Demande d’intégration Aubess SMOKE ALARM - TS0601
Serait-il possible d’intégrer ce dispositif de détection de fumée de la marque TUYA s’il vous plaît ?
Informations brutes :
    "ieee": "a4:c1:38:cf:43:05:f4:81",
    "nwk": 23363,
    "status": 2,
    "lqi": "255",
    "rssi": "-40",
    "last_seen": "1662019963.753286",
    "node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 81,
            "profile_id": 260,
            "manufacturer": "_TZE200_uebojraa",
            "model": "TS0601",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 61184,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 72
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZE200_uebojraa"
                            "id": 5,
                            "name": "model",
                            "value": "TS0601"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
    "signature": {
        "model": "TS0601",
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 81,
                "input_clusters": [
                    4,
                    5,
                    61184,
                    0
                    25,
                    10
    "class": "zigpy.device"
Lien du produit :
https://fr.aliexpress.com/item/1005004165407678.html?spm=a2g0o.order_list.0.0.b2835e5b3c599e&gatewayAdapt=glo2fra
Image du produit :
https://ae01.alicdn.com/kf/Sf97a0ae8bc174608992f7a41d0ac405f8/D-tecteur-de-fum-e-Tuya-ZigBee-alarme-incendie-fonctionne-avec-application-Smart-Life-informations-Push.jpg_Q90.jpg_.webp
Merci d’avance.
Bruce
Merci pour les informations, par contre vu que c’est du tuya et donc pas standard zigbee il va falloir attendre que zigpy l’integre pour qu’on puisse ensuite faire l’integration.
Bonjour @Loic et merci pour le retour.
Soyons patient alors :wink:
Bruce
Ce module semble géré par Zigbee2mqtt auquel il faut penser : TuYa TS0601_co2_sensor control via MQTT | Zigbee2MQTT
OUI Z2M gere en general plus de module et plus vite que nous
Merci pour l’info @ste.che :slight_smile:
Je préfère attendre que le module soit intégré au plugin…
BONjour,
savez-vous si ce module a été intégré ?
:slight_smile:
Même si ce dernier l’a été le plugin-zigbee est abandonné, il faut migrer sur le plugin-z2m
