fe:30:2a:09","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false}
[2022-02-25 09:06:50][DEBUG] : {"devices":{"50:32:5f:ff:fe:30:2a:09":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2022-02-25 09:06:50][DEBUG] : Search attribut for 50:32:5f:ff:fe:30:2a:09 logicalId : 1::6::0 => Bool.false convert to 0
[2022-02-25 09:06:52][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-02-25 09:06:52][DEBUG] : {"ieee":"50:32:5f:ff:fe:30:2a:09","cmd":[{"endpoint":2,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2022-02-25 09:06:52][ERROR] : Erreur exécution de la commande [Bureau][TZ3000_vzopcetz.TS011F 50:32:5f:ff:fe:30:2a:09][On 2] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"50:32:5f:ff:fe:30:2a:09","cmd":[{"endpoint":2,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[50:32:5f:ff:fe:30:2a:09][zdevices.command] Endpoint not found : 2","code":0}
[2022-02-25 09:06:59][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-02-25 09:06:59][DEBUG] : {"ieee":"50:32:5f:ff:fe:30:2a:09","cmd":[{"endpoint":3,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2022-02-25 09:06:59][ERROR] : Erreur exécution de la commande [Bureau][TZ3000_vzopcetz.TS011F 50:32:5f:ff:fe:30:2a:09][On 3] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"50:32:5f:ff:fe:30:2a:09","cmd":[{"endpoint":3,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[50:32:5f:ff:fe:30:2a:09][zdevices.command] Endpoint not found : 3","code":0}
[2022-02-25 09:07:26][DEBUG] : {"devices":{"50:32:5f:ff:fe:30:2a:09":{"1":[{"1":{"value":"70","cluster_name":"Basic"}}]}}}
[2022-02-25 09:07:26][DEBUG] : Search attribut for 50:32:5f:ff:fe:30:2a:09 logicalId : 1::0::1 => 70 convert to 70
[2022-02-25 09:08:08][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyUSB1 --loglevel info --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey qr5SS92XBcp00NsPmnhYCfIZqhXeDhWD --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller ezsp --sub_controller elelabs --channel 15
