Je viens de recevoir cet interrupteur double de marque MOES et de code TS0601.
Dans le plugin Zigbee, il existe plusieurs références TS0601 sous TUYA (capteur de gaz, thermostat intelligent, dimmer), mais, bien sûr aucune ne reconnait mon équipement.
Serait-il possible d’intégrer cet équipement au plugin Zigbee (de préférence sous la marque MOES) ?
Voici ses données brutes :
"ieee": "60:a4:23:ff:fe:a7:95:53",
"nwk": 59535,
"status": 2,
"lqi": "156",
"rssi": "-61",
"last_seen": "1625120595.3230877",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"manufacturer": "_TZE200_g1ib5ldv",
"model": "TS0601",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 66
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZE200_g1ib5ldv"
"id": 5,
"name": "model",
"value": "TS0601"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 61184,
"name": "Cluster",
"attributes": []
"signature": {
"model": "TS0601",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
0,
4,
5,
61184
25,
10
"class": "zigpy.device"
Log Zigbee lors du ON sur la touche 1 :
[2021-07-01 08:46:07][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"36","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"1","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:46:07][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:46:07][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:46:07][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 36
[2021-07-01 08:46:07][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 1
[2021-07-01 08:46:07][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 1
[2021-07-01 08:46:07][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:46:07][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:46:07][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 1
[2021-07-01 08:46:13][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"37","cluster_name":"Cluster"},"1.2":{"value":"2","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:46:13][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:46:13][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:46:13][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 37
[2021-07-01 08:46:13][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 2
[2021-07-01 08:46:13][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 1
[2021-07-01 08:46:13][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:46:13][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:46:13][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 0
[2021-07-01 08:46:14][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"38","cluster_name":"Cluster"},"1.2":{"value":"14","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:46:14][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:46:14][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:46:14][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 38
[2021-07-01 08:46:14][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 14
[2021-07-01 08:46:14][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 4
[2021-07-01 08:46:14][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:46:14][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:46:14][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 0
[2021-07-01 08:46:15][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"39","cluster_name":"Cluster"},"1.2":{"value":"15","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"2","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:46:15][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:46:15][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:46:15][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 39
[2021-07-01 08:46:15][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 15
[2021-07-01 08:46:15][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 4
[2021-07-01 08:46:15][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:46:15][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:46:15][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 2
Log Zigbee lors du OFF sur la touche 1 :
[2021-07-01 08:46:53][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"39","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:46:53][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:46:53][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:46:53][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 39
[2021-07-01 08:46:53][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 1
[2021-07-01 08:46:53][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 1
[2021-07-01 08:46:53][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:46:53][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:46:53][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 0
[2021-07-01 08:46:58][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"40","cluster_name":"Cluster"},"1.2":{"value":"2","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:46:58][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:46:58][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:46:58][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 40
[2021-07-01 08:46:58][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 2
[2021-07-01 08:46:58][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 1
[2021-07-01 08:46:58][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:46:58][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:46:58][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 0
[2021-07-01 08:46:59][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"41","cluster_name":"Cluster"},"1.2":{"value":"14","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:46:59][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:46:59][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:46:59][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 41
[2021-07-01 08:46:59][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 14
[2021-07-01 08:46:59][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 4
[2021-07-01 08:46:59][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:46:59][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:46:59][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 0
[2021-07-01 08:47:00][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"42","cluster_name":"Cluster"},"1.2":{"value":"15","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"2","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:47:00][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:47:00][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:47:00][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 42
[2021-07-01 08:47:00][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 15
[2021-07-01 08:47:00][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 4
[2021-07-01 08:47:00][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:47:00][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:47:00][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 2
Log Zigbee lors du ON sur la touche 2 :
[2021-07-01 08:47:36][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"42","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:47:36][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:47:36][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:47:36][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 42
[2021-07-01 08:47:36][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 1
[2021-07-01 08:47:36][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 1
[2021-07-01 08:47:36][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:47:36][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:47:36][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 0
[2021-07-01 08:47:42][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"43","cluster_name":"Cluster"},"1.2":{"value":"2","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"1","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:47:42][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:47:42][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:47:42][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 43
[2021-07-01 08:47:42][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 2
[2021-07-01 08:47:42][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 1
[2021-07-01 08:47:42][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:47:42][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:47:42][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 1
[2021-07-01 08:47:43][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"44","cluster_name":"Cluster"},"1.2":{"value":"14","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:47:43][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:47:43][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:47:43][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 44
[2021-07-01 08:47:43][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 14
[2021-07-01 08:47:43][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 4
[2021-07-01 08:47:43][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:47:43][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:47:43][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 0
[2021-07-01 08:47:44][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"45","cluster_name":"Cluster"},"1.2":{"value":"15","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"2","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:47:44][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:47:44][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:47:44][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 45
[2021-07-01 08:47:44][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 15
[2021-07-01 08:47:44][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 4
[2021-07-01 08:47:44][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:47:44][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:47:44][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 2
Log Zigbee lors du OFF sur la touche 2 :
[2021-07-01 08:48:10][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"45","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:48:10][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:48:10][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:48:10][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 45
[2021-07-01 08:48:10][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 1
[2021-07-01 08:48:10][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 1
[2021-07-01 08:48:10][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:48:10][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:48:10][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 0
[2021-07-01 08:48:13][DEBUG] : {"devices":{"00:15:8d:00:06:a2:60:67":{"1":{"1280":{"cmd":{"1":{"value":"0","cluster_name":"IAS Zone"},"1.1":{"value":"0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-07-01 08:48:13][DEBUG] : Search command for 00:15:8d:00:06:a2:60:67 logicalId : 1::1280::cmd::1 => 0
[2021-07-01 08:48:14][DEBUG] : Search command for 00:15:8d:00:06:a2:60:67 logicalId : 1::1280::cmd::1.1 => 0
[2021-07-01 08:48:14][DEBUG] : Search command for 00:15:8d:00:06:a2:60:67 logicalId : 1::1280::cmd::1.2 => 0
[2021-07-01 08:48:14][DEBUG] : Search command for 00:15:8d:00:06:a2:60:67 logicalId : 1::1280::cmd::1.3 => 0
[2021-07-01 08:48:14][DEBUG] : {"devices":{"00:15:8d:00:06:a2:60:67":{"1":{"1280":[{"value":"0","cluster_name":"IAS Zone"}]}}}}
[2021-07-01 08:48:14][DEBUG] : Search attribut for 00:15:8d:00:06:a2:60:67 logicalId : 1::1280::0 => 0
[2021-07-01 08:48:16][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"46","cluster_name":"Cluster"},"1.2":{"value":"2","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:48:16][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:48:16][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:48:16][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 46
[2021-07-01 08:48:16][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 2
[2021-07-01 08:48:16][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 1
[2021-07-01 08:48:16][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:48:16][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:48:16][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 0
[2021-07-01 08:48:17][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"47","cluster_name":"Cluster"},"1.2":{"value":"14","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:48:17][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:48:17][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:48:17][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 47
[2021-07-01 08:48:17][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 14
[2021-07-01 08:48:17][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 4
[2021-07-01 08:48:17][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:48:17][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:48:17][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 0
[2021-07-01 08:48:18][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:95:53":{"1":{"61184":{"cmd":{"0":{"value":"1","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"48","cluster_name":"Cluster"},"1.2":{"value":"15","cluster_name":"Cluster"},"1.3":{"value":"4","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"2","cluster_name":"Cluster"}}}}}}}
[2021-07-01 08:48:18][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::0 => 1
[2021-07-01 08:48:18][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1 => 0
[2021-07-01 08:48:18][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.1 => 48
[2021-07-01 08:48:18][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.2 => 15
[2021-07-01 08:48:18][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.3 => 4
[2021-07-01 08:48:18][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.4 => 0
[2021-07-01 08:48:18][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.5 => 1
[2021-07-01 08:48:18][DEBUG] : Search command for 60:a4:23:ff:fe:a7:95:53 logicalId : 1::61184::cmd::1.6 => 2
Image :
A disposition pour toute autre information.
Avec mes remerciements.
